Steam Deck OLED Front Shell Replacement
Выберете то, что вам нужно
  1. Steam Deck OLED Front Shell Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Prepare your Steam Deck for disassembly: шаг 1, изображение 3 из 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
    Спросите у FixBot
    Добавить комментарий
  2. Steam Deck OLED Front Shell Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. Steam Deck OLED Front Shell Replacement, Heat the top edge screen adhesive: шаг 3, изображение 1 из 1
    • Prepare an iOpener and apply it to the top edge of the screen for one minute.
    • You may also use a hair dryer or heat gun, but be careful not to overheat the device, as the screen, battery, and plastic frame are all susceptible to heat damage.
    Спросите у FixBot
  4. Steam Deck OLED Front Shell Replacement, Apply a suction handle: шаг 4, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Apply a suction handle: шаг 4, изображение 2 из 2
    • Apply a suction handle to the top left corner of the screen, as close to the top edge as possible.
    • If your display is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
    Спросите у FixBot
  5. Steam Deck OLED Front Shell Replacement, Insert an opening pick: шаг 5, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Insert an opening pick: шаг 5, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Insert an opening pick: шаг 5, изображение 3 из 3
    • Pull up on the suction handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the screen panel, ambient light sensor, or sensor cable.
    Спросите у FixBot
  6. Steam Deck OLED Front Shell Replacement, Remove the suction handle: шаг 6, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the suction handle: шаг 6, изображение 2 из 2
    • Pull up on the nub on the back of the suction handle to remove it from the screen.
    Спросите у FixBot
  7. Steam Deck OLED Front Shell Replacement, Screen information: шаг 7, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Screen information: шаг 7, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Screen information: шаг 7, изображение 3 из 3
    • As you slice through the adhesive securing the screen, note the following:
    • Along the top and bottom edges, don't insert your pick deeper than 3 mm (~1/8 of an inch) to avoid damaging the sensors, sensors cable, or screen cable.
    • Along the left and right edges, don't insert your pick deeper than 5 mm (~1/5 of an inch) to avoid damaging the screen panel.
    Спросите у FixBot
  8. Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 8, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 8, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 8, изображение 3 из 3
    • Rotate the pick so its flat edge is between the screen and frame.
    • Leave this pick inserted to prevent the adhesive from resealing.
    Спросите у FixBot
  9. Steam Deck OLED Front Shell Replacement, Separate the top edge adhesive: шаг 9, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Separate the top edge adhesive: шаг 9, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Separate the top edge adhesive: шаг 9, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the top edge.
    • Insert another pick in the top left corner.
    • Slide the pick toward the power button to separate the adhesive securing the top edge of the screen.
    Спросите у FixBot
  10. Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 10, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 10, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Reposition the pick: шаг 10, изображение 3 из 3
    Спросите у FixBot
  11. Steam Deck OLED Front Shell Replacement, Heat the right edge screen adhesive: шаг 11, изображение 1 из 1
    • Heat the right edge of the screen for one minute.
    Спросите у FixBot
  12. Steam Deck OLED Front Shell Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 2
    • Don't insert your pick deeper than 5 mm (~1/5 of an inch) along the right edge.
    • Insert another pick just below the right thumbstick.
    • Slide the pick to the bottom right corner to separate the right edge adhesive.
    • Leave the pick inserted to prevent the adhesive from resealing.
    Спросите у FixBot
  13. Steam Deck OLED Front Shell Replacement, Heat the bottom edge adhesive: шаг 13, изображение 1 из 1
    • Heat the bottom edge of the screen for one minute.
    Спросите у FixBot
  14. Steam Deck OLED Front Shell Replacement, Separate the bottom edge adhesive: шаг 14, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Separate the bottom edge adhesive: шаг 14, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Separate the bottom edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm (~1/8 of an inch) along the bottom edge.
    • Insert another pick in bottom right corner along the bottom edge.
    • Slide the pick to the bottom left corner to separate the bottom edge adhesive.
    Спросите у FixBot
  15. Steam Deck OLED Front Shell Replacement, Lift the top edge of the screen: шаг 15, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Lift the top edge of the screen: шаг 15, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Lift the top edge of the screen: шаг 15, изображение 3 из 3
    • Grip the two picks along the top edge.
