Amazon Echo Show 10 3rd Gen Tweeter Replacement
Выберете то, что вам нужно
    1. Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: шаг 1, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: шаг 1, изображение 2 из 2
      • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set it aside.
      Спросите у FixBot
      Добавить комментарий
    2. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 2, изображение 1 из 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      Спросите у FixBot
    3. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 3, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 3, изображение 2 из 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      Спросите у FixBot
    4. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 4, изображение 1 из 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      Спросите у FixBot
    5. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 5, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 5, изображение 2 из 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      Спросите у FixBot
    6. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 6, изображение 1 из 2 Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 6, изображение 2 из 2
      • Rotate the device to lay on its side with the tweeter's exterior facing you.
      • Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
      Спросите у FixBot
    7. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 7, изображение 1 из 1
      • Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
      Спросите у FixBot
    8. Amazon Echo Show 10 3rd Gen Tweeter Replacement: шаг 8, изображение 1 из 1
      • Remove the tweeter.
      • Repeat the previous steps if you are removing the other tweeter.
      Спросите у FixBot
Заключение
Macy Ormand
Участник с: 09/13/23
1 101 Репутация
Автор 6 руководств
Команда
Western Carolina University, Team 1-4, Virtue Fall 2023 Участник Western Carolina University, Team 1-4, Virtue Fall 2023
WCU-VIRTUE-F23S1G4
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 501
