Введение
If your Arlo Pro 2 camera is damaged, blurry, or not providing a video feed, follow this guide to replace the devices camera lens.
If the Arlo camera has fallen or been interfered with it may be not show a clear picture on the connected device.
Before using the guide, disconnect the Arlo Pro 2 camera from the device and power it off.
Выберете то, что вам нужно
Press the release button on the camera and gently pull apart the casing to open the device.
Remove the battery from inside the case.
Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
Seperate the daughterboards from the motherboard and camera casing.
Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
Carefully pull the motherboard apart from the camera casing.
Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
Use a Philips #00 screwdriver to remove the four 4 mm screws on the back metal plate holding the daughterboards together.
Use a Philips #00 screwdriver to remove the two 5 mm screws on the back of the camera daughterboard to disconnect the camera piece from the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