    • Pry up to lift the top edge of the screen away from the frame until you can grab it.
    • If the screen feels stuck, go back around the perimeter and check for missed sections of adhesive. If you're using a hair dryer, use it to lightly heat the stuck sections of adhesive.
    Спросите у FixBot
  16. Steam Deck OLED Front Shell Replacement, Flip the screen over: шаг 16, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Flip the screen over: шаг 16, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Flip the screen over: шаг 16, изображение 3 из 3
    • Be gentle with the screen, as straining its cable may damage the socket on the motherboard.
    • Flip the screen over the bottom edge of the frame.
    • Prop up the screen with a small box or book roughly 2.5 cm (~1 inch) thick.
    • If you don't have a box or book nearby, hold the screen in this position for the next two steps.
    Спросите у FixBot
  17. Steam Deck OLED Front Shell Replacement, Unlatch the screen connector: шаг 17, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Unlatch the screen connector: шаг 17, изображение 2 из 2
    • Use the point of a spudger or a clean fingernail to flip up the locking flap on the outside edge of the screen ZIF connector.
    • Don't touch any of the small surface-mounted components around the connector.
    Спросите у FixBot
  18. Steam Deck OLED Front Shell Replacement, Disconnect the screen: шаг 18, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Disconnect the screen: шаг 18, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use tweezers or your fingers to grip the screen cable pull tab and slide the cable straight out of its socket to disconnect it.
    Спросите у FixBot
  19. Steam Deck OLED Front Shell Replacement, Remove the screen: шаг 19, изображение 1 из 1
    Спросите у FixBot
  20. Steam Deck OLED Front Shell Replacement, Remove the back cover screws: шаг 20, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the back cover screws: шаг 20, изображение 2 из 2
    FixMat
    $36.95
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
    Спросите у FixBot
  21. Steam Deck OLED Front Shell Replacement, Unclip a handle: шаг 21, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Unclip a handle: шаг 21, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Unclip a handle: шаг 21, изображение 3 из 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
    Спросите у FixBot
  22. Steam Deck OLED Front Shell Replacement, Unclip the top and bottom edges: шаг 22, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Unclip the top and bottom edges: шаг 22, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Unclip the top and bottom edges: шаг 22, изображение 3 из 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
    Спросите у FixBot
  23. Steam Deck OLED Front Shell Replacement, Remove the back cover: шаг 23, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the back cover: шаг 23, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the back cover: шаг 23, изображение 3 из 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
    Спросите у FixBot
  24. Steam Deck OLED Front Shell Replacement, Disconnect the battery: шаг 24, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the battery: шаг 24, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the battery: шаг 24, изображение 3 из 3
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
    Спросите у FixBot
  25. Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 25, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 25, изображение 2 из 2
    • During disassembly, skip the next three steps.
    • During reassembly:
    • Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
    • Reconnect the interconnect cable ZIF connector.
    Спросите у FixBot
  26. Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 26, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 26, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 26, изображение 3 из 3
    • Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
    Спросите у FixBot
  27. Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 27, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 27, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 27, изображение 3 из 3
    • During reassembly, follow this step and the above three steps to reconnect the battery.
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
    • Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
    • Be careful not to crease or strain the cable.
    Спросите у FixBot
  28. Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 28, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 28, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 28, изображение 3 из 3
    • Use the point of a spudger to flip up the small locking flap on the left thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
    Спросите у FixBot
  29. Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 29, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 29, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 29, изображение 3 из 3
    • Use a spudger to flip up the small white locking flap on the left button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑L.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    Спросите у FixBot
  30. Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 30, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 30, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left thumbstick: шаг 30, изображение 3 из 3
    • Flip up the small black locking flap on the left thumbstick cable ZIF connector.
    • The pull tab on this connector may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
    Спросите у FixBot
  31. Steam Deck OLED Front Shell Replacement, Disconnect the D-pad: шаг 31, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the D-pad: шаг 31, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the D-pad: шаг 31, изображение 3 из 3
    • Flip up the small locking flap on the D‑pad ZIF connector, located in the top right corner.
    • The pull tab on this connector may be labeled DPAD.
