Введение
Use this guide to replace the right speaker in your iPad 8 LTE.
Note: this guide is for the LTE version only. For the Wi-Fi version, click here.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Some of the instructions in this guide were taken from a previous model. There are small differences between models, but the overall procedure is very similar.
Выберете то, что вам нужно
Heat an iOpener and apply it to the left edge of the device for two minutes.
While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
Front camera
Antennas
Display cables
Инструмент, используемый на этом этапе:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
Skip the next step.
Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
Insert an opening pick into the gap between the digitizer and the frame.
Insert a second opening pick into the gap you just created.
Slide the pick toward the bottom-left corner of the device to separate the adhesive.
Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
Heat an iOpener and apply it to the top edge of the device for two minutes.
Rotate the pick around the top-left corner of the device to separate the adhesive.
Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
Pull the pick out until only the tip is between the digitizer and the frame.
Slide the pick above the front camera to separate the adhesive.
Leave the pick near the right side of the front camera before continuing.
Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
Heat an iOpener and apply it to the right edge of the device for two minutes.
Rotate the pick around the top-right corner of the device to separate the adhesive.
Insert a new opening pick and slide it to the middle of the iPad's right edge.
Heat an iOpener and apply it to the bottom edge of the device for two minutes.
Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
Leave the pick in the corner before moving to the next step.
Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
Slide the pick over the antenna, stopping just before the home button.
Leave the pick to the left of the home button before continuing.
Insert an opening pick into the gap you just created.
Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
Leave the pick to the right of the home button before continuing.
Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers, or your fingers, to remove any tape covering the LCD screws.
Use a Phillips screwdriver to remove the four 4.3 mm screws securing the LCD screen.
Insert a spudger between the frame and the top-right portion of the LCD.
Pry slowly with the spudger to separate the adhesive.
Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
Leave the battery blocker in place as you work.
Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
Use tweezers, or your fingers, to remove the display cable bracket.
Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
Remove the vibration isolator.
Инструмент, используемый на этом этапе:Polyimide Tape$9.99
Remove the front panel assembly.
If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the SIM card reader cable ZIF connector.
Use a pair of tweezers to carefully pull the SIM card reader cable straight out of the ZIF connector.
Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
Continue to peel the right antenna cable away from the rear case until it's completely separated.
Use a Phillips screwdriver to remove the three screws securing the right antenna.
One 2.3 mm-long screw
Two 1.4 mm-long screws
Carefully insert an opening pick between the speaker enclosure and the bracket.
Slide the pick toward the charging port to cut the adhesive.
Push the bracket away from the speaker until it clears the tape underneath.
Insert an opening pick between the antenna and speaker assembly.
Slide the opening pick underneath the antenna to cut the foam adhesive.
Remove the right antenna.
Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
Reposition the left antenna cable out of the way.
Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the right speaker cable ZIF connector.
Use a pair of tweezers to carefully pull the right speaker cable straight out of the ZIF connector.
Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the right speaker.
Insert the flat end of a spudger into the groove in the speaker housing, near the corner of the rear case.
Push the speaker away from the rear case.
Push the speaker out from underneath the shelf on the rear case.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
