Введение
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Pro 7+ tablet.
Before starting this repair, read through Microsoft's guide on best practices for SSD removal. If your replacement SSD has data on it, make a backup of the drive before installing it.
Выберете то, что вам нужно
Before starting your repair, unplug all cables and fully shut down your Surface Pro.
Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
Remove the SSD door.
Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the SSD.
Use your fingers to pull the SSD out of its socket at a shallow angle.
To reassemble your device, follow these instructions in reverse order. Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Еще один человек закончил это руководство.
