Xbox Series X Motherboard Replacement
Выберете то, что вам нужно
  1. Xbox Series X Motherboard Replacement, Uncover the back panel screws: шаг 1, изображение 1 из 2 Xbox Series X Motherboard Replacement, Uncover the back panel screws: шаг 1, изображение 2 из 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Motherboard Replacement: шаг 2, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 2, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 2, изображение 3 из 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    Recommend using a hair dryer to soften the label adhesive.
    Crash - Ответить
    Microsoft can void your warranty. They can use whatever excuse if it is sent in because you opened it and you cannot prove you didn’t damage it.
    DirtyD - Ответить
  3. Xbox Series X Motherboard Replacement, Remove the back panel screws: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Motherboard Replacement, Unclip the back panel: шаг 4, изображение 1 из 3 Xbox Series X Motherboard Replacement, Unclip the back panel: шаг 4, изображение 2 из 3 Xbox Series X Motherboard Replacement, Unclip the back panel: шаг 4, изображение 3 из 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Motherboard Replacement: шаг 5, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 5, изображение 2 из 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Motherboard Replacement, Remove the back panel: шаг 6, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the back panel: шаг 6, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the back panel: шаг 6, изображение 3 из 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Motherboard Replacement: шаг 7, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 7, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 7, изображение 3 из 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Motherboard Replacement, Remove the fan screws: шаг 8, изображение 1 из 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
    are there any 10.5mm wide head screw for the xbox fan for sale because i need a replacement because i accidentally broke mine
    GhostMindX9 - Ответить
    If the 10.5 mm screw isn’t budging, use some pliers to loosen it
    Joseph Grant - Ответить
  9. Xbox Series X Motherboard Replacement, Disconnect the fan cable: шаг 9, изображение 1 из 3 Xbox Series X Motherboard Replacement, Disconnect the fan cable: шаг 9, изображение 2 из 3 Xbox Series X Motherboard Replacement, Disconnect the fan cable: шаг 9, изображение 3 из 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    But don’t pull the connectors with tweezers because you will inevitably still damage the cable as you have no grip on the connector and the tweezers will slip.
    Leif DeWolf - Ответить
  10. Xbox Series X Motherboard Replacement, Remove the fan: шаг 10, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the fan: шаг 10, изображение 2 из 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X Motherboard Replacement, Unlatch the base: шаг 11, изображение 1 из 3 Xbox Series X Motherboard Replacement, Unlatch the base: шаг 11, изображение 2 из 3 Xbox Series X Motherboard Replacement, Unlatch the base: шаг 11, изображение 3 из 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Motherboard Replacement, Twist and remove the base: шаг 12, изображение 1 из 3 Xbox Series X Motherboard Replacement, Twist and remove the base: шаг 12, изображение 2 из 3 Xbox Series X Motherboard Replacement, Twist and remove the base: шаг 12, изображение 3 из 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
    had trouble getting the base off, what worked for me is setting the console on the table sitting on the base and turning the whole console while pushing down.
    techy Waterville - Ответить
  13. Xbox Series X Motherboard Replacement, Remove the optical drive screws: шаг 13, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the optical drive screws: шаг 13, изображение 2 из 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Motherboard Replacement, Remove the vibration isolator: шаг 14, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the vibration isolator: шаг 14, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the vibration isolator: шаг 14, изображение 3 из 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Motherboard Replacement, Disconnect the power and data cables: шаг 15, изображение 1 из 3 Xbox Series X Motherboard Replacement, Disconnect the power and data cables: шаг 15, изображение 2 из 3 Xbox Series X Motherboard Replacement, Disconnect the power and data cables: шаг 15, изображение 3 из 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
    Once again, DO NOT use tweezers to pull these connectors out. That’s a great way to slip and damage something.
    I managed to get the power connector unplugged, but the data cable just refuses to move. I've used quite a bit of force, and using any more feels like I would damage it. I have no clue on how to get it out safely :(
    Izaac Brånn - Ответить
    Try to "walk" the connector out: pry up one side, then the other. Best of luck!
