Steam Deck Steam Button Replacement
Выберете то, что вам нужно
  1. Steam Deck Steam Button Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 1 из 3 Steam Deck Steam Button Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 2 из 3 Steam Deck Steam Button Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
    Спросите у FixBot
    Добавить комментарий
  2. Steam Deck Steam Button Replacement, Remove the back cover screws: шаг 2, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
    Спросите у FixBot
  3. Steam Deck Steam Button Replacement, Unclip the back cover: шаг 3, изображение 1 из 2 Steam Deck Steam Button Replacement, Unclip the back cover: шаг 3, изображение 2 из 2
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
    Спросите у FixBot
  4. Steam Deck Steam Button Replacement, Remove the back cover: шаг 4, изображение 1 из 3 Steam Deck Steam Button Replacement, Remove the back cover: шаг 4, изображение 2 из 3 Steam Deck Steam Button Replacement, Remove the back cover: шаг 4, изображение 3 из 3
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
    Спросите у FixBot
  5. Steam Deck Steam Button Replacement, Uncover the hidden shield screw: шаг 5, изображение 1 из 2 Steam Deck Steam Button Replacement, Uncover the hidden shield screw: шаг 5, изображение 2 из 2
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
    Спросите у FixBot
  6. Steam Deck Steam Button Replacement, Remove the shield screws: шаг 6, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the shield screws: шаг 6, изображение 2 из 2
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
    Спросите у FixBot
  7. Steam Deck Steam Button Replacement, Remove the shield: шаг 7, изображение 1 из 3 Steam Deck Steam Button Replacement, Remove the shield: шаг 7, изображение 2 из 3 Steam Deck Steam Button Replacement, Remove the shield: шаг 7, изображение 3 из 3
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
    Спросите у FixBot
  8. Steam Deck Steam Button Replacement, Disconnect the battery: шаг 8, изображение 1 из 3 Steam Deck Steam Button Replacement, Disconnect the battery: шаг 8, изображение 2 из 3 Steam Deck Steam Button Replacement, Disconnect the battery: шаг 8, изображение 3 из 3
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
    Спросите у FixBot
  9. Steam Deck Steam Button Replacement, Unclip the left trigger: шаг 9, изображение 1 из 2 Steam Deck Steam Button Replacement, Unclip the left trigger: шаг 9, изображение 2 из 2
    • The left trigger will be on your right-hand side when working on the Steam Deck, as it's laying upside down.
    • The Steam Deck's triggers clip into place on two pegs on the trigger bracket, which doubles as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the outermost peg first. Once in place, push down on the trigger to latch the innermost peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    Спросите у FixBot
  10. Steam Deck Steam Button Replacement, Remove the left trigger: шаг 10, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the left trigger: шаг 10, изображение 2 из 2
    • Remove the left trigger.
    • Take care to not lose the trigger spring. It press-fits onto a peg on the trigger's underside.
    Спросите у FixBot
  11. Steam Deck Steam Button Replacement, Remove the trigger bracket screws: шаг 11, изображение 1 из 1
    • Use a Phillips driver to remove the three 5.2 mm screws securing the left trigger bracket.
    Спросите у FixBot
  12. Steam Deck Steam Button Replacement, Remove the trigger bracket: шаг 12, изображение 1 из 1
    • Remove the left trigger bracket.
    • Replacement triggers require calibration to work as expected. To calibrate new triggers, follow this calibration guide.
    Спросите у FixBot
  13. Steam Deck Steam Button Replacement, Disconnect the left thumbstick: шаг 13, изображение 1 из 3 Steam Deck Steam Button Replacement, Disconnect the left thumbstick: шаг 13, изображение 2 из 3 Steam Deck Steam Button Replacement, Disconnect the left thumbstick: шаг 13, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
    Спросите у FixBot
  14. Steam Deck Steam Button Replacement, Remove the thumbstick screws: шаг 14, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the thumbstick screws: шаг 14, изображение 2 из 2
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
    Спросите у FixBot
  15. Steam Deck Steam Button Replacement, Remove the left thumbstick: шаг 15, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the left thumbstick: шаг 15, изображение 2 из 2
    • Remove the left thumbstick.
    Спросите у FixBot
  16. Steam Deck Steam Button Replacement, Disconnect the interconnect cable: шаг 16, изображение 1 из 3 Steam Deck Steam Button Replacement, Disconnect the interconnect cable: шаг 16, изображение 2 из 3 Steam Deck Steam Button Replacement, Disconnect the interconnect cable: шаг 16, изображение 3 из 3
    • Use the pointed end of a spudger to lift up the small locking flap on the button board interconnect cable's ZIF connector.
    Спросите у FixBot
  17. Steam Deck Steam Button Replacement, Disconnect the remaining button board cables: шаг 17, изображение 1 из 3 Steam Deck Steam Button Replacement, Disconnect the remaining button board cables: шаг 17, изображение 2 из 3 Steam Deck Steam Button Replacement, Disconnect the remaining button board cables: шаг 17, изображение 3 из 3
    • If any connectors are covered with tape, use a pair of tweezers to remove it.
    • Use the pointed end of a spudger to lift up the small locking flaps on the rest of the button board ZIF connectors. Use a pair of tweezers to slide the cables out of their connectors:
    • Disconnect the D-pad cable.
    • Disconnect the touchpad board cable.
    • Disconnect the touchpad cable.
    Спросите у FixBot
  18. Steam Deck Steam Button Replacement, Disconnect the left haptics: шаг 18, изображение 1 из 3 Steam Deck Steam Button Replacement, Disconnect the left haptics: шаг 18, изображение 2 из 3 Steam Deck Steam Button Replacement, Disconnect the left haptics: шаг 18, изображение 3 из 3
    • Exercise caution when lifting this connector—pry up on the connector itself, not its housing.
    • Use the pointed end of a spudger to lift up on the haptics cable to disconnect it.
    • Alternatively, you can leave the haptics connected to the button board and flip the board up and over the edge of the shell and out of the way.
    Спросите у FixBot
  19. Steam Deck Steam Button Replacement, Remove the button board screws: шаг 19, изображение 1 из 1
    • Use a Phillips driver to disconnect the four screws securing the left button board:
    • Three 5.2 mm screws
    • One 3.9 mm screw
    Спросите у FixBot
  20. Steam Deck Steam Button Replacement, Remove the button board: шаг 20, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the button board: шаг 20, изображение 2 из 2
    • Remove the left button board.
    • Keep track of the Steam button and its membrane, as once the left button board is removed, they're no longer secured in place.
    Спросите у FixBot
  21. Steam Deck Steam Button Replacement, Remove the Steam button membrane: шаг 21, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the Steam button membrane: шаг 21, изображение 2 из 2
    • Use a pair of tweezers to remove the Steam button membrane.
    Спросите у FixBot
  22. Steam Deck Steam Button Replacement, Remove the Steam button: шаг 22, изображение 1 из 2 Steam Deck Steam Button Replacement, Remove the Steam button: шаг 22, изображение 2 из 2
    • Use a pair of tweezers to remove the Steam button.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
2 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
166 897 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 27 603 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 18
За последние 7 дней: 116
За последние 30 дней: 714
За всё время: 28,872
