Steam Deck OLED Fan Replacement
Выберете то, что вам нужно
  1. Steam Deck OLED Fan Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 1 из 3 Steam Deck OLED Fan Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 2 из 3 Steam Deck OLED Fan Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Fan Replacement, Remove the back cover screws: шаг 2, изображение 1 из 2 Steam Deck OLED Fan Replacement, Remove the back cover screws: шаг 2, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    Купить
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Fan Replacement, Unclip a handle: шаг 3, изображение 1 из 3 Steam Deck OLED Fan Replacement, Unclip a handle: шаг 3, изображение 2 из 3 Steam Deck OLED Fan Replacement, Unclip a handle: шаг 3, изображение 3 из 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Fan Replacement, Unclip the top and bottom edges: шаг 4, изображение 1 из 3 Steam Deck OLED Fan Replacement, Unclip the top and bottom edges: шаг 4, изображение 2 из 3 Steam Deck OLED Fan Replacement, Unclip the top and bottom edges: шаг 4, изображение 3 из 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Fan Replacement, Remove the back cover: шаг 5, изображение 1 из 3 Steam Deck OLED Fan Replacement, Remove the back cover: шаг 5, изображение 2 из 3 Steam Deck OLED Fan Replacement, Remove the back cover: шаг 5, изображение 3 из 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Fan Replacement, Disconnect the battery: шаг 6, изображение 1 из 3 Steam Deck OLED Fan Replacement, Disconnect the battery: шаг 6, изображение 2 из 3 Steam Deck OLED Fan Replacement, Disconnect the battery: шаг 6, изображение 3 из 3
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED Fan Replacement, Disconnect the right button board: шаг 7, изображение 1 из 3 Steam Deck OLED Fan Replacement, Disconnect the right button board: шаг 7, изображение 2 из 3 Steam Deck OLED Fan Replacement, Disconnect the right button board: шаг 7, изображение 3 из 3
    Купить
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    • The pull tab may be labelled C‑R.
  8. Steam Deck OLED Fan Replacement, Separate the cable adhesive: шаг 8, изображение 1 из 3 Steam Deck OLED Fan Replacement, Separate the cable adhesive: шаг 8, изображение 2 из 3 Steam Deck OLED Fan Replacement, Separate the cable adhesive: шаг 8, изображение 3 из 3
    • The interconnect cable is adhered to the motherboard shield.
    • Insert an opening pick between the interconnect cable and the motherboard shield.
    • Be careful not to crease or tear the cable.
    • If you're having trouble inserting a pick, lightly heat the cable using an iOpener or a hair dryer.
    • Slide your pick along the shield to separate the cable.
  9. Steam Deck OLED Fan Replacement, Move the interconnect cable: шаг 9, изображение 1 из 3 Steam Deck OLED Fan Replacement, Move the interconnect cable: шаг 9, изображение 2 из 3 Steam Deck OLED Fan Replacement, Move the interconnect cable: шаг 9, изображение 3 из 3
    • During the rest of the repair, it may be helpful to move the interconnect cable over the battery and out of the way of the motherboard shield.
    • Be careful not to crease or strain the cable, as it's still adhered to the battery.
    • Tape the cable in place away from the motherboard shield.
  10. Steam Deck OLED Fan Replacement, Remove the motherboard shield screws: шаг 10, изображение 1 из 2 Steam Deck OLED Fan Replacement, Remove the motherboard shield screws: шаг 10, изображение 2 из 2
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the top left and bottom left corners of the motherboard shield.
  11. Steam Deck OLED Fan Replacement, Remove the motherboard shield: шаг 11, изображение 1 из 3 Steam Deck OLED Fan Replacement, Remove the motherboard shield: шаг 11, изображение 2 из 3 Steam Deck OLED Fan Replacement, Remove the motherboard shield: шаг 11, изображение 3 из 3
    • If the speaker cable is taped to the bottom edge of the motherboard shield, gently peel it off.
    • Remove the motherboard shield.
  12. Steam Deck OLED Fan Replacement, Reassembly instructions: шаг 12, изображение 1 из 3 Steam Deck OLED Fan Replacement, Reassembly instructions: шаг 12, изображение 2 из 3 Steam Deck OLED Fan Replacement, Reassembly instructions: шаг 12, изображение 3 из 3
    • During reassembly, use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
  13. Steam Deck OLED Fan Replacement, Soften the sticker adhesive: шаг 13, изображение 1 из 2 Steam Deck OLED Fan Replacement, Soften the sticker adhesive: шаг 13, изображение 2 из 2
  14. Steam Deck OLED Fan Replacement, Remove the heat sink sticker: шаг 14, изображение 1 из 3 Steam Deck OLED Fan Replacement, Remove the heat sink sticker: шаг 14, изображение 2 из 3 Steam Deck OLED Fan Replacement, Remove the heat sink sticker: шаг 14, изображение 3 из 3
    • Try not to tear the heat sink sticker, as you'll reuse it during reassembly.
    • Slide the tip of an opening pick under one edge of the heat sink sticker.
    • Peel the sticker up until you can grab it with your fingers.
    • Gently remove the sticker from the heat sink and fan.
    • During reassembly, place the sticker back in its original location. The residual adhesive should stick well.
    • If the residual adhesive isn't sticky anymore, tape the outside edges of the sticker to the heat sink and fan with small strips of tape.
  15. Steam Deck OLED Fan Replacement, Disconnect the fan: шаг 15, изображение 1 из 3 Steam Deck OLED Fan Replacement, Disconnect the fan: шаг 15, изображение 2 из 3 Steam Deck OLED Fan Replacement, Disconnect the fan: шаг 15, изображение 3 из 3
    Купить
    • Use blunt nose tweezers to grip the edges of the fan connector and walk it side-to-side out of its socket to disconnect it.
    • Don't pull on the cables—only pull on the connector body.
    • During reassembly, insert the connector gently. Make sure the exposed colored wires within the connector face away from the fan.
    • Don't force the connector into the socket, as you might damage the fragile internal pins.
  16. Steam Deck OLED Fan Replacement, Remove the fan screws: шаг 16, изображение 1 из 1
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the fan.
    • Don't worry—you already removed the top two fan screws earlier in disassembly. They double as two of the back cover screws.
  17. Steam Deck OLED Fan Replacement, Remove the fan: шаг 17, изображение 1 из 3 Steam Deck OLED Fan Replacement, Remove the fan: шаг 17, изображение 2 из 3 Steam Deck OLED Fan Replacement, Remove the fan: шаг 17, изображение 3 из 3
    • Lift the top edge of the fan from its recess in the midframe.
    • Remove the fan.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Clay Eickemeyer
Участник с: 09/19/22
67 432 Репутация
Автор 453 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 48
За последние 30 дней: 257
За всё время: 767