    Carsten Frauenheim -
  16. Xbox Series X Motherboard Replacement, Remove the optical drive: шаг 16, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the optical drive: шаг 16, изображение 2 из 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Motherboard Replacement, Disconnect the USB port cable: шаг 17, изображение 1 из 3 Xbox Series X Motherboard Replacement, Disconnect the USB port cable: шаг 17, изображение 2 из 3 Xbox Series X Motherboard Replacement, Disconnect the USB port cable: шаг 17, изображение 3 из 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Motherboard Replacement: шаг 18, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 18, изображение 2 из 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
    Connector i-pex Evaflex 5-HD 24 pin
    20952-024e-02
    http://www.i-pex.com/sites/default/files...
    drops206 - Ответить
    The silver ribbon cable is glued down to the center chassis, so only pulling on the black plastic pull tab will result in it pulling free from the cable as that tab is only glued to the cable.
    Better to heat the silver ribbon cable's adhesive with a hair dryer, separate the cable from the center chassis, and then pull the cable from the connector using the black plastic pull tab.
    Crash - Ответить
  19. Xbox Series X Motherboard Replacement, Disconnect the power button cable: шаг 19, изображение 1 из 3 Xbox Series X Motherboard Replacement, Disconnect the power button cable: шаг 19, изображение 2 из 3 Xbox Series X Motherboard Replacement, Disconnect the power button cable: шаг 19, изображение 3 из 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
    I broke this connector during disassembly. Is there a part number I can use to get a replacement on Mouser or Digikey?
    Peter LeCraw - Ответить
    I broke this connector during disassembly too. Where can I get this connector?
    Oscar Cedeño - Ответить
    the manufacturer of connectors in series x is I-PEX.  exact part number (as far as I'm not mistaken) 20535-010E-02 EVAFLEX 5-VS.  0.5mm pin spacing (10pin connector). a possible rescue may be to desolder the connector from the switch board and solder it permanently there.
    drops206 - Ответить
    How do I purchase this from their website?
    munirbisharat12 -
    I have these connectors. Baycroc@fedtel.net
    Evenson Electronics - Ответить
    Would we be able to order them from you directly
    bailey jackson -
    Yes would we be able to order these connectors directly from you?
    Blake Roan -
    There is no black pull tab on mine😬. How am I supposed to pull it safely?
    Karman Wilmot - Ответить
  20. Xbox Series X Motherboard Replacement, Remove the chassis screws: шаг 20, изображение 1 из 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Motherboard Replacement, Peel up the USB port cable: шаг 21, изображение 1 из 2 Xbox Series X Motherboard Replacement, Peel up the USB port cable: шаг 21, изображение 2 из 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X Motherboard Replacement, Remove the center chassis assembly: шаг 22, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the center chassis assembly: шаг 22, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the center chassis assembly: шаг 22, изображение 3 из 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X Motherboard Replacement, Unlatch the chassis strap: шаг 23, изображение 1 из 3 Xbox Series X Motherboard Replacement, Unlatch the chassis strap: шаг 23, изображение 2 из 3 Xbox Series X Motherboard Replacement, Unlatch the chassis strap: шаг 23, изображение 3 из 3
    • Unlatch the chassis strap from the right side of the power supply.
  24. Xbox Series X Motherboard Replacement: шаг 24, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 24, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 24, изображение 3 из 3
    • Pull the chassis strap over and off of the power supply.
    • Once the strap is off of the power supply, set the loose section to the side.
  25. Xbox Series X Motherboard Replacement, Remove the power cable port: шаг 25, изображение 1 из 1
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm screws
    • One 35 mm screw
  26. Xbox Series X Motherboard Replacement: шаг 26, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 26, изображение 2 из 2
    • Lift the power connector out of its recess in the chassis.
  27. Xbox Series X Motherboard Replacement, De-route the power cables: шаг 27, изображение 1 из 2 Xbox Series X Motherboard Replacement, De-route the power cables: шаг 27, изображение 2 из 2
    • Unlatch and open the lid on the power cable's plastic guide.
  28. Xbox Series X Motherboard Replacement: шаг 28, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 28, изображение 2 из 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  29. Xbox Series X Motherboard Replacement, Remove the corner cover: шаг 29, изображение 1 из 1
    • Use a T8 Torx driver to remove the 8.8 mm screw securing the power supply corner cover.
  30. Xbox Series X Motherboard Replacement: шаг 30, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 30, изображение 2 из 2
    • Your Xbox may not have this cover depending on the model.
    • Use your fingers or a pair of tweezers to lift and remove the power supply corner cover.
