Dell XPS 15 9575 Screen Replacement
Выберете то, что вам нужно
    1. Dell XPS 15 9575 Screen  Replacement, Bottom Cover: шаг 1, изображение 1 из 3 Dell XPS 15 9575 Screen  Replacement, Bottom Cover: шаг 1, изображение 2 из 3 Dell XPS 15 9575 Screen  Replacement, Bottom Cover: шаг 1, изображение 3 из 3
      • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
      • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
      • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
      Спросите у FixBot
      Добавить комментарий
    2. Dell XPS 15 9575 Screen  Replacement: шаг 2, изображение 1 из 1
      • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
      • Remove the bottom cover from the device when all sides are free.
      Спросите у FixBot
    1. Dell XPS 15 9575 Screen  Replacement, Heat Sink: шаг 3, изображение 1 из 2 Dell XPS 15 9575 Screen  Replacement, Heat Sink: шаг 3, изображение 2 из 2
      • Wedge the plastic opening pick in between the aluminum cover and the motherboard.
      • Gently pull up popping off the cover and revealing the rest of the heat sink.
      • The aluminum cover will slot into small clamps on all sides, so be sure to align all sides within the clamps during reinstallation.
      Спросите у FixBot
    2. Dell XPS 15 9575 Screen  Replacement: шаг 4, изображение 1 из 2 Dell XPS 15 9575 Screen  Replacement: шаг 4, изображение 2 из 2
      • Use the Phillips #0 screwdriver to remove all five black 3.2mm screws.
      Спросите у FixBot
    3. Dell XPS 15 9575 Screen  Replacement: шаг 5, изображение 1 из 2 Dell XPS 15 9575 Screen  Replacement: шаг 5, изображение 2 из 2
      • Wedge the plastic opening pick in between the edge of the heat sink and the aluminum perimeter with care not to scratch the CPU beneath.
      • Gently pry up on the heat sink until it is loose enough for you to remove. Then grab and remove the heat sink.
      • If it does not work in the first position that you tried, try another. Do not pry too much in one position because it could damage the components beneath the heat sink.
      • Clean and Reapply the Thermal Paste during reinstallation.
      Спросите у FixBot
    1. Dell XPS 15 9575 Screen  Replacement, Screen: шаг 6, изображение 1 из 3 Dell XPS 15 9575 Screen  Replacement, Screen: шаг 6, изображение 2 из 3 Dell XPS 15 9575 Screen  Replacement, Screen: шаг 6, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • Use a plastic opening pick to pop up the small black tab of the touchscreen ZIF connector.
      • The black tab should not pop out, but rather hinge upwards. It will release the ribbon cable from its connector.
      • Use the tweezers to remove the orange ribbon cable from the connector and peel the ribbon from the backboard, as it's secured with a light adhesive.
      Спросите у FixBot
    2. Dell XPS 15 9575 Screen  Replacement: шаг 7, изображение 1 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 7, изображение 2 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 7, изображение 3 из 3
      • Two silver screws are holding down the aluminium dust cover protecting the display connections.
      • Use the Phillips #0 screwdriver to remove two 3.2 mm silver screws.
      • Use the tweezers to remove the grey cover.
      • Under the cover, you will see one white wire and one black wire.
      • Use the tweezers and gently pull straight up on each of the coaxial cables to disconnect them from their specialized brackets.
      • Reposition the tweezers farther up on the wire and pull forward to remove the wires from the plastic guides that hold the them in place.
      Спросите у FixBot
    3. Dell XPS 15 9575 Screen  Replacement: шаг 8, изображение 1 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 8, изображение 2 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 8, изображение 3 из 3
      • Use the Phillips #0 screwdriver to remove the two 3.2 mm black screws holding down the cover.
      • Now use the tweezers to carefully remove the silver cover from the backboard.
      • Under the cover you will see the display cable fused to a rectangular adapter.
      • Gently wedge the plastic opening pick in between the display cable and the backboard.
      • Gently pry up disconnecting the adapter with the display cable from its bracket.
      Спросите у FixBot
    4. Dell XPS 15 9575 Screen  Replacement: шаг 9, изображение 1 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 9, изображение 2 из 3 Dell XPS 15 9575 Screen  Replacement: шаг 9, изображение 3 из 3
      • Open the screen until it is 180 degrees from the keyboard and then lay the laptop face down.
      • Use the Phillips #0 screwdriver to remove the six, 6.3 mm, silver screws securing the hinges.
      Спросите у FixBot
    5. Dell XPS 15 9575 Screen  Replacement: шаг 10, изображение 1 из 1
      • Make sure all previous steps are done before this step, as this step could result in damaging the computer.
      • Grip the screen assembly and gently pull straight up from the table removing the entire assembly.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Michael Papadopolous
Участник с: 09/20/19
377 Репутация
Автор 2 руководств
Команда
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 35
За всё время: 2,809
