How to Back Up a Computer using Clonezilla
Выберете то, что вам нужно
  1. How to Back Up a Computer using Clonezilla, Download Clonezilla Live: шаг 1, изображение 1 из 1
    • Download the latest stable version of Clonezilla Live from NCHC.org:
    • If your computer has an ARM64 or RISC‑V processor (not Intel or AMD), download the latest version from here instead.
    • If you're on Windows, click the file ending in .iso to download it.
    • If you're on MacOS or Linux, click the file ending in .zip to download it.
    • If you're using Safari, go to Preferences → General and uncheck the Open "safe" files after downloading option before downloading.
    Спросите у FixBot
    Добавить комментарий
  2. How to Back Up a Computer using Clonezilla, Connect a flash drive: шаг 2, изображение 1 из 1
    • This flash drive will be erased and have Clonezilla Live written to it. Offload its contents before proceeding.
    • Connect a USB flash drive with at least 1 GB of capacity to an available USB port on the computer.
    • This drive won't be used to back up data to. It's only for Clonezilla Live itself.
    Спросите у FixBot
  3. How to Back Up a Computer using Clonezilla, Create a bootable USB (Windows): шаг 3, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (Windows): шаг 3, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (Windows): шаг 3, изображение 3 из 3
    • Download and install Rufus:
    • For each of the below links, download the file called rufus‑[version].exe. Use the one with arm in the name for ARM computers. Don't use the one with x86 in the name.
    • Windows 8 or newer
    • Windows 7
    • Windows XP or Vista
    • Open Rufus and allow it to make changes and check for updates. Select the flash drive in the Device drop-down menu at the top. Allow Rufus to access the internet and download files if prompted.
    • Click SELECT and select the Clonezilla Live .iso file from the File Explorer window that pops up. It'll name the flash drive based on the file name, but you can give it a more friendly name like CLONEZILLA.
    • Press START and press OK on each prompt. Make sure it writes in ISO image mode, not DD.
    Спросите у FixBot
  4. How to Back Up a Computer using Clonezilla, Create a bootable USB (MacOS): шаг 4, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (MacOS): шаг 4, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (MacOS): шаг 4, изображение 3 из 3
    • Open Disk Utility and select the flash drive from the left sidebar.
    • Click Erase in the Disk Utility window. Enter a name for the volume, like CLONEZILLA. Select MS-DOS (FAT) for the format and Master Boot Record for the scheme. Then click Erase.
    • Open the terminal and type cd ~/Downloads then press Enter.
    • Type unzip [clonezilla_file_name].zip -d /Volumes/CLONEZILLA then press Enter.
    • You can drag the file and disk into the terminal from Finder instead of typing it out.
    Спросите у FixBot
  5. How to Back Up a Computer using Clonezilla, Create a bootable USB (GNU/Linux): шаг 5, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (GNU/Linux): шаг 5, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Create a bootable USB (GNU/Linux): шаг 5, изображение 3 из 3
    • Open your operating system's disk utility (i.e. Disks, GParted, or KDE Partition Manager) and select the flash drive from the Devices list.
    • Look for and select an option like Format Disk or New Partition Table. Format the entire disk as MBR aka ms‑dos.
    • Select the unallocated space and click the button labeled New or + in the toolbar and create a new partition using the FAT32 file system. Give the partition a label like CLONEZILLA.
    • In your file explorer, find the mount location of the new partition. In this example, it's /run/media/nick/CLONEZILLA.
    • Open the terminal (usually called Terminal, Konsole, or opened using Ctrl+Alt+T).
    • Type cd ~/Downloads and press Enter.
    • Type unzip [clonezilla_file_name].zip -d /your/location and press Enter. Substitute /your/location for the path noted earlier in this step.
    Спросите у FixBot
  6. How to Back Up a Computer using Clonezilla, Connect a backup device: шаг 6, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Connect a backup device: шаг 6, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Connect a backup device: шаг 6, изображение 3 из 3
    • Connect a backup device like a USB hard drive (to the fastest available USB port), network drive (via a wired connection), or internal drive (via SATA, SAS, or PCIe) to the computer.
    • Use a USB 3 drive connected to a USB 3 port for faster speeds. USB 3 ports are usually colored blue and/or labeled SuperSpeed (SS).
    • If you connect an internal drive, power off the computer before connecting it and power it back on to proceed.
    Спросите у FixBot
  7. How to Back Up a Computer using Clonezilla, Create backup folder: шаг 7, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Create backup folder: шаг 7, изображение 2 из 2
    • Create a new folder on the drive you want to store your backup on.
    • The new folder's name can't have spaces. If you put it inside other folders, their names can't have spaces either.
    • Note the path of where this folder is located. In this case, it's stored in a folder called Backups on a local drive.
