MacBook Air 13" Late 2020 Screen Replacement
Выберете то, что вам нужно
    1. MacBook Air 13" Late 2020 Screen Replacement, Remove the screws securing the lower case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Magnetic Project Mat
      $19.95
      • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
      • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
      • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 driver to remove the following screws:
      • Two 7.9 mm screws
      • Two 7.3 mm screws
      • Six 2.6 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: шаг 2, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: шаг 2, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the lower case: шаг 2, изображение 3 из 3
      • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
      Спросите у FixBot
    1. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: шаг 3, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: шаг 3, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement, Disconnect the battery: шаг 3, изображение 3 из 3
      • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
      • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
      • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
      • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
      • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
      Спросите у FixBot
    1. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the antenna cables: шаг 4, изображение 1 из 1
      • Use a T3 Torx driver to remove the 1.4 mm screw securing the antenna cable cover.
      • If your T3 bit feels a bit too loose, you may need to use a T4.
      Спросите у FixBot
    2. MacBook Air 13" Late 2020 Screen Replacement: шаг 5, изображение 1 из 1
      • Remove the antenna cable cover.
      Спросите у FixBot
    3. MacBook Air 13" Late 2020 Screen Replacement: шаг 6, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement: шаг 6, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement: шаг 6, изображение 3 из 3
      • Use a pair of tweezers to grip the antenna connector close to its base.
      • Pull straight up to disconnect the cable.
      • Repeat for the second antenna cable.
      • During reassembly, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets.
      Спросите у FixBot
    4. MacBook Air 13" Late 2020 Screen Replacement, Disconnect the display cable: шаг 7, изображение 1 из 1
      • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector cover.
      Спросите у FixBot
    5. MacBook Air 13" Late 2020 Screen Replacement: шаг 8, изображение 1 из 1
      • Remove the display cable connector cover.
      Спросите у FixBot
    6. MacBook Air 13" Late 2020 Screen Replacement: шаг 9, изображение 1 из 2 MacBook Air 13" Late 2020 Screen Replacement: шаг 9, изображение 2 из 2
      • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    7. MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar screws: шаг 10, изображение 1 из 1
      • Use a T5 Torx driver to remove the six screws securing the antenna bar:
      • Four 7.4 mm silver screws
      • Two 4.7 mm black screws
      Спросите у FixBot
    8. MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: шаг 11, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: шаг 11, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the antenna bar: шаг 11, изображение 3 из 3
      • Insert the pointed end of a spudger into the gap between the antenna bar and display hinge.
      • Pivot the spudger against the hinge to pry up the end of the antenna bar.
      • Note that the antenna bar may be lightly adhered to the frame.
      • Repeat for the other end of the antenna bar.
      Спросите у FixBot
    9. MacBook Air 13" Late 2020 Screen Replacement: шаг 12, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement: шаг 12, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement: шаг 12, изображение 3 из 3
      • Use your fingers to pry the antenna bar straight up and away from the case.
      • The antenna bar is secured with some adhesive and may require some force to dislodge.
      • Thread the antenna board through the opening in the middle of the antenna bar.
      • Be careful to not put any strain on the antenna bar's ribbon cables.
      • Remove the antenna bar.
      Спросите у FixBot
    1. MacBook Air 13" Late 2020 Screen Replacement, Remove four hinge screws: шаг 13, изображение 1 из 2 MacBook Air 13" Late 2020 Screen Replacement, Remove four hinge screws: шаг 13, изображение 2 из 2
      • Use a T8 Torx driver to remove two 5.0 mm screws from each hinge (four screws total).
      • Each hinge has a third central screw, which you should leave in place for now.
      Спросите у FixBot
    2. MacBook Air 13" Late 2020 Screen Replacement, Fully open the MacBook: шаг 14, изображение 1 из 2 MacBook Air 13" Late 2020 Screen Replacement, Fully open the MacBook: шаг 14, изображение 2 из 2
      • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
      Спросите у FixBot
    3. MacBook Air 13" Late 2020 Screen Replacement, Remove the two remaining hinge screws: шаг 15, изображение 1 из 1
      • Lift the MacBook up and place it on its side, with the display facing away from you.
      Спросите у FixBot
    4. MacBook Air 13" Late 2020 Screen Replacement: шаг 16, изображение 1 из 2 MacBook Air 13" Late 2020 Screen Replacement: шаг 16, изображение 2 из 2
      • Use a T8 Torx driver to remove the two remaining 5.0 mm screws securing the display, one from each hinge.
      • Once these screws are removed, the display will no longer be connected to the upper case. Hold both halves steady.
      Спросите у FixBot
    5. MacBook Air 13" Late 2020 Screen Replacement, Remove the display: шаг 17, изображение 1 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the display: шаг 17, изображение 2 из 3 MacBook Air 13" Late 2020 Screen Replacement, Remove the display: шаг 17, изображение 3 из 3
      • Carefully begin to close the display until it's at a ~90 degree angle with the upper case.
      • The hinges should pull out of the case slightly as the display is moved towards the case.
      • Keeping the display at a 90 degree angle with the case, move the display away from the case while holding the case still, so that the hinges slide out the bottom of the case.
      • Remove the display.
      • When you've installed the replacement screen, the MacBook may not boot until you plug in the power supply.
      Спросите у FixBot
Заключение
Once you've completed your repair, your laptop may not power back on until connected to power.
205 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 987 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 40 890 руководств
81 Комментарии к руководству
How to make the True Tone working on the screen from another air?
William Kang - Ответить Поделиться
The screen that your replacing should have true tone built in, it is a part of the display.
h_man08 - Ответить Поделиться
Like iPhones does the display need to be programed to allow true tone to work?
Zuhayr Muse - Ответить Поделиться
Just did the replacement! Was a breeze, just be careful not to over tighten any of the screws past a firm twist. Accident broke the head off a 1.5mm screw using a T3 bit. Didn’t affect the plates ability to cover or apply a firm press downwards, but a unfortunate thing nonetheless.
Caleb Stewart - Ответить Поделиться
After Replacing the display, the new display is dim and the F2 does not brighten the screen. Any resolution to this issue?
Already reset NVRAM and PRAM.
Beto Beto - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 205
За последние 7 дней: 1,643
За последние 30 дней: 6,249
За всё время: 447,592
