Samsung Galaxy Note10 Rear Camera Module Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy Note10 Rear Camera Module Replacement, Heat the back panel: шаг 1, изображение 1 из 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy Note10 Rear Camera Module Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Спросите у FixBot
  3. Samsung Galaxy Note10 Rear Camera Module Replacement, Begin to slice the adhesive: шаг 3, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Begin to slice the adhesive: шаг 3, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Begin to slice the adhesive: шаг 3, изображение 3 из 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Do not insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  4. Samsung Galaxy Note10 Rear Camera Module Replacement, Slice the left side adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Slice the left side adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Slice the left side adhesive: шаг 4, изображение 3 из 3
    • Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  5. Samsung Galaxy Note10 Rear Camera Module Replacement, Slice the top side adhesive: шаг 5, изображение 1 из 1
    • Prepare an iOpener and apply it to the top edge of the phone for one minute.
    Спросите у FixBot
  6. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 6, изображение 3 из 3
    • Insert a third opening pick into the gap on the top edge of the phone.
    • Slide the opening pick to the top right corner, slicing the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
    Спросите у FixBot
  7. Samsung Galaxy Note10 Rear Camera Module Replacement, Slice the right side adhesive: шаг 7, изображение 1 из 1
    • Prepare an iOpener and apply it to the right edge of the phone for one minute.
    Спросите у FixBot
  8. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 8, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 8, изображение 2 из 2
    • Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
    • The back panel will begin to separate from the phone as you get closer to the bottom edge.
    • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
    Спросите у FixBot
  9. Samsung Galaxy Note10 Rear Camera Module Replacement, Lift off the back panel: шаг 9, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Lift off the back panel: шаг 9, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Lift off the back panel: шаг 9, изображение 3 из 3
    • Lift up and remove the back panel.
    Спросите у FixBot
  10. Samsung Galaxy Note10 Rear Camera Module Replacement, Lift up the metal cover: шаг 10, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
    Спросите у FixBot
  11. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 11, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 11, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 11, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
    Спросите у FixBot
  12. Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the battery: шаг 12, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the battery: шаг 12, изображение 2 из 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
    Спросите у FixBot
  13. Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the wireless charging coil: шаг 13, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the wireless charging coil: шаг 13, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
    Спросите у FixBot
  14. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the wireless charging coil: шаг 14, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the wireless charging coil: шаг 14, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the wireless charging coil: шаг 14, изображение 3 из 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    Спросите у FixBot
  15. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the loudspeaker screws: шаг 15, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
    Спросите у FixBot
  16. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the loudspeaker: шаг 16, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the loudspeaker: шаг 16, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the loudspeaker: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to remove the loudspeaker.
    Спросите у FixBot
  17. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the interconnect cables: шаг 17, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the interconnect cables: шаг 17, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the interconnect cables: шаг 17, изображение 3 из 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
    • Disconnect the secondary interconnect cable from the motherboard.
    Спросите у FixBot
  18. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 18, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 18, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 18, изображение 3 из 3
    • Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
    • Disconnect the secondary interconnect cable from the daughterboard.
    Спросите у FixBot
  19. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 19, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 19, изображение 2 из 2
    • Remove both interconnect cables.
    Спросите у FixBot
  20. Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect motherboard connectors: шаг 20, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect motherboard connectors: шаг 20, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
    Спросите у FixBot
  21. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 21, изображение 3 из 3
    • Use the pointed end of a spudger to disconnect the side button connector from the motherboard.
    • Disconnect the touch layer connector from the motherboard.
    Спросите у FixBot
  22. Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 22, изображение 1 из 2 Samsung Galaxy Note10 Rear Camera Module Replacement: шаг 22, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
    Спросите у FixBot
  23. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the motherboard: шаг 23, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the motherboard: шаг 23, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the motherboard: шаг 23, изображение 3 из 3
    • Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
    • Remove the motherboard.
    Спросите у FixBot
  24. Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the rear camera module: шаг 24, изображение 1 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the rear camera module: шаг 24, изображение 2 из 3 Samsung Galaxy Note10 Rear Camera Module Replacement, Disconnect the rear camera module: шаг 24, изображение 3 из 3
    • Use the pointed end of a spudger to disconnect the top camera connector from the motherboard.
    • Disconnect the bottom camera connector.
    Спросите у FixBot
  25. Samsung Galaxy Note10 Rear Camera Module Replacement, Remove the rear camera module: шаг 25, изображение 1 из 1
    • Remove the rear camera module.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
166 226 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
122 членов
Автор 26 593 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 17
За последние 30 дней: 63
За всё время: 2,336
