Google Pixel 3 Back Cover Adhesive Installation
Выберете то, что вам нужно
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: шаг 1, изображение 1 из 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: шаг 1, изображение 2 из 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: шаг 1, изображение 3 из 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    Спросите у FixBot
    Добавить комментарий
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: шаг 2, изображение 1 из 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: шаг 2, изображение 2 из 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: шаг 2, изображение 3 из 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
    Спросите у FixBot
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: шаг 3, изображение 1 из 1
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
    Спросите у FixBot
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: шаг 4, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: шаг 4, изображение 2 из 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
    Спросите у FixBot
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: шаг 5, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: шаг 5, изображение 2 из 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    Спросите у FixBot
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: шаг 6, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: шаг 6, изображение 2 из 2
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
    Спросите у FixBot
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: шаг 7, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: шаг 7, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
    Спросите у FixBot
  8. Google Pixel 3 Back Cover Adhesive Installation: шаг 8, изображение 1 из 3 Google Pixel 3 Back Cover Adhesive Installation: шаг 8, изображение 2 из 3 Google Pixel 3 Back Cover Adhesive Installation: шаг 8, изображение 3 из 3
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
    Спросите у FixBot
  9. Google Pixel 3 Back Cover Adhesive Installation: шаг 9, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation: шаг 9, изображение 2 из 2
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
    Спросите у FixBot
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: шаг 10, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: шаг 10, изображение 2 из 2
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
    Спросите у FixBot
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: шаг 11, изображение 1 из 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: шаг 11, изображение 2 из 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
11 человек успешно провели ремонт по этому руководству.
Chayton Ritter
Участник с: 08/21/20
26 963 Репутация
Автор 105 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 26
За последние 30 дней: 79
За всё время: 4,597
