Введение
The Asus ROG G20CB is a compact gaming desktop that uses custom cooling and a specialized case layout. Replacing the graphics card (GPU) can significantly boost performance, but due to the small form factor and custom internal design, it's slightly trickier than on a regular tower. This guide will walk you through the process carefully.
Check GPU size: The G20CB supports small dual-slot GPUs (generally under 10.5 inches / 266mm long). Only 6-pin or 8-pin PCIe connectors.
Выберете то, что вам нужно
Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
Disconnect the cable carefully by pulling gently on both sides of the connector.
Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
Remove the three 4.6 mm Phillips screws from the graphics card housing.
Push down the clip on the red cable connector and firmly pull the cable from the graphics card.
Use one hand to bend up the PCIE riser clip, then with the other hand push it off the graphics card.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
