Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement
Выберете то, что вам нужно
    1. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Rear Glass Removal: шаг 1, изображение 1 из 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Спросите у FixBot
      Добавить комментарий
    2. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 2, изображение 1 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 2, изображение 2 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 2, изображение 3 из 3
      • Secure a suction handle to the bottom of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      Спросите у FixBot
    3. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 3, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 3, изображение 2 из 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      • Don't remove the suction handle yet. You're going to use it later in the removal procedure as a rear glass stand.
      Спросите у FixBot
    4. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 4, изображение 1 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 4, изображение 2 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 4, изображение 3 из 3
      • Insert a third opening pick at the bottom left corner.
      • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Спросите у FixBot
    5. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 5, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 5, изображение 2 из 2
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Спросите у FixBot
    6. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 6, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 6, изображение 2 из 2
      • Do not insert the opening pick deeper than 5 mm to avoid damaging the fingerprint connector.
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      • Do not remove the rear glass all the way yet, the fingerprint cable is still connected to the motherboard.
      Спросите у FixBot
    7. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 7, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 7, изображение 2 из 2
      • Carefully fold the rear glass to the right side of the phone. Use the suction handle as a stand for the rear glass.
      Спросите у FixBot
    8. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 8, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 8, изображение 2 из 2
      • Use a spudger to pry up and disconnect the fingerprint flex cable.
      • Remove the rear glass.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      Спросите у FixBot
    1. Внимание: шаги 9-11 взяты из руководства, помеченного как незавершенное.
      Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Motherboard Cover Removal: шаг 9, изображение 1 из 1
      • Remove the eleven Phillips #00 screws (3.9 mm length).
      Спросите у FixBot
    2. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 10, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 10, изображение 2 из 2
      • Insert the tip of an opening pick underneath the bottom edge of the motherboard cover.
      • Use the opening pick to pry up the motherboard cover.
      Спросите у FixBot
    3. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 11, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 11, изображение 2 из 2
      • Remove the motherboard cover including the black protective foil that covers the battery.
      Спросите у FixBot
    1. Внимание: шаг 12 взят из руководства, помеченного как незавершенное.
      Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Battery Disconnect: шаг 12, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, Xiaomi Redmi Note 8T Battery Disconnect: шаг 12, изображение 2 из 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Спросите у FixBot
    1. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, IPS LCD Screen & Digitizer: шаг 13, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement, IPS LCD Screen & Digitizer: шаг 13, изображение 2 из 2
      • Use a spudger to pry up and disconnect the display flex cable.
      Спросите у FixBot
    2. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 14, изображение 1 из 1
      • Remove the seven Phillips #00 screws (3.9 mm length).
      Спросите у FixBot
    3. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 15, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 15, изображение 2 из 2
      • Slide an opening pick underneath the top edge of the daughterboard cover.
      • Use the opening pick to pry up the daughterboard cover.
      Спросите у FixBot
    4. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 16, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 16, изображение 2 из 2
      • Remove the daughterboard cover.
      Спросите у FixBot
    5. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 17, изображение 1 из 1
      • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
      Спросите у FixBot
    6. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 18, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 18, изображение 2 из 2
      • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the phone.
      • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the screen with the suction handle to create a small gap between the cover and the frame.
      • Insert an iFlex between the midframe and the screen to create a bigger gap. Leave the iFlex in the gap to prevent the screen from resealing.
      Спросите у FixBot
    7. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 19, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 19, изображение 2 из 2
      • Insert an opening pick in the gap you createtd in the step before. You can remove the iFlex afterwards.
      • Start to cut the adhesive by sliding the opening pick to the bottom right corner.
      Спросите у FixBot
    8. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 20, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 20, изображение 2 из 2
      • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
      • Leave the picks in their place to prevent the adhesive from resealing.
      Спросите у FixBot
    9. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 21, изображение 1 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 21, изображение 2 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 21, изображение 3 из 3
      • Insert a third opening pick under the bottom left corner of the phone.
      • Slide the opening pick up to the top left corner to cut the adhesive. Leave it there to prevent the adhesive from resealing.
      • If cutting becomes too difficult, reheat and reapply the iOpener.
      Спросите у FixBot
    10. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 22, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 22, изображение 2 из 2
      • Insert a fourth opening pick at the top left corner.
      • When nearing the front facing camera, only work with the tip of the opening pick to avoid damaging or smearing the camera.
      • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the pick in the top right corner of the screen to prevent the adhesive from resealing.
      Спросите у FixBot
    11. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 23, изображение 1 из 2 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 23, изображение 2 из 2
      • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
      • Try not to remove the display all the way yet, the display cable is still threaded through the frame and possible adhered on the inner side of the midframe.
      Спросите у FixBot
    12. Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 24, изображение 1 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 24, изображение 2 из 3 Xiaomi Redmi Note 8T IPS LCD Screen & Digitizer Replacement: шаг 24, изображение 3 из 3
      • Thread the display flex cable through the gap in the midframe and remove the display.
      Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
19 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
264 538 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 86 234 руководств
6 Комментарии к руководству
Hervorande Anleitung !
Alois Springer - Ответить Поделиться
Bonjour, c'est grâce à ce tuto que je suis fier de vous dire avoir réussi à changer mon écran seul sans payer un réparateur.
Pour enlever l ‘écran je n ai pas réussi à soulever l’écran avec une ventouse en chauffant avec un sèche cheveux ( alors que ça a bien fonctionné pour la vitre arrière).
J ai improvisé alors j ai du élargir une fissure avec un petit tournevis pour soulever l’écran du châssis et ainsi insérer le mediator comme prévu
Merci pour ce tuto…
FRA NCK - Ответить Поделиться
After heating to take apart back glass and screen, both buttons power and volume are loose and dont stay on their place. they fall, even if i put them back. any idea why this happens?
ifixthem - Ответить Поделиться
ok i found why. buttons have a black thin plastic “lock" check it under microscope mine had “twisted
Welchen Kleber sollte man verwenden, um das Display auf den Rahmen/ Chassis zu kleben?
Danke für die gute Anleitung!
koston85 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 36
За последние 30 дней: 101
За всё время: 17,592
