Moto Z Display Assembly Replacement
Выберете то, что вам нужно
  1. Moto Z Display Assembly Replacement, Display Assembly: шаг 1, изображение 1 из 1
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    Спросите у FixBot
    Добавить комментарий
  2. Moto Z Display Assembly Replacement: шаг 2, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 2, изображение 2 из 2
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
    Спросите у FixBot
  3. Moto Z Display Assembly Replacement: шаг 3, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 3, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 3, изображение 3 из 3
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
    Спросите у FixBot
  4. Moto Z Display Assembly Replacement: шаг 4, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 4, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 4, изображение 3 из 3
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
    Спросите у FixBot
  5. Moto Z Display Assembly Replacement: шаг 5, изображение 1 из 1
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
    Спросите у FixBot
  6. Moto Z Display Assembly Replacement: шаг 6, изображение 1 из 1
    Спросите у FixBot
  7. Moto Z Display Assembly Replacement: шаг 7, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 7, изображение 2 из 2
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
    Спросите у FixBot
  8. Moto Z Display Assembly Replacement: шаг 8, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 8, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 8, изображение 3 из 3
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
    Спросите у FixBot
  9. Moto Z Display Assembly Replacement: шаг 9, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
    Спросите у FixBot
  10. Moto Z Display Assembly Replacement: шаг 10, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 10, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 10, изображение 3 из 3
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
    Спросите у FixBot
  11. Moto Z Display Assembly Replacement: шаг 11, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 11, изображение 2 из 2
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
    Спросите у FixBot
  12. Moto Z Display Assembly Replacement: шаг 12, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 12, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 12, изображение 3 из 3
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
    Спросите у FixBot
  13. Moto Z Display Assembly Replacement: шаг 13, изображение 1 из 3 Moto Z Display Assembly Replacement: шаг 13, изображение 2 из 3 Moto Z Display Assembly Replacement: шаг 13, изображение 3 из 3
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
    Спросите у FixBot
  14. Moto Z Display Assembly Replacement: шаг 14, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 14, изображение 2 из 2
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
    Спросите у FixBot
  15. Moto Z Display Assembly Replacement: шаг 15, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 15, изображение 2 из 2
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
    Спросите у FixBot
  16. Moto Z Display Assembly Replacement, Fingerprint Sensor: шаг 16, изображение 1 из 2 Moto Z Display Assembly Replacement, Fingerprint Sensor: шаг 16, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use tweezers to peel off any tape on the home button connector and home button
    Спросите у FixBot
  17. Moto Z Display Assembly Replacement: шаг 17, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 17, изображение 2 из 2
    • Use the point of a spudger to flip up the home button connector's lock.
    Спросите у FixBot
  18. Moto Z Display Assembly Replacement: шаг 18, изображение 1 из 2 Moto Z Display Assembly Replacement: шаг 18, изображение 2 из 2
    • Use tweezers to carefully pull the home button cable straight out of the socket.
    Спросите у FixBot
  19. Moto Z Display Assembly Replacement: шаг 19, изображение 1 из 1
    • Remove the home button.
    Спросите у FixBot
Заключение
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
19 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
343 657 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 27 751 руководств
14 Комментарии к руководству
Do you ship to India?
gsriram72 - Ответить Поделиться
Watch the youtube video it’s a lot better also instead of sending a sticker that connects the phone and the screen they should’ve added adhesive to the new screen.
Jonathan Davila - Ответить Поделиться
Hi Jonathan,
Unlike aftermarket screens that may have adhesive pre-attached, we are an authorized Motorola reseller and sell OEM Motorola parts. In this case, the OEM screen comes without adhesive pre-attached.
Arthur Shi - Ответить Поделиться
For the most part this was a helpful guide, but what about the flash? When following the directions the flash comes off with the screen/digitizer, and it appears to have happened to the author as well. There is no mention or help in reattaching this component or needing to purchase a new flash component prior to beginning the repair. It will be too late for me, but any insight might help others.
Joe Wiltjer - Ответить Поделиться
Hey Joe,
You’re right—depending on the part you order, you may need to transfer the flash lens from your original back cover to the replacement part. This involves prying the original off and sticking it back onto the replacement cover. I’ll add a note to one of the steps.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 16
За последние 30 дней: 71
За всё время: 10,450