    Спросите у FixBot
  32. Steam Deck OLED Front Shell Replacement, Disconnect the touchpad board: шаг 32, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the touchpad board: шаг 32, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the touchpad board: шаг 32, изображение 3 из 3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the previous one.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Lift the connector until its arms are free and slide it straight out to disconnect it.
    Спросите у FixBot
  33. Steam Deck OLED Front Shell Replacement, Disconnect the left haptics: шаг 33, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left haptics: шаг 33, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left haptics: шаг 33, изображение 3 из 3
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the right side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
    Спросите у FixBot
  34. Steam Deck OLED Front Shell Replacement, Disconnect the left touchpad: шаг 34, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left touchpad: шаг 34, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the left touchpad: шаг 34, изображение 3 из 3
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the haptics connector.
    Спросите у FixBot
  35. Steam Deck OLED Front Shell Replacement, Remove the left button board screws: шаг 35, изображение 1 из 1
    • Use your T6 Torx driver to remove the four screws securing the left button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
    Спросите у FixBot
  36. Steam Deck OLED Front Shell Replacement, Remove the left button board: шаг 36, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the left button board: шаг 36, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the left button board: шаг 36, изображение 3 из 3
    • Insert the point of your spudger between the bottom right corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the five cables become trapped underneath the button board as you lay it into place.
    Спросите у FixBot
  37. Steam Deck OLED Front Shell Replacement, Remove the left thumbstick screws: шаг 37, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the left thumbstick screws: шаг 37, изображение 2 из 2
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
    • During reassembly, hold the Steam Deck OLED off your work surface so it doesn't rest on your thumbstick as you tighten the screws.
    Спросите у FixBot
  38. Steam Deck OLED Front Shell Replacement, Remove the left thumbstick: шаг 38, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the left thumbstick: шаг 38, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the left thumbstick: шаг 38, изображение 3 из 3
    • Grip the edges of the thumbstick board and rotate it counterclockwise to clear the trigger.
    • Remove the thumbstick.
    Спросите у FixBot
  39. Steam Deck OLED Front Shell Replacement, Remove the left trigger: шаг 39, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the left trigger: шаг 39, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the left trigger: шаг 39, изображение 3 из 3
    • The left trigger is on your right-hand side when working on the Steam Deck OLED, as it's laying upside down.
    • The trigger clips into place on two pegs on the frame, which double as the hinge.
    • Place the flat end of a spudger onto the inside edge of the trigger's left clip.
    • Use your fingers to push the trigger toward the left as you wedge the spudger between the clip and the peg.
    • Use your spudger to pivot the trigger clip out, away, and up from the peg to unlatch it.
    • During reassembly, latch the right peg first. Once in place, push down on the trigger to latch the left peg, producing an audible "click" sound.
    • Check to make sure that the trigger spring is properly aligned. Test the trigger action before continuing reassembly.
    Спросите у FixBot
  40. Steam Deck OLED Front Shell Replacement, Remove the left bumper assembly screws: шаг 40, изображение 1 из 1
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the left bumper assembly.
    Спросите у FixBot
  41. Steam Deck OLED Front Shell Replacement, Remove the left bumper assembly: шаг 41, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the left bumper assembly: шаг 41, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the left bumper assembly: шаг 41, изображение 3 из 3
    • Grip the left arm of the bumper assembly and lift it off its alignment pegs.
    • Slide the assembly to the left to clear the tab on the right edge of the frame.
    • Remove the assembly.
    • The D-pad and view buttons membrane might stay stuck to the underside of the bumper bracket. If so, remove it.
    • During reassembly, line up the bumper bracket with the alignment posts in the frame as you set it into place.
    Спросите у FixBot
  42. Steam Deck OLED Front Shell Replacement, Remove the buttons membrane: шаг 42, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the buttons membrane: шаг 42, изображение 2 из 2
    • If the D-pad and view buttons membrane stayed on the bumper bracket, skip this step.
    • Remove the D-pad and view button membrane from the frame.
    Спросите у FixBot
  43. Steam Deck OLED Front Shell Replacement, Remove the D-pad: шаг 43, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the D-pad: шаг 43, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the D-pad: шаг 43, изображение 3 из 3
    • Use tweezers to remove the D-pad.
