MacBook Pro 16" 2019 Battery Replacement
Выберете то, что вам нужно
  1. MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: шаг 1, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: шаг 1, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement, Disable Auto Boot: шаг 1, изображение 3 из 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
    Спросите у FixBot
    Добавить комментарий
  2. MacBook Pro 16" 2019 Battery Replacement, Remove lower case screws: шаг 2, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove lower case screws: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 3.7 mm screws
    • Two 7.3 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Спросите у FixBot
  3. MacBook Pro 16" 2019 Battery Replacement, Unclip lower case: шаг 3, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Unclip lower case: шаг 3, изображение 2 из 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
    Спросите у FixBot
  4. MacBook Pro 16" 2019 Battery Replacement: шаг 4, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 4, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 4, изображение 3 из 3
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
    Спросите у FixBot
  5. MacBook Pro 16" 2019 Battery Replacement: шаг 5, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 5, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 5, изображение 3 из 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
    Спросите у FixBot
  6. MacBook Pro 16" 2019 Battery Replacement: шаг 6, изображение 1 из 1
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
    Спросите у FixBot
  7. MacBook Pro 16" 2019 Battery Replacement: шаг 7, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 7, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 7, изображение 3 из 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
    Спросите у FixBot
  8. MacBook Pro 16" 2019 Battery Replacement, Remove lower case: шаг 8, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove lower case: шаг 8, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove lower case: шаг 8, изображение 3 из 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
    Спросите у FixBot
  9. MacBook Pro 16" 2019 Battery Replacement, Remove battery board sticker: шаг 9, изображение 1 из 1
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    Спросите у FixBot
  10. MacBook Pro 16" 2019 Battery Replacement: шаг 10, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 10, изображение 2 из 2
    • Peel back any tape covering the battery board data cable connector.
    Спросите у FixBot
  11. MacBook Pro 16" 2019 Battery Replacement, Disconnect battery board data cable: шаг 11, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect battery board data cable: шаг 11, изображение 2 из 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
    Спросите у FixBot
  12. MacBook Pro 16" 2019 Battery Replacement: шаг 12, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 12, изображение 2 из 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board. Don't pull up.
    Спросите у FixBot
  13. MacBook Pro 16" 2019 Battery Replacement: шаг 13, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 13, изображение 2 из 2
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
    Спросите у FixBot
  14. MacBook Pro 16" 2019 Battery Replacement, Remove battery board data cable: шаг 14, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove battery board data cable: шаг 14, изображение 2 из 2
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to reinstall this cable backwards or upside-down.
    Спросите у FixBot
  15. MacBook Pro 16" 2019 Battery Replacement, Disconnect the battery: шаг 15, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the battery: шаг 15, изображение 2 из 2
    • Use a T5 Torx driver to remove the 6.7 mm pancake screw securing the battery power connector.
    Спросите у FixBot
  16. MacBook Pro 16" 2019 Battery Replacement: шаг 16, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 16, изображение 2 из 2
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
    Спросите у FixBot
  17. MacBook Pro 16" 2019 Battery Replacement, Remove trackpad cable connector bracket: шаг 17, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove trackpad cable connector bracket: шаг 17, изображение 2 из 2
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
    • Remove the bracket.
    Спросите у FixBot
  18. MacBook Pro 16" 2019 Battery Replacement, Disconnect trackpad cable: шаг 18, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect trackpad cable: шаг 18, изображение 2 из 2
    • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
    Спросите у FixBot
  19. MacBook Pro 16" 2019 Battery Replacement: шаг 19, изображение 1 из 1
    • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
    • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
    Спросите у FixBot
  20. MacBook Pro 16" 2019 Battery Replacement: шаг 20, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 20, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 20, изображение 3 из 3
    • Carefully peel the trackpad cable up off the battery, and push it out of the way.
    • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
    Спросите у FixBot
  21. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad assembly screws: шаг 21, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad assembly screws: шаг 21, изображение 2 из 2
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Nine 5.8 mm screws
    • Four 4.9 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
    Спросите у FixBot
  22. MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: шаг 22, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: шаг 22, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove the trackpad: шаг 22, изображение 3 из 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
    Спросите у FixBot
  23. MacBook Pro 16" 2019 Battery Replacement: шаг 23, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 23, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 23, изображение 3 из 3
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
    Спросите у FixBot
  24. MacBook Pro 16" 2019 Battery Replacement, Disconnect the display board: шаг 24, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the display board: шаг 24, изображение 2 из 2
    • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
    • Remove the display board flex cover.
