Google Pixel 3a XL Screen Replacement
Выберете то, что вам нужно
Видеообзор
  1. Google Pixel 3a XL Screen Replacement, Screen: шаг 1, изображение 1 из 3 Google Pixel 3a XL Screen Replacement, Screen: шаг 1, изображение 2 из 3 Google Pixel 3a XL Screen Replacement, Screen: шаг 1, изображение 3 из 3
    • In the following steps, you will be removing the Pixel 3a's screen by cutting through the adhesive holding it in place.
    • For reference, the backside of the screen is shown in this step.
    • Note the narrow clearance between the edge of the screen and the OLED panel under the glass. If you plan to re-use your screen, be sure to follow the instructions below closely.
    • Also note the two different seams between the body of the phone and the screen:
    • The screen seam: where the screen meets the rest of the phone. This is where the screen will separate, and where you should pry.
    • The midframe seam: where the midframe meets the body of the phone. This part is held down by screws. Do not pry at this seam.
    Спросите у FixBot
  2. Google Pixel 3a XL Screen Replacement: шаг 2, изображение 1 из 2 Google Pixel 3a XL Screen Replacement: шаг 2, изображение 2 из 2
    • Place a suction cup on the right edge of the screen, just below the volume button.
    Спросите у FixBot
  3. Google Pixel 3a XL Screen Replacement: шаг 3, изображение 1 из 2 Google Pixel 3a XL Screen Replacement: шаг 3, изображение 2 из 2
    • In the next step you will insert an opening pick between the screen and the plastic body of the phone.
    • If you aren't careful, the plastic opening tool can damage the fragile OLED display panel underneath the glass.
    • If you want to re-use your phone's screen, make sure you insert your pick at a downward angle, as shown in the second photo of this step.
    • This will ensure the opening pick slides under the OLED panel rather than between the glass and the panel, which will ruin the screen.
    Спросите у FixBot
  4. Google Pixel 3a XL Screen Replacement: шаг 4, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 4, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 4, изображение 3 из 3
    • Pull up on the suction cup with a strong, steady force to create a gap between the screen and the phone.
    • Insert your opening pick into the gap.
    • Stop if you feel the tip of the pick hitting against something. The pick may be pressing against the edge of the OLED panel. Angle the pick downward and try again.
    • Once you have inserted an opening pick, you can remove the suction cup.
    Спросите у FixBot
  5. Google Pixel 3a XL Screen Replacement: шаг 5, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 5, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 5, изображение 3 из 3
    • Once the pick is inserted, slide it up and down along the right edge of the phone to cut though the adhesive holding the screen in place.
    Спросите у FixBot
  6. Google Pixel 3a XL Screen Replacement: шаг 6, изображение 1 из 1
    • The adhesive holding the top and bottom edges of the screen in place is thicker, and considerably stronger than the thin strips holding the sides in place.
    • If you plan to reuse your screen, heat up the top edge of the phone with an iOpener, a heat gun, or a hair dryer to loosen the adhesive there before you begin slicing.
    Спросите у FixBot
  7. Google Pixel 3a XL Screen Replacement: шаг 7, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 7, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 7, изображение 3 из 3
    • Carefully slide your opening pick around the upper-right-hand corner of the screen.
    • As shown in step one, the gap between the display and the edge of the glass screen is larger here than on the sides.
    • If you plan to reuse your screen, take special care in this step to either keep your pick deep in the phone under the OLED display (as shown in this step's photos), or only insert it 5 mm into the device to avoid coming into contact with the display under the glass.
    Спросите у FixBot
  8. Google Pixel 3a XL Screen Replacement: шаг 8, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 8, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 8, изображение 3 из 3
    • Continue to separate the adhesive along the top edge of the display.
    • As you slice along this edge, you may bump into the camera and proximity sensor housed here. Don't pry aggressively, just work around them.
    Спросите у FixBot
  9. Google Pixel 3a XL Screen Replacement: шаг 9, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 9, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 9, изображение 3 из 3
    • Slide your opening pick down the left side of the phone to separate the adhesive there.
