TicWatch Pro 3 GPS Battery Replacement
Выберете то, что вам нужно
  1. TicWatch Pro 3 GPS Battery Replacement, Power down your watch: шаг 1, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Power down your watch: шаг 1, изображение 2 из 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. TicWatch Pro 3 GPS Battery Replacement, Unfasten the back cover: шаг 2, изображение 1 из 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
  3. TicWatch Pro 3 GPS Battery Replacement, Loosen the back cover adhesive: шаг 3, изображение 1 из 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  4. TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: шаг 4, изображение 1 из 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: шаг 4, изображение 2 из 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: шаг 4, изображение 3 из 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
  5. TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: шаг 5, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: шаг 5, изображение 2 из 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  6. TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: шаг 6, изображение 1 из 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: шаг 6, изображение 2 из 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: шаг 6, изображение 3 из 3
    • Remove the back cover assembly.
  7. TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: шаг 7, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: шаг 7, изображение 2 из 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
  8. TicWatch Pro 3 GPS Battery Replacement, Unfasten the core assembly: шаг 8, изображение 1 из 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
  9. TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: шаг 9, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: шаг 9, изображение 2 из 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
  10. TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: шаг 10, изображение 1 из 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: шаг 10, изображение 2 из 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: шаг 10, изображение 3 из 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
  11. TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: шаг 11, изображение 1 из 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: шаг 11, изображение 2 из 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: шаг 11, изображение 3 из 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
  12. TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: шаг 12, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: шаг 12, изображение 2 из 2
    • Remove the core assembly.
  13. TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: шаг 13, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: шаг 13, изображение 2 из 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
  14. TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: шаг 14, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: шаг 14, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Купить
    • Use a pair of tweezers to remove the daughterboard.
  15. TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: шаг 15, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: шаг 15, изображение 2 из 2
    • The battery is held in place by mild adhesive.
    • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Pry upwards to loosen the battery.
    • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
    • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
  16. TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: шаг 16, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: шаг 16, изображение 2 из 2
    • Carefully fold the battery over to gain access to the battery cable connector.
    • Avoid straining or tearing the battery cable.
  17. TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: шаг 17, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  18. TicWatch Pro 3 GPS Battery Replacement, Remove the battery: шаг 18, изображение 1 из 2 TicWatch Pro 3 GPS Battery Replacement, Remove the battery: шаг 18, изображение 2 из 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
17 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
204 440 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 303 руководств
13 Комментариев
Where did you buy a replacement battery (if you did)? I have scoured thru aliexpress, ebay, and tried to find shattered-screen watches I could transplant from, with no luck so far. I guess I'll keep looking. My watch barely lasted a year before the battery life halved. The voltage sag is so bad the watch bootloops whenever it vibrates below 30% voltage.
George - Ответить
I've found a listing in aliexpress for an aftermarket battery but need to de-solder the original BMS and transfer to this new battery. Here's the link to aliexpress.
https://www.aliexpress.com/item/10050049...
Daniel Lee - Ответить
I don't think it's tin welding, but most likely TIG welding.
Difficult to open it, but the less experienced could solder the battery contacts on the top without opening the old solder.
https://imgur.com/zhFXcQ4
https://imgur.com/cKJb137
marco deirossi - Ответить
A small problem (solved) that I encountered with the battery purchased as compatible from ali-express is the greater ( >5mm)
distance (compared to the battery) of the original two poles of the battery.
You have to bend them carefully inwards to be able to weld them afterwards.
https://imgur.com/5mrfzDk
https://imgur.com/v2OCVCc
https://imgur.com/Izw3dU1
https://imgur.com/QsnAN6I
Добавить комментарий
Просмотр статистики:
За последние 24часов: 43
За последние 7 дней: 243
За последние 30 дней: 1,060
За всё время: 14,248