    • The left edge of the D-Pad is shorter than the other edges. During reassembly, orient the D-pad so that the left edge faces to the left, closest to the outside edge of the frame.
    Спросите у FixBot
  44. Steam Deck OLED Front Shell Replacement, Remove the Steam button membrane: шаг 44, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the Steam button membrane: шаг 44, изображение 2 из 2
    • Use tweezers to remove the Steam button membrane.
    Спросите у FixBot
  45. Steam Deck OLED Front Shell Replacement, Remove the Steam button: шаг 45, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the Steam button: шаг 45, изображение 2 из 2
    • Remove the Steam button.
    • This button is keyed so it only fits in its recess in the correct orientation.
    Спросите у FixBot
  46. Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 46, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 46, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 46, изображение 3 из 3
    • Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
    Спросите у FixBot
  47. Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 47, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 47, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the interconnect cable: шаг 47, изображение 3 из 3
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑R.
    • During reassembly, don't reconnect this cable yet. You'll reconnect it later.
    Спросите у FixBot
  48. Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 48, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 48, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right thumbstick: шаг 48, изображение 3 из 3
    • Flip up the small black locking flap on the right thumbstick cable ZIF connector.
    Спросите у FixBot
  49. Steam Deck OLED Front Shell Replacement, Disconnect the right button board: шаг 49, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right button board: шаг 49, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right button board: шаг 49, изображение 3 из 3
    • Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
    Спросите у FixBot
  50. Steam Deck OLED Front Shell Replacement, Disconnect the remaining ZIF connectors: шаг 50, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the remaining ZIF connectors: шаг 50, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the remaining ZIF connectors: шаг 50, изображение 3 из 3
    • Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
    • The touchpad cable
    • The touchpad board cable
    • You may need to lift this cable as you pull to free its arms.
    • The action buttons and menu button cable
    Спросите у FixBot
  51. Steam Deck OLED Front Shell Replacement, Disconnect the right haptics: шаг 51, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right haptics: шаг 51, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the right haptics: шаг 51, изображение 3 из 3
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the left side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector, and not on the cables or socket.
    Спросите у FixBot
  52. Steam Deck OLED Front Shell Replacement, Remove the right button board screws: шаг 52, изображение 1 из 1
    • Use your T6 Torx driver to remove the four screws securing the right button board:
    Спросите у FixBot
  53. Steam Deck OLED Front Shell Replacement, Remove the right button board: шаг 53, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the right button board: шаг 53, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the right button board: шаг 53, изображение 3 из 3
    • Insert the point of your spudger between the bottom left corner of the button board and the frame.
    • During reassembly, make sure none of the six cables become trapped underneath the button board as you lay it into place.
    Спросите у FixBot
  54. Steam Deck OLED Front Shell Replacement, Remove the right thumbstick screws: шаг 54, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the right thumbstick screws: шаг 54, изображение 2 из 2
    Спросите у FixBot
  55. Steam Deck OLED Front Shell Replacement, Remove the right thumbstick: шаг 55, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the right thumbstick: шаг 55, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the right thumbstick: шаг 55, изображение 3 из 3
    • Grip the edges of the thumbstick board and rotate it clockwise to clear the trigger.
    Спросите у FixBot
  56. Steam Deck OLED Front Shell Replacement, Unclip the right trigger: шаг 56, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Unclip the right trigger: шаг 56, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Unclip the right trigger: шаг 56, изображение 3 из 3
    • The right trigger is on your left-hand side when working on the Steam Deck OLED, as it's laying upside down.
    • Place the flat end of a spudger onto the inside edge of the trigger's right clip.
    • Use your fingers to push the trigger toward the right as you wedge the spudger between the clip and the peg.
    • During reassembly, latch the left peg first. Once in place, push down on the trigger to latch the right peg, producing an audible "click" sound.
    Спросите у FixBot
  57. Steam Deck OLED Front Shell Replacement, Remove the right bumper assembly screws: шаг 57, изображение 1 из 1
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right bumper assembly.
    Спросите у FixBot
  58. Steam Deck OLED Front Shell Replacement, Remove the right bumper assembly: шаг 58, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the right bumper assembly: шаг 58, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the right bumper assembly: шаг 58, изображение 3 из 3
    • Grip the right arm of the bumper assembly and lift it off the alignment pegs.
