Xbox Series X Fan Replacement
Выберете то, что вам нужно
    1. Xbox Series X Fan Replacement, Uncover the back panel screws: шаг 1, изображение 1 из 2 Xbox Series X Fan Replacement, Uncover the back panel screws: шаг 1, изображение 2 из 2
      • Before you begin, completely power down and unplug all cables from your console.
      • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      Спросите у FixBot
      Добавить комментарий
    2. Xbox Series X Fan Replacement: шаг 2, изображение 1 из 3 Xbox Series X Fan Replacement: шаг 2, изображение 2 из 3 Xbox Series X Fan Replacement: шаг 2, изображение 3 из 3
      • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
      • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      Спросите у FixBot
    3. Xbox Series X Fan Replacement, Remove the back panel screws: шаг 3, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Magnetic Project Mat
      $19.95
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      Спросите у FixBot
    4. Xbox Series X Fan Replacement, Unclip the back panel: шаг 4, изображение 1 из 3 Xbox Series X Fan Replacement, Unclip the back panel: шаг 4, изображение 2 из 3 Xbox Series X Fan Replacement, Unclip the back panel: шаг 4, изображение 3 из 3
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      Спросите у FixBot
    5. Xbox Series X Fan Replacement: шаг 5, изображение 1 из 2 Xbox Series X Fan Replacement: шаг 5, изображение 2 из 2
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      Спросите у FixBot
    6. Xbox Series X Fan Replacement, Remove the back panel: шаг 6, изображение 1 из 3 Xbox Series X Fan Replacement, Remove the back panel: шаг 6, изображение 2 из 3 Xbox Series X Fan Replacement, Remove the back panel: шаг 6, изображение 3 из 3
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      Спросите у FixBot
    7. Xbox Series X Fan Replacement: шаг 7, изображение 1 из 3 Xbox Series X Fan Replacement: шаг 7, изображение 2 из 3 Xbox Series X Fan Replacement: шаг 7, изображение 3 из 3
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      Спросите у FixBot
    1. Xbox Series X Fan Replacement, Remove the fan screws: шаг 8, изображение 1 из 1
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.5 mm pancake screw
      • Two 8.8 mm screws
      Спросите у FixBot
    2. Xbox Series X Fan Replacement, Disconnect the fan cable: шаг 9, изображение 1 из 3 Xbox Series X Fan Replacement, Disconnect the fan cable: шаг 9, изображение 2 из 3 Xbox Series X Fan Replacement, Disconnect the fan cable: шаг 9, изображение 3 из 3
      • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
      Спросите у FixBot
    3. Xbox Series X Fan Replacement, Remove the fan: шаг 10, изображение 1 из 2 Xbox Series X Fan Replacement, Remove the fan: шаг 10, изображение 2 из 2
      • Slide the fan out of its slot to remove it.
      • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
      • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
36 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
167 888 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 32 283 руководств
1 Комментарий к руководству
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
Modesto Delvalle Jr - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 54
За последние 7 дней: 253
За последние 30 дней: 1,209
За всё время: 64,283
