Компьютеры в корпусе формата ATX Mid Tower имеют такую же общую конструкцию и компоненты, как и другие компьютерные корпуса среднего размера.
My Windows 10 computer is boot looping
Hello,
So this has started very recently. My Windows 10 computer is entering a boot loop, and won't get out of it. Already tried restarting it, wouldn't work. Already attempted to go into Windows Recovery, just kept boot looping. I have an AM4 CPU, just in case you guys need any information about the motherboard. All help is accepted!
Many thanks,
T
Update: 7/29/26 5:02 PM
Nevermind, my computer was being slow 😅. Thanks, to anyone who see's this, anyways.
T
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @Theo Grefalda
If you PC is slow on startup you can always turn off fast startup and check if that may help
Also it's always handy to keep an up to date Win 10 recovery USB flashdrive around so that you can repair the OS if there's problems.
You can create a recovery USB from any known working Win10 PC. All you need is a 16GB USB flashdrive and 1-2 hours of time.
In the host PC go to Control panel > Recovery > Create a recovery drive and follow the prompts.
When you have the recovery drive, turn on your PC and then either get into BIOS or use the appropriate function key to make USB as the 1st boot option.
Insert the USB flashdrive into a USB port and the PC should boot from the USB drive into the Windows Recovery Environment menus.
When in the WRE menus select Troubleshooting > Advanced and select what options you want e.g. if the OS can't be found on the HDD/SSD by BIOS or doesn't boot properly select Startup Repair or Safe Mode with Networking etc.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Hey, @jayeff ! So the situation is mostly dealt with, and I would suspect that the Hard Drive is bad. We already gave the motherboard another SSD, and we are going to put Win10 on that SSD. Many thanks, though!
из
Добавьте свой ответ
Theo Grefalda буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 22
За всё время: 66
