Car Vibration when accelerating
What causes the car to shake during acceleration around 40 mph
Это хороший вопрос?
Это хороший вопрос?
Shaking can be caused by a number of reasons, so there's troubleshooting that needs to be done before it can be properly diagnosed.
First thing is to try and identify where you're feeling the shaking. Is it coming through the steering wheel? That would indicate one of your front tires or wheels, or even a wheel bearing. Similarly, if someone riding in the back seat feels it coming through the floor or behind them, you'd want to concentrate on one of the rear wheels. In any case, it wouldn't hurt to jack up the car and spin each wheel individually; you're looking for any bulges or out of round conditions on any of the four wheels, although a bad tire would usually cause shaking whether or not you're accelerating. While you have the wheels off the ground, grab them by the sides and try to move them left and right to see if there's any play in them; likewise hold onto the top and bottom and try again. Left to right only issues would indicate steering linkage issues, while top to bottom only movement is usually ball joints. Play in all directions and you're looking at wheel bearings.
Shaking can also come from the drivetrain, again there are several possibilities there. Is the engine running well? A misfiring cylinder can cause shaking in the engine, which can be more noticeable under load. Speaking of load, the engine and transmission mounts are meant to stabilize the drivetrain, especially under load, so a broken transmission or engine mount can cause movement of the engine when it isn't supposed to.
As you can see, there isn't one answer to your question, so you'll have to check some of the things I've mentioned and see if you can pin down the source a little better, because there's not much we can tell you with just the information you've given so far.
Был ли этот ответ полезен?
tbh the way I isolate it is I run the engine and feel it for shaking and rev it - if it doesn't do it in park and I can't feel it in park, I know I need to look at the body. I can usually tell which side is bad by the side that feels off - driver=right side under the engine, passenger=left side under the engine. It's not 100% effective but it tells you a lot.
@nick Thanks, I did forget to mention that; frequently I'll put it in drive with the emergency brake on and my foot hard on the brake while revving the engine; that puts a load on the engine to pin down if the problem starts there.
@dadibrokeit I do it in park and take it out on a drive I know the area — think rec center. This gen uses e-braking so you can't hold it.
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 38
За все время: 38
