Texas Instruments TI-30 XS Multiview Solar Panel Replacement
Выберете то, что вам нужно
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: шаг 1, изображение 1 из 2 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: шаг 1, изображение 2 из 2
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
    Спросите у FixBot
    Добавить комментарий
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: шаг 2, изображение 1 из 1
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
    Спросите у FixBot
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: шаг 3, изображение 1 из 1
    • Use the spudger (or fingernail) to lift the battery from the black holder.
    Спросите у FixBot
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Make sure the positive side of your CR2032 is facing up.
    • Reverse the steps 2 and 1.
    Спросите у FixBot
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: шаг 5, изображение 1 из 1
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
    Спросите у FixBot
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: шаг 6, изображение 1 из 1
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
    Спросите у FixBot
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: шаг 7, изображение 1 из 1
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
    Спросите у FixBot
Заключение
Aaron Feinstein
Участник с: 10/01/15
401 Репутация
1 руководство автора
Команда
Cal Poly, Team 11-2, Forte Fall 2015 Участник Cal Poly, Team 11-2, Forte Fall 2015
CPSU-FORTE-F15S11G2
4 членов
Автор 9 руководств
1 Комментарий к руководству
Do you know where I could get a replacement solar panel for the calculator?
Josh - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 32
За всё время: 3,018