    Спросите у FixBot
  25. MacBook Pro 16" 2019 Battery Replacement: шаг 25, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 25, изображение 2 из 2
    • Using a T3 Torx driver, remove the two 1.6 mm screws securing the bracket for the display board cable connector.
    • Remove the display board cable connector bracket.
    Спросите у FixBot
  26. MacBook Pro 16" 2019 Battery Replacement: шаг 26, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 26, изображение 2 из 2
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
    Спросите у FixBot
  27. MacBook Pro 16" 2019 Battery Replacement, Remove the hinge covers: шаг 27, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove the hinge covers: шаг 27, изображение 2 из 2
    • Use a T3 Torx driver to remove the four 2.0 mm screws from the hinge covers (two screws on each side).
    Спросите у FixBot
  28. MacBook Pro 16" 2019 Battery Replacement: шаг 28, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 28, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 28, изображение 3 из 3
    • Remove the two hinge covers.
    Спросите у FixBot
  29. MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch ID and headphone jack cable connectors: шаг 29, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch ID and headphone jack cable connectors: шаг 29, изображение 2 из 2
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the cover bracket for the Touch ID and headphone jack cable connectors.
    Спросите у FixBot
  30. MacBook Pro 16" 2019 Battery Replacement: шаг 30, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 30, изображение 2 из 2
    • Disconnect the headphone jack flex connector by prying it straight up from the logic board.
    Спросите у FixBot
  31. MacBook Pro 16" 2019 Battery Replacement: шаг 31, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 31, изображение 2 из 2
    • Disconnect the power button and Touch ID sensor by prying its connector straight up from the logic board.
    • These two small connectors have a tendency to get caught underneath the logic board during reinstallation, so double check they're correctly positioned before screwing down the logic board.
    Спросите у FixBot
  32. MacBook Pro 16" 2019 Battery Replacement, Disconnect Touch Bar and lid angle sensor connectors: шаг 32, изображение 1 из 1
    • Using a T3 Torx driver, remove the two 1.5 mm screws securing the cover bracket for the Touch Bar digitizer and lid angle sensor connectors.
    Спросите у FixBot
  33. MacBook Pro 16" 2019 Battery Replacement: шаг 33, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 33, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 33, изображение 3 из 3
    • Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
    Спросите у FixBot
  34. MacBook Pro 16" 2019 Battery Replacement: шаг 34, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 34, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 34, изображение 3 из 3
    • Disconnect the lid angle sensor cable by prying it straight up from the logic board.
    • Disconnect the Touch Bar digitizer cable by prying it straight up from the logic board.
    Спросите у FixBot
  35. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Touch Bar display connector: шаг 35, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the Touch Bar display connector: шаг 35, изображение 2 из 2
    • Use a T3 Torx driver to remove the two 1.9 mm screws securing the bracket for the Touch Bar display cable connector.
    Спросите у FixBot
  36. MacBook Pro 16" 2019 Battery Replacement: шаг 36, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 36, изображение 2 из 2
    • Disconnect the Touch Bar display cable by prying its connector straight up from the logic board.
    Спросите у FixBot
  37. MacBook Pro 16" 2019 Battery Replacement, Disconnect the Thunderbolt cables: шаг 37, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the Thunderbolt cables: шаг 37, изображение 2 из 2
    • Using a T3 Torx Driver:
    • Remove the two 1.3 mm screws securing the Thunderbolt flex cable cover on the left.
    • Remove two more 1.3 mm screws from the Thunderbolt cable cover on the right.
    Спросите у FixBot
  38. MacBook Pro 16" 2019 Battery Replacement: шаг 38, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 38, изображение 2 из 2
    • Remove the cover brackets from both Thunderbolt cable sockets.
    Спросите у FixBot
  39. MacBook Pro 16" 2019 Battery Replacement: шаг 39, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 39, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 39, изображение 3 из 3
    • Use a spudger to disconnect the left-side Thunderbolt flex cable by prying it straight up from the logic board.
    • Pry from the inside edge, nearest the fan.
    • Gently push the flex cable connector off to the side so it doesn't interfere with logic board removal.
