Redmi Note 9 Pro Screen Replacement
Выберете то, что вам нужно
  1. Redmi Note 9 Pro Screen Replacement, Heat the rear glass: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
  2. Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Спросите у FixBot
  3. Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 3, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Спросите у FixBot
  4. Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 4, изображение 1 из 3 Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 4, изображение 2 из 3 Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 4, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Спросите у FixBot
  5. Redmi Note 9 Pro Screen Replacement: шаг 5, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement: шаг 5, изображение 2 из 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Спросите у FixBot
  6. Redmi Note 9 Pro Screen Replacement: шаг 6, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement: шаг 6, изображение 2 из 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    Спросите у FixBot
  7. Redmi Note 9 Pro Screen Replacement, Remove the rear glass: шаг 7, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Remove the rear glass: шаг 7, изображение 2 из 2
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    Спросите у FixBot
  8. Redmi Note 9 Pro Screen Replacement, Unfasten the motherboard cover screws: шаг 8, изображение 1 из 1
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
    Спросите у FixBot
  9. Redmi Note 9 Pro Screen Replacement, Pry up the motherboard cover: шаг 9, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Pry up the motherboard cover: шаг 9, изображение 2 из 2
    • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
    • Flip the opening pick sideways to pry up the motherboard cover.
    Спросите у FixBot
  10. Redmi Note 9 Pro Screen Replacement, Remove the motherboard cover: шаг 10, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Remove the motherboard cover: шаг 10, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
    Спросите у FixBot
  11. Redmi Note 9 Pro Screen Replacement, Disconnect the battery cable: шаг 11, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Disconnect the battery cable: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Спросите у FixBot
  12. Redmi Note 9 Pro Screen Replacement, Unfasten the loudspeaker assembly screws: шаг 12, изображение 1 из 1
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
    Спросите у FixBot
  13. Redmi Note 9 Pro Screen Replacement, Pry up the loudspeaker assembly: шаг 13, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Pry up the loudspeaker assembly: шаг 13, изображение 2 из 2
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the battery.
    • Use your opening pick to pry up the loudspeaker assembly.
    Спросите у FixBot
  14. Redmi Note 9 Pro Screen Replacement, Remove the loudspeaker assembly: шаг 14, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Remove the loudspeaker assembly: шаг 14, изображение 2 из 2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    Спросите у FixBot
  15. Redmi Note 9 Pro Screen Replacement, Disconnect the display cable: шаг 15, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Disconnect the display cable: шаг 15, изображение 2 из 2
    • Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
    Спросите у FixBot
  16. Redmi Note 9 Pro Screen Replacement, Loosen the display adhesive: шаг 16, изображение 1 из 1
    • Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
    • The protective adhesive of the Redmi Note 9 Pro is very strong and it's hard to get underneath the display panel in the beginning. It is likely that you have to reapply the iOpener more than once.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Спросите у FixBot
  17. Redmi Note 9 Pro Screen Replacement, Insert an iFlex: шаг 17, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Insert an iFlex: шаг 17, изображение 2 из 2
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an iFlex into the gap between the midframe and the screen.
    Спросите у FixBot
  18. Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 18, изображение 1 из 3 Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 18, изображение 2 из 3 Redmi Note 9 Pro Screen Replacement, Insert an opening pick: шаг 18, изображение 3 из 3
    • Insert an opening pick above the iFlex.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Remove the iFlex.
    Спросите у FixBot
  19. Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 19, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement, Slice the adhesive: шаг 19, изображение 2 из 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    Спросите у FixBot
  20. Redmi Note 9 Pro Screen Replacement: шаг 20, изображение 1 из 3 Redmi Note 9 Pro Screen Replacement: шаг 20, изображение 2 из 3 Redmi Note 9 Pro Screen Replacement: шаг 20, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave it in the top left corner to prevent the adhesive from resealing.
    Спросите у FixBot
  21. Redmi Note 9 Pro Screen Replacement: шаг 21, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement: шаг 21, изображение 2 из 2
    • When you slice near the front facing camera, insert only the tip of the opening pick (about 2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    Спросите у FixBot
  22. Redmi Note 9 Pro Screen Replacement: шаг 22, изображение 1 из 2 Redmi Note 9 Pro Screen Replacement: шаг 22, изображение 2 из 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
    Спросите у FixBot
  23. Redmi Note 9 Pro Screen Replacement, Remove the screen: шаг 23, изображение 1 из 3 Redmi Note 9 Pro Screen Replacement, Remove the screen: шаг 23, изображение 2 из 3 Redmi Note 9 Pro Screen Replacement, Remove the screen: шаг 23, изображение 3 из 3
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
18 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
258 447 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 25 718 руководств
4 Комментарии к руководству
Man sollte vor dem zusammen bauen dringend drauf achten, dass auch Verbindungen die man nicht gelöst hat, wie z.b. Kabelverbindung zum unteren Lautsprecher, wirklich richtig sitzen, sonst darf man nach dem zu kleben feststellen dass der untere Lautsprecher nicht funktioniert 🤣😅😉😡😡😃😃
Tomek Einstein - Ответить Поделиться
Teşekkür ederim faydalı bilgiler
chemical engineer - Ответить Поделиться
Welche Art von Klebstoff wird da verwendet, um das neue Display einzukleben? Und es gibt Screens, bei denen zusätzlich ein Glas mit dabei ist, was sind da die Unterschiede und wie werden die montiert?
huedrant - Ответить Поделиться
HP mati total
Yogi Yogi - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 46
За последние 30 дней: 283
За всё время: 19,356