    Спросите у FixBot
  8. How to Back Up a Computer using Clonezilla, Boot into Clonezilla: шаг 8, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Boot into Clonezilla: шаг 8, изображение 2 из 2
    • If you're using a Mac, shut it down and hold the Option key right after pressing the power button. Skip the remainder of this step.
    • If you're using GNU/Linux or Windows 7 or older, restart the computer and repeatedly press F11, F12, or the key specific to your device to access the boot options. Skip the remainder of this step.
    • If you're using Windows 8 or newer, open the Settings app and navigate to Update & Security (or System in Windows 11) → Recovery then select "Restart now" under Advanced startup.
    • You can also hold the Shift key while clicking Restart in the Start Menu.
    Спросите у FixBot
  9. How to Back Up a Computer using Clonezilla: шаг 9, изображение 1 из 3 How to Back Up a Computer using Clonezilla: шаг 9, изображение 2 из 3 How to Back Up a Computer using Clonezilla: шаг 9, изображение 3 из 3
    • If you're using GNU/Linux or Windows 7 or older, select the flash drive from the boot menu. Continue to the next step.
    • If you're using a Mac, select the EFI Boot option to boot from the flash drive. Continue to the next step.
    • In Advanced startup navigate to Use a device → UEFI: USB. This will boot the computer from the flash drive.
    • If the USB option doesn't appear in this menu, select Continue to restart the computer and try again.
    Спросите у FixBot
  10. How to Back Up a Computer using Clonezilla, Start Clonezilla: шаг 10, изображение 1 из 1
    • On higher resolution displays, this menu can be very small. If you can't read the options, use the arrow keys to select the third option (press the down arrow twice) and press Enter.
    • Highlight the option labeled Clonezilla live (VGA with large font & To RAM) and press Enter.
    • If this doesn't work, restart and use the top (VGA 800x600) option instead.
    Спросите у FixBot
  11. How to Back Up a Computer using Clonezilla: шаг 11, изображение 1 из 3 How to Back Up a Computer using Clonezilla: шаг 11, изображение 2 из 3 How to Back Up a Computer using Clonezilla: шаг 11, изображение 3 из 3
    • Highlight your preferred language by pressing the up/down arrow keys and press Enter to select it.
    • You can also use Tab to highlight <Ok> and press Enter.
    • Verify the keyboard layout it detects is accurate and press Enter. If it isn't, select Change and select the correct one.
    • Highlight Start_Clonezilla and press Enter.
    Спросите у FixBot
  12. How to Back Up a Computer using Clonezilla, Select backup type: шаг 12, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Select backup type: шаг 12, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Select backup type: шаг 12, изображение 3 из 3
    • Select device-image.
    • Select local_dev to store the backup on a drive connected to the computer.
    • If you're backing up to a network device, select the applicable option and follow its prompts. When asked for a path, use the one created in this step. Skip the next step.
    • Ensure the device you're backing up to is connected securely. Press Enter to proceed to the next screen.
    Спросите у FixBot
  13. How to Back Up a Computer using Clonezilla, Find the backup drive: шаг 13, изображение 1 из 1
    • Review the storage devices in this list. In our example, the devices shown are:
    • The computer's internal 500GB NVMe drive (the one we want to back up) labeled nvme0n1
    • An external 4TB drive (the one we want to back up to) labeled sda
    • The flash drive containing Clonezilla Live itself labeled sdb
    • Ensure the drive you want to back up to is shown in this list, and note the name of each. Press Ctrl+C to proceed.
    • If the drive isn't shown, disconnect and reconnect it. If it still doesn't show up, ensure it doesn't require additional power or have compatibility issues with this device.
    Спросите у FixBot
  14. How to Back Up a Computer using Clonezilla, Select the backup partition: шаг 14, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Select the backup partition: шаг 14, изображение 2 из 2
    • Select the partition on the drive you want to back up to. Confirm the partition by its size. In this case, it's labeled sda1, since it's the first and only partition on sda, which takes the entire capacity of the drive (3.6T). You'll specify the folder later.
    • Take note of the drive's file system. In this case it's exFAT.
    • Select whether to check and repair the drive's file system. In general, you can skip this.
    • If the file system of the drive is NTFS, it can't be checked.
    Спросите у FixBot
  15. How to Back Up a Computer using Clonezilla, Select the backup folder: шаг 15, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Select the backup folder: шаг 15, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Select the backup folder: шаг 15, изображение 3 из 3
    • Select the folder made in this step. Use the arrow keys to highlight folders, and press Enter to open each one.
    • Only folders without spaces in their name will appear here.
    • If needed, select Parent_directory to leave the current folder (shown above it).
    • Double-check the folder path and folder name. Tab over and select <Done>, then press Enter to proceed.