    Спросите у FixBot
  40. MacBook Pro 16" 2019 Battery Replacement: шаг 40, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 40, изображение 2 из 2
    • Repeat to disconnect the Thunderbolt flex cable connector on the opposite side.
    • Carefully push the flex cable connector aside so there's clearance for the logic board to come out without snagging.
    Спросите у FixBot
  41. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: шаг 41, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: шаг 41, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard cable: шаг 41, изображение 3 из 3
    • Peel back the tape covering the keyboard cable connector.
    Спросите у FixBot
  42. MacBook Pro 16" 2019 Battery Replacement: шаг 42, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 42, изображение 2 из 2
    • Use a spudger to gently pry straight up on the long locking flap on the ZIF connector for the keyboard cable.
    • Because this ZIF connector is so long, the locking flap is fragile. Be careful and pry up slowly and in the middle so it doesn't snap.
    Спросите у FixBot
  43. MacBook Pro 16" 2019 Battery Replacement: шаг 43, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 43, изображение 2 из 2
    • Disconnect the keyboard cable by sliding it out from its socket on the logic board.
    • Pull in the direction of the cable.
    • If possible, pull on the tape attached to the cable, rather than the cable itself, to reduce the risk of damage.
    Спросите у FixBot
  44. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left speaker: шаг 44, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the left speaker: шаг 44, изображение 2 из 2
    • Peel back any tape covering the left speaker cable connector.
    Спросите у FixBot
  45. MacBook Pro 16" 2019 Battery Replacement: шаг 45, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 45, изображение 2 из 2
    • Open the locking flap on the left speaker cable's ZIF connector by prying it straight up from the logic board.
    Спросите у FixBot
  46. MacBook Pro 16" 2019 Battery Replacement: шаг 46, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 46, изображение 2 из 2
    • Disconnect the left speaker by pulling its cable away from the logic board until it releases from its socket.
    Спросите у FixBot
  47. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right speaker: шаг 47, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the right speaker: шаг 47, изображение 2 из 2
    • Peel back any tape covering the right speaker cable connector.
    Спросите у FixBot
  48. MacBook Pro 16" 2019 Battery Replacement: шаг 48, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 48, изображение 2 из 2
    • Open the locking flap on the right speaker cable's ZIF connector by prying it straight up from the logic board.
    Спросите у FixBot
  49. MacBook Pro 16" 2019 Battery Replacement: шаг 49, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 49, изображение 2 из 2
    • Disconnect the right speaker by pulling its cable away from the logic board until it releases from its socket.
    Спросите у FixBot
  50. MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard backlight: шаг 50, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the keyboard backlight: шаг 50, изображение 2 из 2
    • Peel back any tape covering the first keyboard backlight cable connector.
    Спросите у FixBot
  51. MacBook Pro 16" 2019 Battery Replacement: шаг 51, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 51, изображение 2 из 2
    • Open the locking flap on the keyboard backlight's ZIF connector by prying it straight up from the logic board.
    Спросите у FixBot
  52. MacBook Pro 16" 2019 Battery Replacement: шаг 52, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 52, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 52, изображение 3 из 3
    • Disconnect the keyboard backlight by pulling its cable away from the logic board until it releases from its socket.
    • Move the cable away from its connector so it can more easily clear the logic board during removal.
    Спросите у FixBot
  53. MacBook Pro 16" 2019 Battery Replacement, Disconnect the right fan: шаг 53, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the right fan: шаг 53, изображение 2 из 2
    • Peel back any tape covering the right fan connector.
    Спросите у FixBot
  54. MacBook Pro 16" 2019 Battery Replacement: шаг 54, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 54, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 54, изображение 3 из 3
    • Open the locking flap on the right fan's ZIF connector by prying it straight up from the logic board.
    • Disconnect the right fan by pulling its cable away from the logic board until it releases from its socket.
    Спросите у FixBot
  55. MacBook Pro 16" 2019 Battery Replacement, Disconnect the left fan: шаг 55, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the left fan: шаг 55, изображение 2 из 2
    • Peel back any tape covering the left fan connector.
    Спросите у FixBot
  56. MacBook Pro 16" 2019 Battery Replacement: шаг 56, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 56, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 56, изображение 3 из 3
    • Open the locking flap on the left fan's ZIF connector by prying it straight up from the logic board.
    • Disconnect the left fan by pulling its cable away from the logic board until it releases from its socket.
