Razer Blade 15" (2018) RAM Replacement
Выберете то, что вам нужно
    1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: шаг 1, изображение 1 из 2 Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: шаг 1, изображение 2 из 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Спросите у FixBot
      Добавить комментарий
    1. Razer Blade 15" (2018) RAM Replacement, Unfasten the back cover: шаг 2, изображение 1 из 1
      • Rotate your laptop so the screen hinge is farthest from you.
      • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
      Спросите у FixBot
    2. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
      • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      Спросите у FixBot
    3. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: шаг 4, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: шаг 4, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: шаг 4, изображение 3 из 3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      • Insert your pick up to 10 mm (0.4 in) deep.
      Спросите у FixBot
    4. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: шаг 5, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: шаг 5, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: шаг 5, изображение 3 из 3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      Спросите у FixBot
    5. Razer Blade 15" (2018) RAM Replacement, Free the front edge: шаг 6, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: шаг 6, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: шаг 6, изображение 3 из 3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
      Спросите у FixBot
    6. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: шаг 7, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: шаг 7, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: шаг 7, изображение 3 из 3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
      Спросите у FixBot
    1. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: шаг 8, изображение 1 из 2 Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: шаг 8, изображение 2 из 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
      Спросите у FixBot
    2. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: шаг 9, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: шаг 9, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: шаг 9, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
      Спросите у FixBot
    3. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: шаг 10, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: шаг 10, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: шаг 10, изображение 3 из 3
      • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
      Спросите у FixBot
    1. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: шаг 11, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: шаг 11, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: шаг 11, изображение 3 из 3
      • Two metal arms secure the left and right edges of each RAM stick.
      • Push the lower RAM stick's metal arms outward to disengage them.
      • Remove the RAM stick.
      • During reassembly, insert the RAM stick at a 30-degree angle, then push straight down to engage the metal arms.
      Спросите у FixBot
    2. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: шаг 12, изображение 1 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: шаг 12, изображение 2 из 3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: шаг 12, изображение 3 из 3
      • Disengage the upper RAM stick's arms and remove the RAM.
      Спросите у FixBot
Заключение
Clay Eickemeyer
Участник с: 09/19/22
108 052 Репутация
Автор 471 руководств
Команду
Guide Team Участник Guide Team
Staff
10 членов
Автор 62 128 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 18
За последние 30 дней: 72
За всё время: 817
