MacBook Air 13" Mid 2013 Solid-State Drive Replacement
Выберете то, что вам нужно
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Lower Case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: шаг 2, изображение 1 из 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Спросите у FixBot
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: шаг 3, изображение 2 из 2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      Спросите у FixBot
    1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Solid-State Drive: шаг 4, изображение 1 из 1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      Спросите у FixBot
    2. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: шаг 5, изображение 1 из 2 MacBook Air 13" Mid 2013 Solid-State Drive Replacement: шаг 5, изображение 2 из 2
      • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
      • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      Спросите у FixBot
Заключение
Not sure what to do with your old SSD? Use this external SSD enclosure to turn it into a handy portable external drive!
148 человек успешно провели ремонт по этому руководству.
31 Комментарии к руководству
May I upgrade it to a 256 GB Drive?
Ray - Ответить Поделиться
Where can I find the 256GB SSD to upgrade my 128GB macbook air (mid 2013)?
Josh - Ответить Поделиться
I'm also looking for a 256HB SSD because 128GB isn't enough?
rhattan503 - Ответить Поделиться
At the moment, the only source for this part is on eBay, at UpgradeMonkey shop (UK)
Link : http://www.ebay.fr/itm/NEW-haswell-MacBo...
It's high priced, but I didn't find anywhere else.
Regards.
JMM - Ответить Поделиться
http://www.alelua.com/es/31-almacenamien... SDD for MacBook Air 11" and 13" (Mid 2013/Early 2014) 256 GB Drive
alelua - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 82
За последние 30 дней: 429
За всё время: 376,453