    • Slide the assembly to the right to clear the tab on the left edge of the frame.
    • The action and menu buttons membrane might stay stuck to the underside of the bumper bracket. If so, remove it.
    Спросите у FixBot
  59. Steam Deck OLED Front Shell Replacement, Remove the buttons membrane: шаг 59, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the buttons membrane: шаг 59, изображение 2 из 2
    • If the action and menu buttons membrane stayed on the bumper bracket, skip this step.
    • Remove the action and menu buttons membrane from the frame.
    Спросите у FixBot
  60. Steam Deck OLED Front Shell Replacement, Remove the action buttons: шаг 60, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the action buttons: шаг 60, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the action buttons: шаг 60, изображение 3 из 3
    • Use tweezers to remove the four action buttons, A, B, X, and Y.
    • During reassembly, don't worry! The buttons are keyed—they can only be reinstalled in one orientation.
    Спросите у FixBot
  61. Steam Deck OLED Front Shell Replacement, Remove the quick access button membrane: шаг 61, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the quick access button membrane: шаг 61, изображение 2 из 2
    • Use tweezers to remove the quick access button membrane.
    Спросите у FixBot
  62. Steam Deck OLED Front Shell Replacement, Remove the quick access button: шаг 62, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the quick access button: шаг 62, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the quick access button: шаг 62, изображение 3 из 3
    • Use tweezers to remove the quick access button.
    Спросите у FixBot
  63. Steam Deck OLED Front Shell Replacement, Remove the menu button: шаг 63, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the menu button: шаг 63, изображение 2 из 2
    • Use tweezers to remove the menu button.
    Спросите у FixBot
  64. Steam Deck OLED Front Shell Replacement, Remove the view button: шаг 64, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the view button: шаг 64, изображение 2 из 2
    • Use tweezers to remove the view button.
    Спросите у FixBot
  65. Steam Deck OLED Front Shell Replacement, Remove the right touchpad board screws: шаг 65, изображение 1 из 1
    • Use your T6 Torx driver to remove the four 5 mm‑long screws securing the right touchpad board.
    Спросите у FixBot
  66. Steam Deck OLED Front Shell Replacement, Remove the right touchpad board: шаг 66, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the right touchpad board: шаг 66, изображение 2 из 2
    • Use your fingers to remove the right touchpad board.
    Спросите у FixBot
  67. Steam Deck OLED Front Shell Replacement, Remove the right touchpad screws: шаг 67, изображение 1 из 1
    • Use your T6 Torx driver to remove the four 6 mm‑long screws securing the right touchpad.
    Спросите у FixBot
  68. Steam Deck OLED Front Shell Replacement, Remove the right touchpad: шаг 68, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the right touchpad: шаг 68, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the right touchpad: шаг 68, изображение 3 из 3
    • Remove the right touchpad.
    • If you're having trouble removing the touchpad, lift the edge of the Steam Deck OLED and push the touchpad through from the front.
    Спросите у FixBot
  69. Steam Deck OLED Front Shell Replacement, Remove the left touchpad board screws: шаг 69, изображение 1 из 1
    • Use your T6 Torx driver to remove the four 5 mm‑long screws securing the left touchpad board.
    Спросите у FixBot
  70. Steam Deck OLED Front Shell Replacement, Remove the left touchpad board: шаг 70, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the left touchpad board: шаг 70, изображение 2 из 2
    • Use your fingers to remove the left touchpad board.
    Спросите у FixBot
  71. Steam Deck OLED Front Shell Replacement, Remove the left touchpad screws: шаг 71, изображение 1 из 1
    • Use your T6 Torx driver to remove the four 6 mm‑long screws securing the left touchpad.
    Спросите у FixBot
  72. Steam Deck OLED Front Shell Replacement, Remove the left touchpad: шаг 72, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the left touchpad: шаг 72, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the left touchpad: шаг 72, изображение 3 из 3
    • Remove the left touchpad.
    Спросите у FixBot
  73. Steam Deck OLED Front Shell Replacement, Remove the motherboard shield screws: шаг 73, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the motherboard shield screws: шаг 73, изображение 2 из 2
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the top left and bottom left corners of the motherboard shield.