  31. Xbox Series X Motherboard Replacement, Remove the accessory antenna board: шаг 31, изображение 1 из 1
    • Use a T8 Torx driver to remove the three 9.6 mm screws securing the accessory antenna board to the center chassis.
  32. Xbox Series X Motherboard Replacement: шаг 32, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 32, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 32, изображение 3 из 3
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
    Is this is WIFI Antenna Board that required to replaced if there is a issue with WIFI non-detection ?
    Raviraj Iddya - Ответить
  33. Xbox Series X Motherboard Replacement, Remove the board shield: шаг 33, изображение 1 из 1
    • Use a T8 Torx driver to remove the nine screws securing the board shield:
    • Six 8.8 mm black screws
    • Two 35 mm silver screws
    • One 13.1 mm silver screw
  34. Xbox Series X Motherboard Replacement: шаг 34, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 34, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 34, изображение 3 из 3
    • Lift up the board shield to remove it from the center chassis.
  35. Xbox Series X Motherboard Replacement, Remove the chassis strap: шаг 35, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the chassis strap: шаг 35, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the chassis strap: шаг 35, изображение 3 из 3
    • Disconnect the chassis strap from the locking tabs on either side of the power supply.
  36. Xbox Series X Motherboard Replacement: шаг 36, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 36, изображение 2 из 2
    • Remove the chassis strap.
  37. Xbox Series X Motherboard Replacement, Disconnect the motherboard: шаг 37, изображение 1 из 3 Xbox Series X Motherboard Replacement, Disconnect the motherboard: шаг 37, изображение 2 из 3 Xbox Series X Motherboard Replacement, Disconnect the motherboard: шаг 37, изображение 3 из 3
    • Grip and compress the locking tab on the 10-pin power connector.
    • While compressing the locking tab, lift the connector straight up to disconnect it from the board.
  38. Xbox Series X Motherboard Replacement: шаг 38, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 38, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 38, изображение 3 из 3
    • Grip the base of the interconnect cable connector with your fingers.
    • Depress each side of the connector to unlock the cable locking tabs.
    • With the locking tabs depressed, grip the edges of the interconnect cable and pull it straight out of the connector to disconnect it.
    • With the locking tabs depressed correctly, the interconnect cable will slide out with very little force.
    • During reassembly, the interconnect cable should "snap" into place when fully inserted.
    Bij deze had ik een andere connector . Ik had in het midden een tab dat ik moest indrukken en toen kwam de kabel met een zwarte connector uit een grijze connector . Ik heb de 20 jaar editie Xbox X .
    Maarten Lauwereys - Ответить
    There is a variant of this connection that has the locking tab on the front of the connector.
    Martin Samuelsson - Ответить
  39. Xbox Series X Motherboard Replacement, Remove the silver power supply screws: шаг 39, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the silver power supply screws: шаг 39, изображение 2 из 2
    • Use a T8 Torx driver to remove the three 35 mm‑long silver screws from the power supply—leave the fourth black screw in place.
  40. Xbox Series X Motherboard Replacement, Remove the center chassis: шаг 40, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the center chassis: шаг 40, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the center chassis: шаг 40, изображение 3 из 3
    • Grip the edges of the center chassis (not the power supply) and lift it off of the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
  41. Xbox Series X Motherboard Replacement, Pry off the SSD shield: шаг 41, изображение 1 из 3 Xbox Series X Motherboard Replacement, Pry off the SSD shield: шаг 41, изображение 2 из 3 Xbox Series X Motherboard Replacement, Pry off the SSD shield: шаг 41, изображение 3 из 3
    • The SSD shield has thermal pads on either side, so ensure these are kept as intact as possible during this procedure.
    • Use the flat end of a spudger to pry up the edges of the metal SSD shield.
    • Remove the SSD shield.
  42. Xbox Series X Motherboard Replacement, Remove the SSD screw: шаг 42, изображение 1 из 1
    • Use a T8 Torx driver to remove the 5.2 mm screw securing the SSD.
  43. Xbox Series X Motherboard Replacement, Remove the SSD: шаг 43, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the SSD: шаг 43, изображение 2 из 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its M.2 board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
    If your internally hdd is faulty how can you clone it yo replace
    Murat Bas - Ответить
    I use SABRENT Tool-Free USB Type-C Dual Docking Station for PCIe NVMe M.2 SSDs with Offline Cloning Function (EC-SSD2).
