ASUS D550MA-DS01 Battery Replacement
Выберете то, что вам нужно
    1. ASUS D550MA-DS01 Battery Replacement, Keyboard Module: шаг 1, изображение 1 из 2 ASUS D550MA-DS01 Battery Replacement, Keyboard Module: шаг 1, изображение 2 из 2
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
      Спросите у FixBot
      Добавить комментарий
    2. ASUS D550MA-DS01 Battery Replacement: шаг 2, изображение 1 из 1
      • Turn the laptop over and open the display.
      • Insert the flat edge of the spudger into the crease of the keyboard cover.
      • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
      • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
      Спросите у FixBot
    3. ASUS D550MA-DS01 Battery Replacement: шаг 3, изображение 1 из 2 ASUS D550MA-DS01 Battery Replacement: шаг 3, изображение 2 из 2
      • Make sure that the entire cover has been released from the plastic clips.
      • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
      • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
      Спросите у FixBot
    4. ASUS D550MA-DS01 Battery Replacement: шаг 4, изображение 1 из 1
      • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
      • Disconnect the three data cables from the motherboard.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      Спросите у FixBot
    5. ASUS D550MA-DS01 Battery Replacement: шаг 5, изображение 1 из 1
      • Remove the fully disconnected keyboard module from the laptop.
      Спросите у FixBot
    1. ASUS D550MA-DS01 Battery Replacement, Battery: шаг 6, изображение 1 из 2 ASUS D550MA-DS01 Battery Replacement, Battery: шаг 6, изображение 2 из 2
      • Do not use any metal tool to pry any type of battery. Doing so can puncture or short the battery, resulting in damage or injury.
      • Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
      Спросите у FixBot
    2. ASUS D550MA-DS01 Battery Replacement: шаг 7, изображение 1 из 2 ASUS D550MA-DS01 Battery Replacement: шаг 7, изображение 2 из 2
      • Lift the battery out and remove it:
      • The battery is connected to the motherboard on the left side.
      • Use your fingertips to evenly grip the battery on the left and right sides of the battery.
      • Pull straight up to lift the battery out of its place.
      • Do not use excessive force or attempt to pry the battery with any tools. Doing so will result in damage to the laptop.
      Спросите у FixBot
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 человек успешно провели ремонт по этому руководству.
Richard Johnson
Участник с: 09/16/15
707 Репутация
Автор 5 руководств
Команда
IUPUI, Team 1-2, Baechle Fall 2015 Участник IUPUI, Team 1-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G2
3 членов
Автор 44 руководств
2 Комментарии к руководству
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Robert Beasley - Ответить Поделиться
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
MIGUEL MORENO - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 38
За всё время: 5,979
