Amazon Echo Show 10 3rd Gen Display Replacement
Выберете то, что вам нужно
    1. Amazon Echo Show 10 3rd Gen Display Replacement, Display: шаг 1, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Display Replacement, Display: шаг 1, изображение 2 из 2
      • With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set aside.
      Спросите у FixBot
      Добавить комментарий
    2. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 2, изображение 1 из 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      Спросите у FixBot
    3. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 3, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Display Replacement: шаг 3, изображение 2 из 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      Спросите у FixBot
    4. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 4, изображение 1 из 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      Спросите у FixBot
    5. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 5, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Display Replacement: шаг 5, изображение 2 из 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      Спросите у FixBot
    6. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 6, изображение 1 из 1
      • Tilt the device so that the underside of the display and its neck are facing you.
      • You may need help holding it in this position. Alternatively, you could place the device on a soft surface so it doesn't get damaged.
      • Use a T6 Torx screwdriver to remove the two 5mm screws from the underside of the display neck.
      Спросите у FixBot
    7. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 7, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Display Replacement: шаг 7, изображение 2 из 2
      • Lift the plate up to remove it from the neck of the device.
      • Set it aside for reassembly.
      Спросите у FixBot
    8. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 8, изображение 1 из 1
      • Use an opening tool to flip up the small locking flap on the ribbon cable connector located in the center of the exposed underside of the display neck.
      • Gently pull the cable out.
      Спросите у FixBot
    9. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 9, изображение 1 из 1
      • Tilt the device so it is in the upright position.
      • Use a TR10 Torx Security screwdriver to remove the four 11 mm screws from the top of the display neck.
      Спросите у FixBot
    10. Amazon Echo Show 10 3rd Gen Display Replacement: шаг 10, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Display Replacement: шаг 10, изображение 2 из 2
      • Gently lift the display and its connecting neck off of the base.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Macy Ormand
Участник с: 09/13/23
1 101 Репутация
Автор 6 руководств
Команда
Western Carolina University, Team 1-4, Virtue Fall 2023 Участник Western Carolina University, Team 1-4, Virtue Fall 2023
WCU-VIRTUE-F23S1G4
4 членов
Автор 12 руководств
6 Комментарии к руководству
any idea where to purchase a replacement display?
Don Jackson - Ответить Поделиться
Were you able to source a replacement display? I'm having troubles finding one. Thanks
Jeg4 - Ответить Поделиться
where can I buy a replacement display for echo 10 3rd gen?
Tomasz K. - Ответить Поделиться
@tomaszk64280 por la plataforma de amazon, pero no aparece el tutorial para cambiar solo la pantalla
ARIAS SEGUROS Y CIA LTDA - Ответить Поделиться
Wenn ihr eine Quelle gefunden habt wäre eine info schön ich suche nun auch nach einem kleinen missgeschick...
Jan Pfotenhauer - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 26
За последние 30 дней: 95
За всё время: 2,667
