OnePlus Nord Screen Replacement
Выберете то, что вам нужно
    1. OnePlus Nord Screen Replacement, Loosen the rear glass adhesive: шаг 1, изображение 1 из 1
      • Switch off your phone.
      • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
      Спросите у FixBot
      Добавить комментарий
    2. OnePlus Nord Screen Replacement, Create a gap: шаг 2, изображение 1 из 2 OnePlus Nord Screen Replacement, Create a gap: шаг 2, изображение 2 из 2
      • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
      • Pull on the suction cup to create a gap between the rear glass and the frame.
      • Insert an opening pick into the gap.
      Спросите у FixBot
    3. OnePlus Nord Screen Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 OnePlus Nord Screen Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
      • Slide the opening pick along the edge to the bottom right corner.
      • Leave the opening pick in its place to prevent the adhesive from resealing.
      • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
      Спросите у FixBot
    4. OnePlus Nord Screen Replacement: шаг 4, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 4, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 4, изображение 3 из 3
      • Insert a second opening pick under the bottom right corner.
      • Slide the opening pick along the edge to the top right corner.
      • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
      Спросите у FixBot
    5. OnePlus Nord Screen Replacement: шаг 5, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 5, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 5, изображение 3 из 3
      • Insert a third opening pick under the top right corner of the back cover.
      • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    6. OnePlus Nord Screen Replacement: шаг 6, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 6, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 6, изображение 3 из 3
      • Insert a fourth opening pick under the top left corner.
      • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
      Спросите у FixBot
    7. OnePlus Nord Screen Replacement: шаг 7, изображение 1 из 2 OnePlus Nord Screen Replacement: шаг 7, изображение 2 из 2
      • Insert a fifth opening pick under the bottom left corner.
      • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
      Спросите у FixBot
    8. OnePlus Nord Screen Replacement, Remove the back cover: шаг 8, изображение 1 из 1
      • Remove the back cover.
      • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Спросите у FixBot
    1. OnePlus Nord Screen Replacement, Remove the motherboard cover: шаг 9, изображение 1 из 1
      • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
      Спросите у FixBot
    2. OnePlus Nord Screen Replacement: шаг 10, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 10, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 10, изображение 3 из 3
      • Insert the tip of an opening pick under the motherboard cover.
      • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
      • Remove the motherboard cover.
      Спросите у FixBot
    3. OnePlus Nord Screen Replacement, Disconnect the battery: шаг 11, изображение 1 из 2 OnePlus Nord Screen Replacement, Disconnect the battery: шаг 11, изображение 2 из 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Спросите у FixBot
    1. OnePlus Nord Screen Replacement, Remove the daughterboard cover: шаг 12, изображение 1 из 1
      • Use a Phillips #00 screwdriver to remove the seven 3.6 mm-long screws.
      Спросите у FixBot
    2. OnePlus Nord Screen Replacement: шаг 13, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 13, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 13, изображение 3 из 3
      • Insert the tip of an opening pick under the daughterboard cover.
      • Pry up to release the clips holding the daughterboard cover in place.
      • Remove the daughterboard cover.
      Спросите у FixBot
    3. OnePlus Nord Screen Replacement, Disconnect the display connector: шаг 14, изображение 1 из 2 OnePlus Nord Screen Replacement, Disconnect the display connector: шаг 14, изображение 2 из 2
      • Use the flat edge of a spudger to pry up and disconnect the display connector from its daughterboard socket.
      Спросите у FixBot
    4. OnePlus Nord Screen Replacement, Apply a heated iOpener: шаг 15, изображение 1 из 1
      • Apply a Heat an iOpener to the screen for two minutes.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Спросите у FixBot
    5. OnePlus Nord Screen Replacement, Create a gap: шаг 16, изображение 1 из 3 OnePlus Nord Screen Replacement, Create a gap: шаг 16, изображение 2 из 3 OnePlus Nord Screen Replacement, Create a gap: шаг 16, изображение 3 из 3
      • Apply a suction cup to the right edge of the display.
      • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Pull up the suction cup with strong, steady force to create a gap.
      • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
      Спросите у FixBot
    6. OnePlus Nord Screen Replacement, Slice the adhesive: шаг 17, изображение 1 из 3 OnePlus Nord Screen Replacement, Slice the adhesive: шаг 17, изображение 2 из 3 OnePlus Nord Screen Replacement, Slice the adhesive: шаг 17, изображение 3 из 3
      • Insert a second opening pick at the bottom right corner.
      • Slide the opening pick along the edge to the top right corner of your phone.
      • Leave both opening picks in their place to prevent the adhesive from resealing.
      Спросите у FixBot
    7. OnePlus Nord Screen Replacement: шаг 18, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 18, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 18, изображение 3 из 3
      • Insert a third opening pick under the top right corner.
      • Slide the opening pick along the edge to slice the adhesive.
      Спросите у FixBot
    8. OnePlus Nord Screen Replacement: шаг 19, изображение 1 из 3 OnePlus Nord Screen Replacement: шаг 19, изображение 2 из 3 OnePlus Nord Screen Replacement: шаг 19, изображение 3 из 3
      • Slide the opening pick along the edge to cut the adhesive.
      • Leave the opening pick in the bottom left corner so prevent the adhesive from resealing.
      Спросите у FixBot
    9. OnePlus Nord Screen Replacement: шаг 20, изображение 1 из 2 OnePlus Nord Screen Replacement: шаг 20, изображение 2 из 2
      • Slide it along the bottom edge to cut the remaining adhesive.
      • Do not remove the screen completely yet. The display cable is still threaded through the frame.
      Спросите у FixBot
    10. OnePlus Nord Screen Replacement, Remove the display: шаг 21, изображение 1 из 3 OnePlus Nord Screen Replacement, Remove the display: шаг 21, изображение 2 из 3 OnePlus Nord Screen Replacement, Remove the display: шаг 21, изображение 3 из 3
      • Carefully thread the display cable through the frame.
      • Remove the display.
      Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
35 человек успешно провели ремонт по этому руководству.
Adriana Zwink
Участник с: 12/18/19
68 008 Репутация
Автор 167 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 48 770 руководств
15 Комментарии к руководству
So essentially the greater part of the guide is only necessary because OnePlus decided to have the display connector at the back of the phone rather than at the front under the display? What a poor choice repairability-wise on their side, very disappointing! Otherwise great guide.
Nikola Steffanov - Ответить Поделиться
Hi Nikola, yes, this is troublesome! Indeed, you have to make a few moves until it is possible to remove the display. Unfortunately, there is no easier way.
Adriana Zwink - Ответить Поделиться
Yes!, I had the same problem, I spent all day trying different ways to get out like three pesky screws. :( Any tips from anybody? I scoured the internet for a few hours, tried a few different things already but any help would be much appreciated!
Matt Farel - Ответить Поделиться
Why do guides only show you how to take apart screens and not how to apply a new one?
Tee Jay - Ответить Поделиться
Hi @Tee Jay, to reassemble your OnePlus Nord and install the new screen, follow the steps in this guide in reverse order.
Статистика просмотров:
За последние 24 часов: 19
За последние 7 дней: 155
За последние 30 дней: 686
За всё время: 87,464