    Спросите у FixBot
  57. MacBook Pro 16" 2019 Battery Replacement, Disconnect the other keyboard backlight: шаг 57, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the other keyboard backlight: шаг 57, изображение 2 из 2
    • Peel back any tape covering the other keyboard backlight connector.
    Спросите у FixBot
  58. MacBook Pro 16" 2019 Battery Replacement: шаг 58, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 58, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 58, изображение 3 из 3
    Спросите у FixBot
  59. MacBook Pro 16" 2019 Battery Replacement, Disconnect the microphone array: шаг 59, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the microphone array: шаг 59, изображение 2 из 2
    • Peel back any tape covering the microphone array connector.
    Спросите у FixBot
  60. MacBook Pro 16" 2019 Battery Replacement: шаг 60, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 60, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 60, изображение 3 из 3
    • Open the locking flap on the microphone array's ZIF connector by prying it straight up from the logic board.
    • Disconnect the microphone array by pulling its cable away from the logic board until it releases from its socket.
    Спросите у FixBot
  61. MacBook Pro 16" 2019 Battery Replacement, Disconnect the antenna bundle: шаг 61, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Disconnect the antenna bundle: шаг 61, изображение 2 из 2
    • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
    Спросите у FixBot
  62. MacBook Pro 16" 2019 Battery Replacement: шаг 62, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 62, изображение 2 из 2
    • Disconnect all three antenna cables by prying each one straight up from its socket.
    • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
    Спросите у FixBot
  63. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board screws: шаг 63, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement, Remove the logic board screws: шаг 63, изображение 2 из 2
    • Remove all eleven screws securing the logic board assembly:
    • Three 3.3 mm T3 Torx screws
    • Two 3.6 mm T5 Torx screws
    • Four 2.9 mm T5 Torx screws
    • One 4.0 mm T8 Torx screw
    • One 4.0 mm T8 Torx screw (large head)
    • During reassembly, install these screws only loosely. Adjust the board position if necessary until all the connectors line up, and then tighten the screws.
    Спросите у FixBot
  64. MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: шаг 64, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: шаг 64, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement, Remove the logic board: шаг 64, изображение 3 из 3
    • Peel up (but don't remove) the rubber vibration damping strip from the adhesive holding it to the fan.
    • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
    • Repeat for the other adhesive strip on the opposite fan.
    Спросите у FixBot
  65. MacBook Pro 16" 2019 Battery Replacement: шаг 65, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 65, изображение 2 из 2
    • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
    • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
    Спросите у FixBot
  66. MacBook Pro 16" 2019 Battery Replacement: шаг 66, изображение 1 из 1
    • Lifting from the left side, remove the logic board.
    Спросите у FixBot
  67. MacBook Pro 16" 2019 Battery Replacement: шаг 67, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 67, изображение 2 из 2
    • When reinstalling the logic board assembly:
    • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • Verify that no cables get trapped under the board as you install it. Check each of the fifteen marked locations carefully.
    Спросите у FixBot
  68. MacBook Pro 16" 2019 Battery Replacement, Battery: шаг 68, изображение 1 из 1
    • Use a T5 Torx driver to remove the 5.1 mm screw securing the battery board.
    Спросите у FixBot
  69. MacBook Pro 16" 2019 Battery Replacement: шаг 69, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 69, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 69, изображение 3 из 3
    • The liquid adhesive remover provided in your kit can damage the antireflective coating on your MacBook Pro's display, as well as the plastic keyboard keys.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    • Additionally, use painter's tape to seal off the area under the trackpad as best you can. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
    Спросите у FixBot
  70. MacBook Pro 16" 2019 Battery Replacement: шаг 70, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 70, изображение 2 из 2
    • To control the flow of adhesive remover, raise the back edge (hinge side) of your MacBook Pro a few inches using a book or foam block.
    Спросите у FixBot
  71. MacBook Pro 16" 2019 Battery Replacement: шаг 71, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 71, изображение 2 из 2
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
    Спросите у FixBot
  72. MacBook Pro 16" 2019 Battery Replacement: шаг 72, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 72, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 72, изображение 3 из 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    Спросите у FixBot
  73. MacBook Pro 16" 2019 Battery Replacement: шаг 73, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 73, изображение 2 из 2
    • Apply a few drops of adhesive remover underneath the two battery cells on the right, starting along the edge nearest the fan.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    Спросите у FixBot
  74. MacBook Pro 16" 2019 Battery Replacement: шаг 74, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 74, изображение 2 из 2
    • Add a few more drops of adhesive remover in between the two battery cells on the right, so that it flows down underneath the lower battery cell.
