Sony Xperia Z1s Battery Replacement
Выберете то, что вам нужно
  1. Sony Xperia Z1s Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
    Спросите у FixBot
    Добавить комментарий
  2. Sony Xperia Z1s Battery Replacement: шаг 2, изображение 1 из 1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
    Спросите у FixBot
  3. Sony Xperia Z1s Battery Replacement: шаг 3, изображение 1 из 1
    • Use the opening pick to pry off the battery flex cable.
    Спросите у FixBot
  4. Sony Xperia Z1s Battery Replacement: шаг 4, изображение 1 из 1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
    Спросите у FixBot
  5. Sony Xperia Z1s Battery Replacement: шаг 5, изображение 1 из 1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
    Спросите у FixBot
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
Еще один человек закончил это руководство.
Matthew Klengson
Участник с: 09/30/21
324 Репутация
Автор 2 руководств
Команда
Clemson, Team 4-4, Hunter Fall 2021 Участник Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 членов
Автор 5 руководств
1 Комментарий к руководству
Step 1 - The gap is too small to simply use the pick. The suction tool also did not provide a big enough gap to get the pick in. In order to get the pick in I had to heat up the back and use the suction cup in order to get the pick. Then moved the pick around the perimeter to pull of the back. The battery was attached to the back with two glue strips. I unpluged the battery ribbon cable and got the glue off using the two pull tabs that were attached to the glue.
The rest of the steps were non existent in my case. Hope this reply helps
MrKoszmaro - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 33
За всё время: 662
