iPhone 6s Battery Replacement
Выберете то, что вам нужно
  1. iPhone 6s Battery Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
  2. iPhone 6s Battery Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6s Battery Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6s Battery Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6s Battery Replacement: шаг 3, изображение 1 из 3 iPhone 6s Battery Replacement: шаг 3, изображение 2 из 3 iPhone 6s Battery Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6s Battery Replacement, Opening Procedure: шаг 4, изображение 1 из 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  5. iPhone 6s Battery Replacement: шаг 5, изображение 1 из 1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6s Battery Replacement: шаг 6, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 6, изображение 2 из 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  7. iPhone 6s Battery Replacement: шаг 7, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 7, изображение 2 из 2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  8. iPhone 6s Battery Replacement: шаг 8, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 8, изображение 2 из 2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  9. iPhone 6s Battery Replacement: шаг 9, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 9, изображение 2 из 2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  10. iPhone 6s Battery Replacement: шаг 10, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 10, изображение 2 из 2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  11. iPhone 6s Battery Replacement: шаг 11, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 11, изображение 2 из 2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  12. iPhone 6s Battery Replacement: шаг 12, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 12, изображение 2 из 2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  13. iPhone 6s Battery Replacement: шаг 13, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 13, изображение 2 из 2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  14. iPhone 6s Battery Replacement: шаг 14, изображение 1 из 3 iPhone 6s Battery Replacement: шаг 14, изображение 2 из 3 iPhone 6s Battery Replacement: шаг 14, изображение 3 из 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  15. iPhone 6s Battery Replacement, Battery Connector: шаг 15, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  16. iPhone 6s Battery Replacement: шаг 16, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 16, изображение 2 из 2
    • Remove the battery connector bracket from the iPhone.
  17. iPhone 6s Battery Replacement: шаг 17, изображение 1 из 3 iPhone 6s Battery Replacement: шаг 17, изображение 2 из 3 iPhone 6s Battery Replacement: шаг 17, изображение 3 из 3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  18. iPhone 6s Battery Replacement: шаг 18, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 18, изображение 2 из 2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  19. iPhone 6s Battery Replacement, Unfasten the display cable bracket: шаг 19, изображение 1 из 1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  20. iPhone 6s Battery Replacement: шаг 20, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 20, изображение 2 из 2
    • Remove the display cable bracket.
  21. iPhone 6s Battery Replacement: шаг 21, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 21, изображение 2 из 2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Battery Replacement: шаг 22, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 22, изображение 2 из 2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  23. iPhone 6s Battery Replacement: шаг 23, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 23, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  24. iPhone 6s Battery Replacement: шаг 24, изображение 1 из 1
  25. iPhone 6s Battery Replacement, Battery: шаг 25, изображение 1 из 3 iPhone 6s Battery Replacement, Battery: шаг 25, изображение 2 из 3 iPhone 6s Battery Replacement, Battery: шаг 25, изображение 3 из 3
    • Use tweezers to peel back the tips of the two adhesive strips along the bottom edge of the battery.
    • Use your fingers or blunt tweezers. Be careful when working near the battery; puncturing a lithium-ion battery can release dangerous chemicals and/or cause a fire.
    • Optionally, you can remove the Taptic Engine now. This will give you better access to the adhesive strips.
  26. iPhone 6s Battery Replacement: шаг 26, изображение 1 из 2 iPhone 6s Battery Replacement: шаг 26, изображение 2 из 2
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • To avoid tearing the adhesive strip, be careful not to snag it against the battery or lower components.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  27. iPhone 6s Battery Replacement: шаг 27, изображение 1 из 1
    • Repeat for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip to step 27.
    • If either of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • Do not insert the spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath. Do not pry against the logic board or you may damage the phone.
    • For alternative methods to unstick the battery, continue with the next step below.
  28. iPhone 6s Battery Replacement, Alternative methods to unstick the battery from the case: шаг 28, изображение 1 из 1
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Otherwise, you can apply heat using a heat gun or hair dryer.
    • Then, use a plastic opening tool to gently lift the battery.
    • Overheating the iPhone may ignite the battery.
    • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
    • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
  29. iPhone 6s Battery Replacement, Battery Removal: шаг 29, изображение 1 из 1
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the ribbon cable.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a forced restart after reassembly. This can prevent several issues and simplify troubleshooting.
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
2049 человек успешно провели ремонт по этому руководству.
Evan Noronha
Участник с: 02/05/15
226 270 Репутация
Автор 168 руководств
239 Комментариев
Easy fix. I would recommend getting the adhesive for the screen, as I completely destroyed about half of it when I removed the screen.
cziebell937 - Ответить
the adhesive strip under the battery do not use your hand to pull out, use tweezer and a stick roll it up slowly.......
luke foxy - Ответить
That's a good idea! But on the other hand it looks a bit funny expanding it to about 1 meter ;-) - especially nice, if the owner is there watching …
Michael Gasperl -
That was actually way better than the original suggestion. If you hold the tweezer a little to the side while you roll up the adhesive, it will come off a little bit easier.
KatSeiko -
I found that instead of trying to pull the adhesive strips straight out, that by shifting the strip side to side as I pulled allowed it to “inch out” and break the bond more on a diagonal and snap out in one piece….
James Brewer -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 130
За последние 7 дней: 927
За последние 30 дней: 4,843
За всё время: 1,555,282
