Введение
Follow this guide to replace the USB-C port on your iPad Pro 11" 1st gen.
If your battery is swollen, take appropriate precautions.
Some photos in this guide show the screen disconnected and fully removed. This isn't necessary for the procedure, so this guide skips those steps. If you wish to remove the screen, follow this guide.
Some photos show the battery connector blocked with two card strips. While this is an optional method, it's more reliable to fully discharge the battery. Ignore this visual discrepancy as you work through the guide.
Выберете то, что вам нужно
Unplug any cables and fully shut down your iPad.
Camera module, ambient light sensors, proximity senor, and front microphone
Display cables
Screen magnets
LCD edges
Apply a heated iOpener to the right edge of the screen for two minutes.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
Pull up on the suction handle with firm, constant pressure to create a gap large enough to insert an opening pick.
Insert the tip of an opening pick into the gap.
Insert a new opening pick in the gap you just created.
Slide the pick along the right edge to separate the adhesive.
Leave the pick in the top right corner to prevent the adhesive from re-sealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
Insert a new opening pick to the right of the ambient light sensor.
Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
Leave the pick in to prevent the adhesive from re-sealing.
Insert a new opening pick to the left of the ambient light sensor.
Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a new opening pick in the bottom right corner below the existing pick.
Slide the pick around the bottom right corner to separate the adhesive.
Slide the opening pick along the bottom edge, stopping at the USB-C port.
Leave the pick in to prevent the bottom edge adhesive from re-sealing.
Insert a new opening pick to the left of the USB-C port.
Separate the remaining bottom edge adhesive.
Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
There are flat sections of the frame which require an opening pick to be inserted horizontally.
Insert an opening pick at a 45˚ angle just above the bottom left corner.
Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
Lower the opening pick so it is horizontal to the screen.
Continue separating the left edge adhesive until you reach the next indented section of the frame.
Separate the remaining adhesive, making sure to follow the instructions exactly as written.
Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
Slide the pick horizontally and don't insert the pick more than 5 mm.
Grab two opposing corners of the screen and gently separate the rest of the adhesive.
Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
Инструмент, используемый на этом этапе:FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
One 1.3 mm screw
One 2.0 mm screw
Use tweezers or your fingers to remove the bracket.
Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connector.
Grip the right edge of the screen and fold it open like a book.
Lay the screen down over the left edge of the iPad.
Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
Use tweezers or your fingers to remove the bottom cable shield.
Use the flat end of a spudger to disconnect the USB-C port cable.
Slide an opening pick between the cable and the logic board to separate the adhesive.
Use a Phillips screwdriver to remove the two 1.9 mm screws securing the USB-C port to the frame.
Use tweezers to remove the two grounding contacts from each side of the USB-C port.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 1st Gen answers community for help.
5 участников успешно повторили данное руководство.
2 Комментариев
Left side of the screen display cables are EXTREMELY fragile. I am an experienced iPad tech and have worked on literally thousands of iPads. Did my first iPad Pro 11 1st gen today and ended up with a black line across the LCD.
Reversing the whole heating the adhesive part is pretty easy--it sort of does that on its own. But, putting the kit back together so it stays that way probably is a bit more than just "follow these instructions in reverse order." Simply hitting "reverse" on the hair drier, for example, will not get the adhesive to hold the edges in place.