    • Wait about two minutes for the liquid adhesive remover to penetrate and weaken the battery adhesive before you proceed to the next step.
    Спросите у FixBot
  75. MacBook Pro 16" 2019 Battery Replacement: шаг 75, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 75, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 75, изображение 3 из 3
    Plastic Cards
    $2.99
    • After a couple minutes, insert one corner of a plastic card underneath the battery, starting from the lower edge of the bottom, right-most cell.
    • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
    • Wiggle the card from side to side and slide it all the way underneath both battery cells.
    • Lift the cells to fully separate the adhesive, but don't try to remove them from your MacBook yet.
    • Leave the plastic card temporarily underneath the cells to prevent the adhesive from re-bonding as you proceed to the next step.
    Спросите у FixBot
  76. MacBook Pro 16" 2019 Battery Replacement: шаг 76, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 76, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 76, изображение 3 из 3
    • Switch to the left side of the MacBook Pro, and repeat the previous step to separate two more battery cells.
    • Leave the second plastic card in place temporarily.
    Спросите у FixBot
  77. MacBook Pro 16" 2019 Battery Replacement: шаг 77, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 77, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 77, изображение 3 из 3
    • Apply a few drops of adhesive remover along the top edges of the two center battery cells.
    • There are openings in the chassis underneath these two cells, which allow the adhesive remover to leak through and may prevent it from fully penetrating.
    • Be mindful of leaks, and apply more adhesive remover along the side edges if needed.
    Спросите у FixBot
  78. MacBook Pro 16" 2019 Battery Replacement: шаг 78, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 78, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 78, изображение 3 из 3
    • After a couple minutes, retrieve your first plastic card and insert one corner under the top edge of one of the center battery cells.
    • Wiggle it from side to side and slide it underneath the battery cell until all the adhesive separates.
    • If you have trouble, don't use excessive force and don't deform the battery. Apply more adhesive remover and try again, or skip down two steps for an alternate method.
    Спросите у FixBot
  79. MacBook Pro 16" 2019 Battery Replacement: шаг 79, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 79, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 79, изображение 3 из 3
    • Retrieve your second plastic card and repeat the previous step to separate the remaining center battery cell.
    Спросите у FixBot
  80. MacBook Pro 16" 2019 Battery Replacement: шаг 80, изображение 1 из 1
    • If you had trouble getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
    • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
    Спросите у FixBot
  81. MacBook Pro 16" 2019 Battery Replacement: шаг 81, изображение 1 из 2 MacBook Pro 16" 2019 Battery Replacement: шаг 81, изображение 2 из 2
    • Lift and remove the battery.
    • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
    • Peel off any large strips of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
    • This can take quite a bit of work, so be patient.
    Спросите у FixBot
  82. MacBook Pro 16" 2019 Battery Replacement: шаг 82, изображение 1 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 82, изображение 2 из 3 MacBook Pro 16" 2019 Battery Replacement: шаг 82, изображение 3 из 3
    Tesa 61395 Tape
    $25.95
    • Double-check the fit and alignment of your new battery before sticking it down.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place.
    • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Ask our Answers community for troubleshooting help.
96 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 644 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 31 535 руководств
60 Комментарии к руководству
Holy cow that is a lot of steps
T J - Ответить Поделиться
Amazing. This is truly thorough, and as soon as this battery starts to fail, will come back here. Nice work documenting a whole assembly line.
antoniogonzalo - Ответить Поделиться
If I want to replace my fans, it looks like I can follow this guide to step 66 and then just figure it out from there? Is there a guide somewhere on this? Thanks!
Matt - Ответить Поделиться
You can do as you wrote for replacing only the fan. Ther’s nothing more to know about it.
Daniele Carminati - Ответить Поделиться
I see that the MacBook Pro 13 logic board remains in place in iFixit battery replacement guide. Is there any reason why in the MacBook Pro 16 the logic board cannot remain in place while removing and reinstalling the battery?
andremengatti - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 187
За последние 7 дней: 1,328
За последние 30 дней: 5,901
За всё время: 264,819