    Justin Ott - Ответить
    my ssd is unfortunately broken and cloning from another series x nvme didn't work, the power led lights up briefly and goes off again and that's it
    Mario FrodosLabambus - Ответить
    It is firmware locked by microsoft, you must go to them to change the ssd
    John Netfixl -
    Imagine going through all this, just to find out the console doesn't even support a full-sized NVMe drive.
    beileijunk - Ответить
    48 steps to replace the SSD? Smh
    David Amodt - Ответить
    At least the primary storage is replaceable at all, unlike the PS5.
    Tyler -
    Make it daunting enough and people would rather go to the manufacturer to do it.. we need better placement for this. Not only for easier replacement but better cooling
    Mykel Gibson - Ответить
    If you want a larger drive with better cooling that should be on the external storage card, not the internal drive.
    Tyler -
    Absolutely terrible from microsoft. Much like their surface pro devices.
    Make a simple task as hard as possible so that people will just buy a new device instead of a simple and cheap fix.
    Boo microsoft
    Joshua Dunsire - Ответить
    The storage replacement process is better on the Xbox Series consoles than the PS5 in every way. To replace the Xbox external drive you just slide it out, don't need a screw driver or even turn off the console. The PS5 requires tools. The internal drive on Xbox can be replaced as shown above. The PS5 internal drive is soldered to the motherboard. So boo Sony.
    Tyler -
    There is a partition key that has to be copied over form the original ssd if not damaged. Will have to have a nvme reader and use disk management software. Then after will need to put into safe mode and load the osu1 update for xbox then be set. Though if can't get the partition key it bricks it to where turns on then off. If only there was a master key to initialize the console then run the osu1 for the software.
    Michael Russell - Ответить
    What's the ssd model? Maybe hook up to a pc?
    Dark Knight_TJ - Ответить
  44. Xbox Series X Motherboard Replacement, Remove the interconnect cable: шаг 44, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the interconnect cable: шаг 44, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the interconnect cable: шаг 44, изображение 3 из 3
    • If your interconnect cable has a locking tab in the middle, skip to the next step.
    • Remove the interconnect cable.
  45. Xbox Series X Motherboard Replacement: шаг 45, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 45, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 45, изображение 3 из 3
    • Pinch the locking tab on the interconnect cable on the motherboard and use the flat end of a spudger to disengage the clip.
    • Use your fingers to pull the connector straight up and out of its socket.
    • During reassembly, insert the #1—SOC side of interconnect cable connector into its socket so the locking tab is facing outward. Then, press down on the edges of the connector until it snaps into place.
  46. Xbox Series X Motherboard Replacement, Remove the metal shield: шаг 46, изображение 1 из 3 Xbox Series X Motherboard Replacement, Remove the metal shield: шаг 46, изображение 2 из 3 Xbox Series X Motherboard Replacement, Remove the metal shield: шаг 46, изображение 3 из 3
    • Be very careful not to damage any of the components around the metal shield.
    • Use the flat end of a spudger to pry up the edges of the large metal shield in the center of the motherboard.
  47. Xbox Series X Motherboard Replacement: шаг 47, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 47, изображение 2 из 2
    • Remove the metal shield.
    • During reassembly, set the shield into place and push down firmly around the perimeter to secure the shield.
  48. Xbox Series X Motherboard Replacement, Remove the APU tension bracket: шаг 48, изображение 1 из 2 Xbox Series X Motherboard Replacement, Remove the APU tension bracket: шаг 48, изображение 2 из 2
    • Only loosen and tighten the APU tension bracket screws a few turns at a time in an "X" pattern. For example: top left → bottom right → top right → bottom left.
    • Use a T8 Torx driver to remove the four 12.3 mm‑long APU tension bracket screws.
  49. Xbox Series X Motherboard Replacement: шаг 49, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 49, изображение 2 из 2
    • Don't move the APU bracket side to side, or you may damage the delicate surface‑mounted components underneath it. Only lift straight up.
    • Use your fingers to lift the APU bracket straight up and remove it.
    • During reassembly, set the bracket into place so the black pieces of plastic are facing the long edges of the motherboard—the piece of plastic with a circular hole (not oblong) should be closer to the interconnect cable socket. Use this photo as a reference.
  50. Xbox Series X Motherboard Replacement: шаг 50, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 50, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 50, изображение 3 из 3
    • Depending on the condition of the thermal paste and putty, the board may be bonded to the heatsink assembly. If you can't easily remove the board, use a spudger to gently lift the edges of the board to separate it.
