Введение
Follow this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech Signature Slim Solar+ keyboard.
Выберете то, что вам нужно
Slide the keyboard's power switch into the OFF position.
Lay your keyboard down with the feet facing up on a clean work surface.
Insert the point of a spudger under an end of the foot.
Slide the spudger underneath the foot and lift until you can grip it with your fingers.
Peel the foot up and remove it.
Remove a replacement foot from its backing and firmly press it into place.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
