My psp is bricked
how to unbrick , need the passages.
Это хороший вопрос?
Счет 0
8 Комментариев:
Hi! Sorry, but we need more information. How do you know it's bricked? Did you modded it in the past? If yes, what happens when you try to boot it with the "R" button pressed in? Or won't it turn on at all?
Thanks.
из
there is a recovery menu appearing , and in my psp 3000 nothing happens when i turn it on for now
из
This is actually good. It means it's modded. Stock PSP's will not have a recovery menu. From there you can do more. I would check if you can try to boot normally from that menu. Does that work? Otherwise you need to do a recovery from there. But, you got 2 PSP which aren't working? Can you clarify this? Thanks!
из
i actually have 3 psp lol , i have 2 psp's E1000 and then a psp 3000. and about the recovery menu , i can't manage to boot in i mean there is no place where i can boot it , there is :toggle usb ,configuration , run program at " psp/game/recovery/eboot.pbp " , advanced , cpu speed , plugins , registry hacks , misc, exit . exit just does nothing
из
and i just managed randomly to go in like the " start " page where it tells you to set the time and the date , but seems softlocked. and my other psp i think it's not a 3000 but a 2000.. idk
из
Показать ещё 3 комментариев
Добавить комментарий