    • Lift the motherboard straight up and off of the heatsink to remove it.
    • During reassembly, carefully place the board onto the heatsink with the APU facing down. Remember, there's exposed thermal paste on the bottom of the board, so use the alignment pegs to orient it correctly. If you have to reposition the board, it may smear the thermal paste.
  51. Xbox Series X Motherboard Replacement, Thermal putty replacement: шаг 51, изображение 1 из 2 Xbox Series X Motherboard Replacement, Thermal putty replacement: шаг 51, изображение 2 из 2
    • Check the condition of the thermal putty—it'll be on the heatsink and/or the motherboard.
    • If any pieces are damaged or dried out, follow the next four steps to remove and replace them.
    • If you're only replacing the thermal paste, skip to this step.
  52. Xbox Series X Motherboard Replacement: шаг 52, изображение 1 из 3 Xbox Series X Motherboard Replacement: шаг 52, изображение 2 из 3 Xbox Series X Motherboard Replacement: шаг 52, изображение 3 из 3
    • Use the flat end of a spudger to scrape off the damaged or deteriorated thermal pad.
    • Be careful around any small surface-mounted components that might be hidden under the thermal pad. Work slowly to avoid accidentally prying them off.
  53. Xbox Series X Motherboard Replacement: шаг 53, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 53, изображение 2 из 2
    Cotton Swabs
    • Use isopropyl alcohol (>90%) and a lint-free microfiber cloth to remove any thermal putty residue.
    • If you have to work near the small resistors, use cotton swabs instead.
  54. Xbox Series X Motherboard Replacement: шаг 54, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 54, изображение 2 из 2
    • To prevent the thermal putty from sticking to your fingers, consider wearing nitrile gloves.
    • Grab a small piece of thermal putty. Refer to the size of the thermal pad you're replacing for how much you need.
  55. Xbox Series X Motherboard Replacement: шаг 55, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 55, изображение 2 из 2
    • Roll the thermal putty into a ball.
    • Place the thermal putty where the damaged thermal pad was, making sure it's centered over the component—in this case a memory chip.
    • Optionally, you can use the flat end of a spudger (or an included applicator) to spread the thermal putty over the surface of the component.
    • When you reattach the heat sink, you'll compress the thermal putty and it'll spread the ball out.
  56. Xbox Series X Motherboard Replacement, Replace the thermal paste: шаг 56, изображение 1 из 2 Xbox Series X Motherboard Replacement, Replace the thermal paste: шаг 56, изображение 2 из 2
    Cotton Swabs
    • Apply a few drops of isopropyl alcohol (>90%) to the processor and use a coffee filter or a lint-free cloth to wipe away any residue.
  57. Xbox Series X Motherboard Replacement: шаг 57, изображение 1 из 2 Xbox Series X Motherboard Replacement: шаг 57, изображение 2 из 2
    • Repeat the previous step for the thermal paste on the heat sink.
    • You can use a spudger to scrape off the thermal paste on the heat sink if it's too dried out.
  58. Xbox Series X Motherboard Replacement, Apply the thermal paste: шаг 58, изображение 1 из 2 Xbox Series X Motherboard Replacement, Apply the thermal paste: шаг 58, изображение 2 из 2
    • Apply a small bead of thermal paste to the center of the APU.
    • Follow this guide in reverse order starting with this step to reattach the heat sink. Placing the heat sink back on the processor will evenly spread the thermal paste (and thermal putty if applicable) and bond both parts together.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
21 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
94 530 Репутация
Автор 662 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 410 руководств
4 Комментариев
There are five completely unnecessary steps in this guide all centered around removing the PSU and the part under it that don't need to be done in order to remove the motherboard/heatsink. You can cut out steps 38, 39, 41, 42 and 43 on step 40 you only need to remove the three 35mm screws to complete the step. As long as you complete the rest of the guide the top comes away without issue.
Alex Weaver - Ответить
Hi Alex! The guide has been updated and any unnecessary steps have been removed. Thank you for the helpful information!
Spencer Day -
Thanks....... I just had one apart and skipped those steps with no problems.
Alan Sears - Ответить
If you replace the motherboard will the disk drive still work?
tomjeffrey20 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 56
За последние 7 дней: 349
За последние 30 дней: 1,379
За всё время: 35,438
