Samsung Watch Active Sensor Array Replacement
Выберете то, что вам нужно
    1. Samsung Watch Active Sensor Array Replacement, Turn off the watch: шаг 1, изображение 1 из 2 Samsung Watch Active Sensor Array Replacement, Turn off the watch: шаг 1, изображение 2 из 2
      • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
      • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
      Спросите у FixBot
      Добавить комментарий
    2. Samsung Watch Active Sensor Array Replacement, Remove the rear screws: шаг 2, изображение 1 из 1
      • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
      Спросите у FixBot
    3. Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: шаг 3, изображение 1 из 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: шаг 3, изображение 2 из 3 Samsung Watch Active Sensor Array Replacement, Separate the back cover from the housing: шаг 3, изображение 3 из 3
      • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
      • Push the tip of the opening tool into the gap to separate the back cover from the housing.
      • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
      Спросите у FixBot
    4. Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: шаг 4, изображение 1 из 2 Samsung Watch Active Sensor Array Replacement, Disconnect the sensor array: шаг 4, изображение 2 из 2
      • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
      • Use a spudger to disconnect the sensor array from the motherboard.
      Спросите у FixBot
    5. Samsung Watch Active Sensor Array Replacement, Remove the back cover: шаг 5, изображение 1 из 1
      • Remove the back cover.
      Спросите у FixBot
    1. Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: шаг 6, изображение 1 из 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: шаг 6, изображение 2 из 3 Samsung Watch Active Sensor Array Replacement, Loosen the sensor array: шаг 6, изображение 3 из 3
      • Use an opening pick and slide it underneath the sensor array which is slightly glued in place.
      • Carefully twist the opening pick to separate the sensor array from the back cover.
      Спросите у FixBot
    2. Samsung Watch Active Sensor Array Replacement, Remove the sensor array: шаг 7, изображение 1 из 2 Samsung Watch Active Sensor Array Replacement, Remove the sensor array: шаг 7, изображение 2 из 2
      • Remove the sensor array from the back cover.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Tobias Isakeit
Участник с: 03/31/14
134 915 Репутация
Автор 189 руководств
Команда
Tobias Isakeit - Repairability Engineer Участник Tobias Isakeit - Repairability Engineer
Business
1 член
Автор 1 596 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 18
За последние 30 дней: 67
За всё время: 4,941