    Спросите у FixBot
  10. Google Pixel 3a XL Screen Replacement: шаг 10, изображение 1 из 1
    • The adhesive holding the bottom edge of the screen in place is thicker, and considerably stronger than the thin strips holding the sides in place.
    • If you plan to reuse your screen, heat up the bottom edge of the phone with an iOpener, a heat gun, or a hair dryer to loosen the adhesive there before you begin slicing.
    Спросите у FixBot
  11. Google Pixel 3a XL Screen Replacement: шаг 11, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 11, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 11, изображение 3 из 3
    • Slide your opening pick along the bottom edge of the phone to separate the last of the adhesive holding the screen in place.
    • As shown in step one, the gap between the display and the edge of the screen is larger here than on the sides.
    • Don't try to remove the screen yet! It is still connected to the phone by a display cable.
    Спросите у FixBot
  12. Google Pixel 3a XL Screen Replacement: шаг 12, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 12, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 12, изображение 3 из 3
    • Lift the screen by its top edge (where the front-facing camera is) and carefully flip it 180° so that the screen is resting face-down on the phone.
    • If you plan to reuse your screen, be careful not to stress the display cable during this step.
    Спросите у FixBot
  13. Google Pixel 3a XL Screen Replacement: шаг 13, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use tweezers to remove the black sticker covering the display cable bracket.
    • If the sticker is in good condition, you can reuse it during reassembly. Otherwise, you can replace it with a piece of electrical tape.
    Спросите у FixBot
  14. Google Pixel 3a XL Screen Replacement: шаг 14, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove the two 4.3mm T3 screws holding the display cable bracket in place.
    • Due to manufacturing tolerances, a T4 Torx driver may fit better into these T3 screws.
    Спросите у FixBot
  15. Google Pixel 3a XL Screen Replacement: шаг 15, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 15, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 15, изображение 3 из 3
    • Remove the display cable bracket.
    • Pry up on the cable connector with the pointy end of a spudger to disconnect the screen from the phone.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Спросите у FixBot
  16. Google Pixel 3a XL Screen Replacement: шаг 16, изображение 1 из 1
    • Remove the screen from the phone.
    • Compare your new replacement part to the original part. You may need to transfer remaining components such as the speaker grille and the camera bracket to the new part.
    Спросите у FixBot
  17. Google Pixel 3a XL Screen Replacement: шаг 17, изображение 1 из 3 Google Pixel 3a XL Screen Replacement: шаг 17, изображение 2 из 3 Google Pixel 3a XL Screen Replacement: шаг 17, изображение 3 из 3
    Tesa 61395 Tape
    $8.95
    • To reinstall the screen:
    • Use tweezers or an opening tool to remove all traces of adhesive from the phone frame. You can use high concentration isopropyl alcohol to help with the cleaning.
    • If you plan to re-use the screen, be sure to remove all adhesive residue from the screen. Be careful with metal tools to avoid scratching the screen.
    • Apply pre-cut adhesive or double-sided tape (such as Tesa tape) to re-attach the screen to the frame.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Спросите у FixBot
Заключение
If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.
Repair didn’t go as planned? Check out our Google Pixel 3a XL Answers community for troubleshooting help.
33 человек успешно провели ремонт по этому руководству.
Taylor Dixon
Участник с: 06/26/18
72 541 Репутация
Автор 94 руководств
22 Комментарии к руководству
I replaced the display and when it is turned on for the first time, everything works, but when it goes on standby when I switch it on again the touchscreen doesn't work anymore.
rensan - Ответить Поделиться
Rensan that is very weird! I would try resetting the phone, if you can? Sometimes that helps smooth out weird bugs with new Pixel displays.
Taylor Dixon - Ответить Поделиться
I had the exact same issue, it was really weird. Turns out to be a hardware fault in the display, so I returned it and the new display works fine.
Eric Coco - Ответить Поделиться
I'm having the same issue, gonna send the replacement screen in for a replacement. I got it from gadgetfix on eBay.
Arnie Jonassen - Ответить Поделиться
The screens got recalled for a period of time due to this exact issue. i only know about it because my screen had broken, and absolutely no parts supplier online or here locally in Los Angeles could even order the display assembly.
Marie Irwin - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 35
За последние 30 дней: 179
За всё время: 51,838
