iMac G5 20" Model A1076 Hard Drive Replacement
Выберете то, что вам нужно
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Rear Panel: шаг 1, изображение 1 из 1
      • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      Спросите у FixBot
      Добавить комментарий
    2. iMac G5 20" Model A1076 Hard Drive Replacement: шаг 2, изображение 1 из 2 iMac G5 20" Model A1076 Hard Drive Replacement: шаг 2, изображение 2 из 2
      • Lift the rear panel slightly near the bottom of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      Спросите у FixBot
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Hard Drive: шаг 3, изображение 1 из 1
      • Remove the following three screws:
      • One shouldered 12.4 mm Phillips.
      • Two 7 mm T10 Torx.
      Спросите у FixBot
    2. iMac G5 20" Model A1076 Hard Drive Replacement: шаг 4, изображение 1 из 1
      • The following action is optional. If you skip this step, be very careful not to strain the thermal sensor cable as you disconnect the hard drive cables and transfer this bracket to your new hard drive.
      • Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
      Спросите у FixBot
    3. iMac G5 20" Model A1076 Hard Drive Replacement: шаг 5, изображение 1 из 2 iMac G5 20" Model A1076 Hard Drive Replacement: шаг 5, изображение 2 из 2
      • Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
      • Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
      • Repeat this process for the SATA power connector.
      Спросите у FixBot
    4. iMac G5 20" Model A1076 Hard Drive Replacement: шаг 6, изображение 1 из 1
      • Lift the hard drive out of the iMac.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      Спросите у FixBot
    1. iMac G5 20" Model A1076 Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 1
      • Remove the two 15 mm shouldered T10 Torx screws from the hard drive and remove the bracket.
      Спросите у FixBot
    2. iMac G5 20" Model A1076 Hard Drive Replacement: шаг 8, изображение 1 из 1
      • Remove the two 6 mm T10 Torx screws from the hard drive and remove the hard drive bracket.
      • The hard drive bracket with the thermal sensor board is attached to the SATA connector side of the hard drive.
      Спросите у FixBot
Заключение
149 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
Very helpful and easy guide. Thanks!
Bojan A - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 27
За последние 30 дней: 100
За всё время: 77,420