    Спросите у FixBot
  74. Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 74, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 74, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 74, изображение 3 из 3
    • Lift the top edge of the motherboard shield up and flip it over to the right of the motherboard, over the battery.
    Спросите у FixBot
  75. Steam Deck OLED Front Shell Replacement, Soften the sticker adhesive: шаг 75, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Soften the sticker adhesive: шаг 75, изображение 2 из 2
    Спросите у FixBot
  76. Steam Deck OLED Front Shell Replacement, Remove the heat sink sticker: шаг 76, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Remove the heat sink sticker: шаг 76, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Remove the heat sink sticker: шаг 76, изображение 3 из 3
    • Try not to tear the heat sink sticker, as you'll reuse it during reassembly.
    • Slide the tip of an opening pick under one edge of the heat sink sticker.
    • Peel the sticker up until you can grab it with your fingers.
    • Gently remove the sticker from the heat sink and fan.
    • During reassembly, place the sticker back in its original location. The residual adhesive should stick well.
    • If the residual adhesive isn't sticky anymore, tape the outside edges of the sticker to the heat sink and fan with small strips of tape.
    Спросите у FixBot
  77. Steam Deck OLED Front Shell Replacement, Remove the heat sink screws: шаг 77, изображение 1 из 1
    • Use your T6 Torx driver to remove the three 3.3 mm‑long screws securing the heat sink.
    • During reassembly, install the screws in the order marked on the heat sink mounts: 1, 2, then 3.
    Спросите у FixBot
  78. Steam Deck OLED Front Shell Replacement, Remove the heat sink: шаг 78, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the heat sink: шаг 78, изображение 2 из 2
    • Lift the heat sink from the motherboard and remove it.
    • Depending on the age of your device, this might require some force. A twisting motion may help loosen the thermal paste.
    • Before reinstalling the heat sink, follow this guide to clean the heat sink and APU and reapply thermal paste.
    Спросите у FixBot
  79. Steam Deck OLED Front Shell Replacement, Disconnect the audio board: шаг 79, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the audio board: шаг 79, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Disconnect the audio board: шаг 79, изображение 3 из 3
    • Use the point of your spudger to flip up the small locking flap on the audio board ZIF connector in the upper right corner of the motherboard.
    • Use tweezers or your fingers to grip the cable's pull tab and pull it straight out of its socket to disconnect it.
    Спросите у FixBot
  80. Steam Deck OLED Front Shell Replacement, Unlock the audio board connector: шаг 80, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Unlock the audio board connector: шаг 80, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Unlock the audio board connector: шаг 80, изображение 3 из 3
    • Use your fingers or a spudger to gently lift the white locking tab on the audio board socket to release the cable.
    • Avoid bending the socket against the board—if you can't get your tool underneath, push up on alternating sides of the tab to lift it.
    • During reassembly, gently press down on the locking tab to secure the cable.
    Спросите у FixBot
  81. Steam Deck OLED Front Shell Replacement, Disconnect the audio board: шаг 81, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Disconnect the audio board: шаг 81, изображение 2 из 2
    • Use tweezers or your fingers to pull the audio board cable out of its socket to disconnect it.
    • With the locking tab released, the cable will slide out with little to no resistance. If it doesn't, check that the white locking tab is fully released.
    • During reassembly, ensure that the locking tab is in its unlocked, lifted position before inserting the cable.
    Спросите у FixBot
  82. Steam Deck OLED Front Shell Replacement, Pry up the right speaker: шаг 82, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Pry up the right speaker: шаг 82, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Pry up the right speaker: шаг 82, изображение 3 из 3
    • Be careful not to damage the speaker mesh underneath the speaker.
    • Insert the flat end of your spudger between the right speaker and the frame.
    • Slowly pry up the speaker to separate the adhesive securing it.
    • If the speaker feels stubborn, lightly heat it using a hair dryer.
    • During reassembly, make sure that the speaker mesh lays flat against the frame before reinstalling your speakers.
    Спросите у FixBot
  83. Steam Deck OLED Front Shell Replacement, Pry up the left speaker: шаг 83, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Pry up the left speaker: шаг 83, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Pry up the left speaker: шаг 83, изображение 3 из 3
    • Insert the flat end of your spudger between the left speaker and the frame.
