ThinkPad T420 Keyboard Replacement
Выберете то, что вам нужно
    1. ThinkPad T420 Keyboard Replacement, Change note: шаг 1, изображение 1 из 2 ThinkPad T420 Keyboard Replacement, Change note: шаг 1, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Спросите у FixBot
      Добавить комментарий
    1. ThinkPad T420 Keyboard Replacement, Keyboard FRU: шаг 2, изображение 1 из 1
      • If the label on the back of the keyboard is not worn, that can be used to reference which keyboard is needed.
      • IMPORTANT: Each country has a different keyboard FRU part number. To match the keyboard you have and which one you need to purchase, check the back label or refer to the Lenovo HMM.
      Спросите у FixBot
    1. ThinkPad T420 Keyboard Replacement, Unlock the battery: шаг 3, изображение 1 из 3 ThinkPad T420 Keyboard Replacement, Unlock the battery: шаг 3, изображение 2 из 3 ThinkPad T420 Keyboard Replacement, Unlock the battery: шаг 3, изображение 3 из 3
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
      Спросите у FixBot
    2. ThinkPad T420 Keyboard Replacement, Release the battery: шаг 4, изображение 1 из 3 ThinkPad T420 Keyboard Replacement, Release the battery: шаг 4, изображение 2 из 3 ThinkPad T420 Keyboard Replacement, Release the battery: шаг 4, изображение 3 из 3
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
      Спросите у FixBot
    1. ThinkPad T420 Keyboard Replacement, Remove the RAM door: шаг 5, изображение 1 из 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: шаг 5, изображение 2 из 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: шаг 5, изображение 3 из 3
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
      Спросите у FixBot
    2. ThinkPad T420 Keyboard Replacement, Remove the keyboard: шаг 6, изображение 1 из 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: шаг 6, изображение 2 из 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: шаг 6, изображение 3 из 3
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
      Спросите у FixBot
    3. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: шаг 7, изображение 1 из 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: шаг 7, изображение 2 из 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: шаг 7, изображение 3 из 3
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
      Спросите у FixBot
Финишная прямая
10 человек успешно провели ремонт по этому руководству.
Nick
Участник с: 11/10/09
105 503 Репутация
Автор 72 руководств
3 Комментарии к руководству
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - Ответить Поделиться
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - Ответить Поделиться
I love how simply disassemby are in those old ThinkPads <3
Ziobro - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 34
За последние 30 дней: 182
За всё время: 16,213