    Спросите у FixBot
  16. How to Back Up a Computer using Clonezilla, Select backup type: шаг 16, изображение 1 из 1
    • At this point, you may be asked to synchronize the system time:
    • Press Y to synchronize the time, then press Enter to set a time zone.
    • Follow the prompts, beginning with the continent and narrowing down, until you select your time zone.
    • If you're connected to the internet, it might find it automatically.
    • Select savedisk to save the entire disk as an image.
    • If you only want to save certain partitions, choose saveparts instead.
    Спросите у FixBot
  17. How to Back Up a Computer using Clonezilla, Name backup file: шаг 17, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Name backup file: шаг 17, изображение 2 из 2
    • Type a name for the image file. By default, it creates a name based on the time and date. Don't use any spaces or include any of the "reserved image names" listed.
    • Tab over and select <Ok> to proceed.
    Спросите у FixBot
  18. How to Back Up a Computer using Clonezilla, Select drive to back up: шаг 18, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Select drive to back up: шаг 18, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Select drive to back up: шаг 18, изображение 3 из 3
    • Select the drive you want to back up from the list. The drive selected has an asterisk in its check box. If there's multiple options, select the drive by pressing the spacebar (Space).
    • Double-check the selected drive is the one you want to back up, then tab over and select <Ok>.
    Спросите у FixBot
  19. How to Back Up a Computer using Clonezilla, Configure backup: шаг 19, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Configure backup: шаг 19, изображение 2 из 2
    • Select the default compression option.
    • Select whether to check the source file system. If you're backing up MacOS or Windows, skip this. For GNU/Linux systems, skip it unless you believe there's a problem.
    Спросите у FixBot
  20. How to Back Up a Computer using Clonezilla: шаг 20, изображение 1 из 2 How to Back Up a Computer using Clonezilla: шаг 20, изображение 2 из 2
    • Select whether to check if the the saved image is restorable. We recommend checking it.
    • Select whether to encrypt the backup or not. We recommend encrypting it if it contains sensitive data. The passphrase to decrypt it will be set later.
    Спросите у FixBot
  21. How to Back Up a Computer using Clonezilla: шаг 21, изображение 1 из 2 How to Back Up a Computer using Clonezilla: шаг 21, изображение 2 из 2
    • Select whether to copy log files onto the Clonezilla Live USB. Keep this at the default option.
    • Select what to do when the back up process is complete. We recommend the poweroff option to shut the computer down once it's complete.
    • The choose option requires you to manually complete the process, and then select whether to shut down or reboot.
    Спросите у FixBot
  22. How to Back Up a Computer using Clonezilla, Confirm configuration: шаг 22, изображение 1 из 1
    • Clonezilla will show you what partitions are being backed up.
    • Verify what's shown is what you want to back up, then type y and press Enter to continue.
    • If it looks wrong, type n instead, then press Enter and follow the prompts to correct it.
    Спросите у FixBot
  23. How to Back Up a Computer using Clonezilla, Set encryption passphrase: шаг 23, изображение 1 из 2 How to Back Up a Computer using Clonezilla, Set encryption passphrase: шаг 23, изображение 2 из 2
    • If you chose not to encrypt the backup, skip this step.
    • Type the passphrase you want to use to encrypt the backup. This is how you'll decrypt the image to view its contents. Press Enter once you've typed it successfully.
    • The passphrase won't be shown on the screen as you type it. If you make a mistake, the Backspace & Delete keys still work as normal, but shortcuts like Ctrl+A don't.
    • Be careful about keyboard settings like Caps Lock and Num Lock.
    • Type the passphrase again when prompted. Press Enter again to proceed.
    Спросите у FixBot
  24. How to Back Up a Computer using Clonezilla, Complete the backup: шаг 24, изображение 1 из 3 How to Back Up a Computer using Clonezilla, Complete the backup: шаг 24, изображение 2 из 3 How to Back Up a Computer using Clonezilla, Complete the backup: шаг 24, изображение 3 из 3
    • Clonezilla will begin backing up the drive. This process can take a while.
    • If you're using a desktop, we recommend leaving the monitor on and connected for the entire process, since hot‑plugging it may not work.
    • If you chose the shutdown option, you can safely leave the computer alone and let it finish. Congrats, you're done!
    • If you chose the choose option, you can leave the computer temporarily, but need to complete the back up manually:
    • Press Enter to continue to the selection screen when prompted.
    • Select poweroff to turn off the computer or reboot to restart it.
    • Use Rufus or your operating system's disk utility to restore the flash drive back to normal.
    Спросите у FixBot
Заключение
Congratulations! You've successfully backed up a computer.
Didn't go as planned? Try asking our Answers Community for help.
Nick Schultz
Участник с: 03/24/24
57 701 Репутация
Автор 316 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 41
За последние 30 дней: 210
За всё время: 1,270