    • If the speaker feels stubborn, lightly heat it with an iOpener or hair dryer.
    Спросите у FixBot
  84. Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 84, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 84, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Move the motherboard shield: шаг 84, изображение 3 из 3
    • Place the motherboard shield back onto the motherboard to protect it during the rest of the repair.
    • Optionally, you can secure the shield with its two 3.8 mm‑long screws to prevent it from falling off as you move the Steam Deck OLED.
    Спросите у FixBot
  85. Steam Deck OLED Front Shell Replacement, Flip over the Steam Deck OLED: шаг 85, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Flip over the Steam Deck OLED: шаг 85, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Flip over the Steam Deck OLED: шаг 85, изображение 3 из 3
    • Lay a soft, clean cloth on your work surface.
    • While holding the motherboard shield in place, flip over your Steam Deck OLED and lay it screen-side-down onto the cloth.
    Спросите у FixBot
  86. Steam Deck OLED Front Shell Replacement, Separate the sensor cable: шаг 86, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Separate the sensor cable: шаг 86, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Separate the sensor cable: шаг 86, изображение 3 из 3
    • Insert the tip of an opening pick under the right-side ambient light sensor to separate it from the top right corner of the screen recess.
    • Lower your pick flat to the midframe and reinsert it under the metal tab located next to the ambient light sensor.
    • Be careful not to damage the cable or separate it from the underside of the metal tab—the adhesive is strong, and the cable is fragile.
    • Slide your pick under the tab to separate it from the midframe.
    • Don't insert your pick deeper than the width of the cable to avoid damaging it.
    Спросите у FixBot
  87. Steam Deck OLED Front Shell Replacement: шаг 87, изображение 1 из 3 Steam Deck OLED Front Shell Replacement: шаг 87, изображение 2 из 3 Steam Deck OLED Front Shell Replacement: шаг 87, изображение 3 из 3
    • Repeat the previous step to separate the left-side ambient light sensor and metal tab.
    • Remember to not insert your pick deeper than the width of the cable to avoid damaging it.
    Спросите у FixBot
  88. Steam Deck OLED Front Shell Replacement, Separate the antennas: шаг 88, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Separate the antennas: шаг 88, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Separate the antennas: шаг 88, изображение 3 из 3
    • Press the flat end of your spudger or your fingers through the bottom left cutout in the screen recess and separate the antenna from the front shell.
    • Only apply enough force to separate the antenna from the black plastic front shell and not the gray midframe. This doesn't require much force.
    • Repeat for the antenna in the bottom middle of the screen recess.
    Спросите у FixBot
  89. Steam Deck OLED Front Shell Replacement, Remove the midframe screws: шаг 89, изображение 1 из 1
    • Flip your Steam Deck OLED back over and lay it screen-side-down.
    • Use your T6 Torx driver to remove the six 5.9 mm‑long screws securing the midframe to the front shell.
    Спросите у FixBot
  90. Steam Deck OLED Front Shell Replacement, Free the bottom edge of the midframe: шаг 90, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Free the bottom edge of the midframe: шаг 90, изображение 2 из 2
    • The midframe is almost free. The front shell secures it with clips, alignment posts, and ports along the top edge.
    • Rotate the device so the power button is closest to you.
    • Grip the bottom arms of the midframe and brace your other fingers against the front shell.
    • Use your fingers to pry the bottom edge of the midframe away from the front shell.
    • If you feel resistance, the antennas have re-adhered to the front shell. Be gentle and stop prying to check the antennas, if necessary.
    • It may be helpful to stand the Steam Deck OLED on its top edge to see the antennas as you pry.
    Спросите у FixBot
  91. Steam Deck OLED Front Shell Replacement, Separate the right edge of the midframe: шаг 91, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Separate the right edge of the midframe: шаг 91, изображение 2 из 2
    • Continue holding up the bottom right arm of the midframe with one hand.
    • With your other hand, pry the top edge of the front shell (near the volume buttons) away from the midframe.
    • Lift the top right corner of the midframe away from the front shell until the headphone jack comes free of its cutout.
