Steam Deck Left Touchpad Replacement
Выберете то, что вам нужно
  1. Steam Deck Left Touchpad Replacement, Prepare your device: шаг 1, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Prepare your device: шаг 1, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Prepare your device: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four 9.5 mm screws
    • Four 5.8 mm screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  2. Steam Deck Left Touchpad Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  3. Steam Deck Left Touchpad Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  4. Steam Deck Left Touchpad Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  5. Steam Deck Left Touchpad Replacement, Remove the shield screws: шаг 6, изображение 1 из 1
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
  6. Steam Deck Left Touchpad Replacement, Remove the shield: шаг 7, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the shield: шаг 7, изображение 2 из 2
  7. Steam Deck Left Touchpad Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  8. Steam Deck Left Touchpad Replacement, Unclip the left trigger: шаг 9, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Unclip the left trigger: шаг 9, изображение 2 из 2
    • The left trigger will be on your righthand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
  9. Steam Deck Left Touchpad Replacement, Remove the left trigger: шаг 10, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the left trigger: шаг 10, изображение 2 из 2
    • Remove the left trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
  10. Steam Deck Left Touchpad Replacement, Remove the trigger bracket screws: шаг 11, изображение 1 из 1
    • Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
  11. Steam Deck Left Touchpad Replacement, Remove the trigger bracket: шаг 12, изображение 1 из 1
    • Remove the left trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
  12. Steam Deck Left Touchpad Replacement, Disconnect the left thumbstick: шаг 13, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Disconnect the left thumbstick: шаг 13, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Disconnect the left thumbstick: шаг 13, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  13. Steam Deck Left Touchpad Replacement, Remove the thumbstick screws: шаг 14, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the thumbstick screws: шаг 14, изображение 2 из 2
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  14. Steam Deck Left Touchpad Replacement, Remove the left thumbstick: шаг 15, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the left thumbstick: шаг 15, изображение 2 из 2
    • Remove the left thumbstick.
  15. Steam Deck Left Touchpad Replacement, Disconnect the interconnect cable: шаг 16, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Disconnect the interconnect cable: шаг 16, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Disconnect the interconnect cable: шаг 16, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
  16. Steam Deck Left Touchpad Replacement, Disconnect the remaining button board cables: шаг 17, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Disconnect the remaining button board cables: шаг 17, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Disconnect the remaining button board cables: шаг 17, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the D-pad cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
  17. Steam Deck Left Touchpad Replacement, Disconnect the left haptics: шаг 18, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Disconnect the left haptics: шаг 18, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Disconnect the left haptics: шаг 18, изображение 3 из 3
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
  18. Steam Deck Left Touchpad Replacement, Remove the button board screws: шаг 19, изображение 1 из 1
    • Use a Phillips driver to disconnect the four screws securing the left button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
  19. Steam Deck Left Touchpad Replacement, Remove the button board: шаг 20, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the button board: шаг 20, изображение 2 из 2
    • Remove the left button board.
    • Keep track of the Steam button and its membrane, as once the left button board is removed, they're no longer secured in place.
  20. Steam Deck Left Touchpad Replacement, Remove the touchpad board screws: шаг 21, изображение 1 из 1
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad board.
  21. Steam Deck Left Touchpad Replacement, Remove the touchpad board: шаг 22, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the touchpad board: шаг 22, изображение 2 из 2
    • Remove the touchpad board.
  22. Steam Deck Left Touchpad Replacement, Remove the touchpad screws: шаг 23, изображение 1 из 2 Steam Deck Left Touchpad Replacement, Remove the touchpad screws: шаг 23, изображение 2 из 2
    • Use a Phillips driver to remove the four 4.7 mm screws securing the touchpad.
    • You may need to temporarily remove the Steam button membrane for easier access to the bottom left screw.
    • Each of the touchpad's four mounting corners have a locating peg. During reassembly, ensure each is properly seated.
  23. Steam Deck Left Touchpad Replacement, Remove the left touchpad: шаг 24, изображение 1 из 3 Steam Deck Left Touchpad Replacement, Remove the left touchpad: шаг 24, изображение 2 из 3 Steam Deck Left Touchpad Replacement, Remove the left touchpad: шаг 24, изображение 3 из 3
    • The touchpad's springs are very delicate and are precisely positioned. If bent, the touchpad may rattle or not work as intended.
    • From the front of the Steam Deck, use your finger to push the left touchpad partway through the front shell to unseat it.
    • Lift the touchpad out from underneath the overhanging section of the midframe.
    • Remove the touchpad.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Carsten Frauenheim
Участник с: 03/10/20
92 225 Репутация
Автор 337 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 709 руководств
5 Комментариев
Are there any leads on where to get replacement touch pads?
Mitch B - Ответить
I, too, would like to know where we can obtain replacement touchpads.
informal.mak - Ответить
Yeah where are the replacement touch pads? My left pad is stuck and clicky.
Jeff Salata - Ответить
Where i can get touch pad?
xNer0TM - Ответить
I want to purchase replacement parts. where to buy
ccola id - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 31
За последние 7 дней: 209
За последние 30 дней: 892
За всё время: 10,874
