How to Reseal an Apple Watch
Выберете то, что вам нужно
  1. How to Reseal an Apple Watch, Clean the watch frame: шаг 1, изображение 1 из 2 How to Reseal an Apple Watch, Clean the watch frame: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Adhesive Cleanup Kit (Set of 12)
    Купить
    • The following steps show how to apply new display adhesive with the display already installed. If you're installing a new screen or removed your screen jump to Step 6 of this guide.
    • Apply a little bit of isopropyl alcohol (>90%) to a cotton swab, or Q-tip (or use a cleaning pad) and gently remove the old adhesive on top of the watch frame.
    • To remove the adhesive on the side with the display cables, gently lay the display on the frame.
    • Avoid straining or tearing the display cables.
  2. How to Reseal an Apple Watch, Clean the rear side of the display: шаг 2, изображение 1 из 2 How to Reseal an Apple Watch, Clean the rear side of the display: шаг 2, изображение 2 из 2
    • Flip the Apple Watch upside down so the display lays flat and lift the watch body.
    • Gently remove the old adhesive on the rear side of the display.
  3. How to Reseal an Apple Watch, Prepare the adhesive: шаг 3, изображение 1 из 1
    • Use a pair of tweezers to carefully remove the replacement adhesive (including the blue protective film) from the backing paper.
  4. How to Reseal an Apple Watch, Apply the new adhesive: шаг 4, изображение 1 из 3 How to Reseal an Apple Watch, Apply the new adhesive: шаг 4, изображение 2 из 3 How to Reseal an Apple Watch, Apply the new adhesive: шаг 4, изображение 3 из 3
    • Hold the replacement adhesive diagonally and thread it over the display.
    • Slightly tilt the display forward to align the adhesive with the frame.
    • Position the replacement adhesive on the watch frame, where the old adhesive was located.
  5. How to Reseal an Apple Watch: шаг 5, изображение 1 из 1
    • Use the pointed end of a spudger to press the replacement adhesive into place.
    • To completely reseal your watch jump straight to step 14.
  6. How to Reseal an Apple Watch, Clean the watch frame: шаг 6, изображение 1 из 2 How to Reseal an Apple Watch, Clean the watch frame: шаг 6, изображение 2 из 2
    Купить
    • To remove the adhesive on the side with the display cables, gently fold the cables down.
    • Don‘t fold the cable sharply and only bend them to avoid cable damage.
  7. How to Reseal an Apple Watch, Clean the rear side of the display: шаг 7, изображение 1 из 2 How to Reseal an Apple Watch, Clean the rear side of the display: шаг 7, изображение 2 из 2
    • If you‘re reusing your old display you need to remove the leftover adhesive from its rear side.
  8. How to Reseal an Apple Watch, Prepare the adhesive: шаг 8, изображение 1 из 1
  9. How to Reseal an Apple Watch, Apply the new adhesive: шаг 9, изображение 1 из 2 How to Reseal an Apple Watch, Apply the new adhesive: шаг 9, изображение 2 из 2
    • Hold the replacement adhesive diagonally and thread it over the display cables.
    • Slightly tilt the display cables forward to align the adhesive with the frame.
  10. How to Reseal an Apple Watch: шаг 10, изображение 1 из 1
  11. How to Reseal an Apple Watch, Reconnect the screen: шаг 11, изображение 1 из 2 How to Reseal an Apple Watch, Reconnect the screen: шаг 11, изображение 2 из 2
    • Lay your display flat on your working surface.
    • Hold the watch body in an upright position and grab the display cables with a pair of tweezers.
    • Before inserting the cables into the connectors, make sure the ZIF connector flaps are in an upright position. Otherwise, you risk damaging the cables.
    • Align the display cables parallel to the ZIF connectors and push them in.
    • No force is needed to push the cables into the connectors. If the cable doesn’t insert easily, it’s probably misaligned and needs to be gently removed and repositioned.
  12. How to Reseal an Apple Watch, Secure the ZIF connectors: шаг 12, изображение 1 из 3 How to Reseal an Apple Watch, Secure the ZIF connectors: шаг 12, изображение 2 из 3 How to Reseal an Apple Watch, Secure the ZIF connectors: шаг 12, изображение 3 из 3
    • Use the pointed end of a spudger and fold down the black flaps on top of the ZIF connectors to secure the cables.
  13. How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: шаг 13, изображение 1 из 3 How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: шаг 13, изображение 2 из 3 How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: шаг 13, изображение 3 из 3
    • Carefully adhere the old heat dissipation stickers to the ZIF connectors on the rear side of the display or apply new heat dissipation stickers where the old ones were located.
  14. How to Reseal an Apple Watch, Remove the protective film: шаг 14, изображение 1 из 3 How to Reseal an Apple Watch, Remove the protective film: шаг 14, изображение 2 из 3 How to Reseal an Apple Watch, Remove the protective film: шаг 14, изображение 3 из 3
    • Use tweezers and a pair of scissors to lift and cut a corner of the protective film.
    • Remove the film from the display adhesive.
  15. How to Reseal an Apple Watch, Reseal the Apple Watch: шаг 15, изображение 1 из 2 How to Reseal an Apple Watch, Reseal the Apple Watch: шаг 15, изображение 2 из 2
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive, apply a heated iOpener to the display. Then apply pressure for a few hours —for example, place your Apple Watch under one or two heavy books overnight.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Заключение
2 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
203 395 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 818 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 12
За последние 7 дней: 95
За последние 30 дней: 430
За всё время: 3,415