    • If you feel resistance, either the front shell is caught on the midframe or the screen-side sensor cable is stuck to the midframe. Work slowly and inspect these areas as you pry.
    • During reassembly, squeeze the top edge of the front shell onto the midframe until it snaps into place.
    Спросите у FixBot
  92. Steam Deck OLED Front Shell Replacement, Separate the left edge of the midframe: шаг 92, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Separate the left edge of the midframe: шаг 92, изображение 2 из 2
    • Don't lift the midframe all the way out, yet—the audio board cable prevents the midframe from lifting more than half of an inch (~1.25 cm).
    • Repeat the previous step for the top left corner of the midframe, prying the front shell (near the power button) away from the midframe as you lift the midframe about half an inch (~1.25 cm) up.
    • Remember to inspect the frame and the screen-side sensor cable if you feel resistance.
    Спросите у FixBot
  93. Steam Deck OLED Front Shell Replacement, Free the audio board cable: шаг 93, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Free the audio board cable: шаг 93, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Free the audio board cable: шаг 93, изображение 3 из 3
    • Insert the flat end of your spudger against the audio board cable in the cutout in the midframe.
    • Hold the cable's pull tab clear of the cutout and lift the midframe over the cable.
    Спросите у FixBot
  94. Steam Deck OLED Front Shell Replacement, Remove the midframe: шаг 94, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Remove the midframe: шаг 94, изображение 2 из 2
    • Remove the midframe.
    Спросите у FixBot
  95. Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 95, изображение 1 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 95, изображение 2 из 3 Steam Deck OLED Front Shell Replacement, Reassembly instructions: шаг 95, изображение 3 из 3
    • During reassembly, follow these instructions to align the front shell onto your midframe:
    • Flip the midframe over, screen-side-up.
    • Hook the top edge of your replacement front shell over the top edge of the midframe, aligning the buttons and ports with their cutouts.
    • Grip the right end of the audio board cable and thread it through its cutout in the midframe and over the motherboard. Use a spudger or tweezers to angle the cable away from the midframe as you thread it.
    • Ensure the left end of the audio board cable threads over the audio board and doesn't become trapped underneath.
    Спросите у FixBot
  96. Steam Deck OLED Front Shell Replacement, Separate the ambient light sensors cable: шаг 96, изображение 1 из 2 Steam Deck OLED Front Shell Replacement, Separate the ambient light sensors cable: шаг 96, изображение 2 из 2
    • Use your fingers to separate the metal tab securing the left-side ambient light sensor from the front shell.
    Спросите у FixBot
  97. Steam Deck OLED Front Shell Replacement: шаг 97, изображение 1 из 2 Steam Deck OLED Front Shell Replacement: шаг 97, изображение 2 из 2
    • Use your fingers to separate the metal tab securing the right-side ambient light sensor from the front shell.
    Спросите у FixBot
  98. Steam Deck OLED Front Shell Replacement, Remove the ambient light sensors: шаг 98, изображение 1 из 1
    • Remove the ambient light sensors and audio board cable.
    • All that remains is the front shell.
    Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
5 человек успешно провели ремонт по этому руководству.
Clay Eickemeyer
Участник с: 09/19/22
104 680 Репутация
Автор 472 руководств
Команда
Guide Team Участник Guide Team
Staff
10 членов
Автор 18 390 руководств
3 Комментарии к руководству
Seems to be missing the break screen left side adhesive step. Good guide otherwise :)
Bunny T - Ответить Поделиться
Steps 86, 87, 96 and 97 are not nessasary. I tried this and struggled for awhile, stopped before i damaged it. I went to the youtube guide by extreme rate, the maker of my replacement front shell. They say to pry on this part against the case to brake the glue and leaving it atrached to the main board support. That was much easier.
Colin P - Ответить Поделиться
100% agree Colin. I found that lifting the silver metal tabs lift 90deg vertical from working surface and lifted out of insert mounts on the shell.
P.S. Unsure about how it affects the installation of wire. getting to that soon. I do not recommend this process as i am only 50% through it.
Stick with what you know. If you don't know, seek a source for answers and guidance that have been vetted.
Thrasson - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 20
За последние 7 дней: 167
За последние 30 дней: 497
За всё время: 16,139
