Microsoft Surface Pro 5 Screen Adhesive Replacement
Выберете то, что вам нужно
    1. Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: шаг 1, изображение 1 из 3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: шаг 1, изображение 2 из 3 Microsoft Surface Pro 5 Screen Adhesive Replacement, Remove the old adhesive: шаг 1, изображение 3 из 3
      • Scrape away all traces of adhesive and debris from the Surface's case and screen.
      • Use high concentration isopropyl alcohol (over 90%) or iFixit adhesive remover and a lint-free cloth to clean the adhesion surfaces on both the case and the screen.
      • If glue or glass remnants are left behind, the new screen will not mount correctly and may be damaged.
      • Lay the adhesive strips out to get an idea of where they go.
      Спросите у FixBot
      Добавить комментарий
    2. Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: шаг 2, изображение 1 из 2 Microsoft Surface Pro 5 Screen Adhesive Replacement, Apply the new adhesive: шаг 2, изображение 2 из 2
      • Peel the white backing off of one adhesive strip, and carefully align it with the edge that matches the cutouts in the strip.
      • Lay the strip down lightly on its matching edge and make sure all the cutouts and edges of the strip line up with the Surface case.
      • Once aligned, use your fingers to press the adhesive strip down against the case.
      • Repeat this procedure for the remaining three adhesive strips.
      Спросите у FixBot
    3. Microsoft Surface Pro 5 Screen Adhesive Replacement, Install the display: шаг 3, изображение 1 из 1
      • Continue reassembly until the cables are reconnected and you're ready to install the screen.
      • If possible, test your screen's functionality before sticking it in place.
      • Remove the clear backing from the adhesive strips.
      • Align the screen with the case and set it on top of the adhesive. Once it's aligned, press down on the edges of the screen to set the adhesive.
      • Apply a few books worth of weight on top of the screen for an hour to help the adhesive bond.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Microsoft Surface Pro 6 answers community for help.
3 человек успешно провели ремонт по этому руководству.
Sam Omiotek
Участник с: 02/25/19
99 781 Репутация
Автор 289 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 29
За последние 30 дней: 143
За всё время: 4,645
