How to Use a Desoldering Pump
Выберете то, что вам нужно
    1. How to Use a Desoldering Pump, Prime the pump: шаг 1, изображение 1 из 2 How to Use a Desoldering Pump, Prime the pump: шаг 1, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      Desoldering Pump
      $3.99
      • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
      • Firmly grasp the desoldering pump with your hand.
      • Depress the plunger until it locks in place.
      • This primes the spring-loaded piston for suction.
      Спросите у FixBot
      Добавить комментарий
    2. How to Use a Desoldering Pump, Activate the pump: шаг 2, изображение 1 из 2 How to Use a Desoldering Pump, Activate the pump: шаг 2, изображение 2 из 2
      • To activate the pump, press the black side button.
      • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
      • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
      Спросите у FixBot
    3. How to Use a Desoldering Pump, Desolder a joint: шаг 3, изображение 1 из 3 How to Use a Desoldering Pump, Desolder a joint: шаг 3, изображение 2 из 3 How to Use a Desoldering Pump, Desolder a joint: шаг 3, изображение 3 из 3
      FixHub Smart Soldering Iron
      $79.95
      • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
      • Prime the desoldering pump by depressing the plunger.
      • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
      • Position the pump's nozzle as close to the molten solder as possible.
      • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
      • Press the side button to activate the pump.
      • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
      Спросите у FixBot
    4. How to Use a Desoldering Pump, Clean the desoldering pump: шаг 4, изображение 1 из 3 How to Use a Desoldering Pump, Clean the desoldering pump: шаг 4, изображение 2 из 3 How to Use a Desoldering Pump, Clean the desoldering pump: шаг 4, изображение 3 из 3
      • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
      • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
      • Grasp the nozzle by its knurled edge.
      • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
      • Remove the nozzle and clean out the pump interior.
      Спросите у FixBot
Заключение
For soldering instructions and tips, follow this guide.
93 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 455 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 37 875 руководств
5 Комментарии к руководству
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - Ответить Поделиться
How does the tip not melt.
Mia Cipollone - Ответить Поделиться
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz - Ответить Поделиться
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - Ответить Поделиться
Realmente me estoy interesando en este rubro y espero çontinuar aprendiendo para que me sirva como terapia
Jaime Rivera - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 51
За последние 7 дней: 386
За последние 30 дней: 1,594
За всё время: 119,699
