iPhone 11 Logic Board Replacement
Выберете то, что вам нужно
Видеообзор
  1. iPhone 11 Logic Board Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 11 Logic Board Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 11 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 11 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 11 Logic Board Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 11 Logic Board Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 11 Logic Board Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 11 Logic Board Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Спросите у FixBot
  4. iPhone 11 Logic Board Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 11 Logic Board Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 11 Logic Board Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 11 Logic Board Replacement: шаг 5, изображение 1 из 3 iPhone 11 Logic Board Replacement: шаг 5, изображение 2 из 3 iPhone 11 Logic Board Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  6. iPhone 11 Logic Board Replacement: шаг 6, изображение 1 из 3 iPhone 11 Logic Board Replacement: шаг 6, изображение 2 из 3 iPhone 11 Logic Board Replacement: шаг 6, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  7. iPhone 11 Logic Board Replacement, Heat the lower edge of the phone: шаг 7, изображение 1 из 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
    Спросите у FixBot
  8. iPhone 11 Logic Board Replacement: шаг 8, изображение 1 из 2 iPhone 11 Logic Board Replacement: шаг 8, изображение 2 из 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    Спросите у FixBot
  9. iPhone 11 Logic Board Replacement, Lift the display slightly: шаг 9, изображение 1 из 3 iPhone 11 Logic Board Replacement, Lift the display slightly: шаг 9, изображение 2 из 3 iPhone 11 Logic Board Replacement, Lift the display slightly: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  10. iPhone 11 Logic Board Replacement, Separate the screen adhesive: шаг 10, изображение 1 из 3 iPhone 11 Logic Board Replacement, Separate the screen adhesive: шаг 10, изображение 2 из 3 iPhone 11 Logic Board Replacement, Separate the screen adhesive: шаг 10, изображение 3 из 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Спросите у FixBot
  11. iPhone 11 Logic Board Replacement, Screen information: шаг 11, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  12. iPhone 11 Logic Board Replacement: шаг 12, изображение 1 из 3 iPhone 11 Logic Board Replacement: шаг 12, изображение 2 из 3 iPhone 11 Logic Board Replacement: шаг 12, изображение 3 из 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  13. iPhone 11 Logic Board Replacement: шаг 13, изображение 1 из 3 iPhone 11 Logic Board Replacement: шаг 13, изображение 2 из 3 iPhone 11 Logic Board Replacement: шаг 13, изображение 3 из 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
    Спросите у FixBot
  14. iPhone 11 Logic Board Replacement: шаг 14, изображение 1 из 2 iPhone 11 Logic Board Replacement: шаг 14, изображение 2 из 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
    Спросите у FixBot
  15. iPhone 11 Logic Board Replacement, Remove the suction cup: шаг 15, изображение 1 из 1
    • Pull the small nub on the suction cup to detach it from the front panel.
    Спросите у FixBot
  16. iPhone 11 Logic Board Replacement, Open the iPhone: шаг 16, изображение 1 из 3 iPhone 11 Logic Board Replacement, Open the iPhone: шаг 16, изображение 2 из 3 iPhone 11 Logic Board Replacement, Open the iPhone: шаг 16, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    Спросите у FixBot
  17. iPhone 11 Logic Board Replacement, Display Assembly: шаг 17, изображение 1 из 2 iPhone 11 Logic Board Replacement, Display Assembly: шаг 17, изображение 2 из 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    Спросите у FixBot
  18. iPhone 11 Logic Board Replacement, Unscrew the battery connector cover: шаг 18, изображение 1 из 2 iPhone 11 Logic Board Replacement, Unscrew the battery connector cover: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Спросите у FixBot
  19. iPhone 11 Logic Board Replacement, Remove the battery connector cover: шаг 19, изображение 1 из 1
    • Remove the bracket.
    Спросите у FixBot
  20. iPhone 11 Logic Board Replacement, Disconnect the battery: шаг 20, изображение 1 из 2 iPhone 11 Logic Board Replacement, Disconnect the battery: шаг 20, изображение 2 из 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
    Спросите у FixBot
  21. iPhone 11 Logic Board Replacement, Unscrew the logic board cover screws: шаг 21, изображение 1 из 2 iPhone 11 Logic Board Replacement, Unscrew the logic board cover screws: шаг 21, изображение 2 из 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
    Спросите у FixBot
  22. iPhone 11 Logic Board Replacement, Remove the logic board cover bracket: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 11 Logic Board Replacement, Disconnect the display: шаг 23, изображение 1 из 3 iPhone 11 Logic Board Replacement, Disconnect the display: шаг 23, изображение 2 из 3 iPhone 11 Logic Board Replacement, Disconnect the display: шаг 23, изображение 3 из 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
    Спросите у FixBot
  24. iPhone 11 Logic Board Replacement, Disconnect the front sensors: шаг 24, изображение 1 из 2 iPhone 11 Logic Board Replacement, Disconnect the front sensors: шаг 24, изображение 2 из 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    Спросите у FixBot
  25. iPhone 11 Logic Board Replacement, Remove the display assembly: шаг 25, изображение 1 из 1
    Спросите у FixBot
  26. iPhone 11 Logic Board Replacement, Unscrew the rear camera cover: шаг 26, изображение 1 из 2 iPhone 11 Logic Board Replacement, Unscrew the rear camera cover: шаг 26, изображение 2 из 2
    • Remove the two Phillips screws securing the rear camera cover:
    • One 1.4 mm screw
    • One 1.3 mm screw
    Спросите у FixBot
  27. iPhone 11 Logic Board Replacement, Remove the camera cover: шаг 27, изображение 1 из 3 iPhone 11 Logic Board Replacement, Remove the camera cover: шаг 27, изображение 2 из 3 iPhone 11 Logic Board Replacement, Remove the camera cover: шаг 27, изображение 3 из 3
    • Lift the camera cover from the edge closest to the battery, and remove it.
    • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
    • The cover only lays flat after the two tabs are seated correctly.
    Спросите у FixBot
  28. iPhone 11 Logic Board Replacement, Disconnect the cameras: шаг 28, изображение 1 из 3 iPhone 11 Logic Board Replacement, Disconnect the cameras: шаг 28, изображение 2 из 3 iPhone 11 Logic Board Replacement, Disconnect the cameras: шаг 28, изображение 3 из 3
    • Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
    Спросите у FixBot
  29. iPhone 11 Logic Board Replacement, Loosen the camera assembly: шаг 29, изображение 1 из 2 iPhone 11 Logic Board Replacement, Loosen the camera assembly: шаг 29, изображение 2 из 2
    • Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
    Спросите у FixBot
  30. iPhone 11 Logic Board Replacement: шаг 30, изображение 1 из 1
    • Remove the rear-facing camera assembly.
    Спросите у FixBot
  31. iPhone 11 Logic Board Replacement, Disconnect the Lightning port flex cable: шаг 31, изображение 1 из 2 iPhone 11 Logic Board Replacement, Disconnect the Lightning port flex cable: шаг 31, изображение 2 из 2
    • Use a spudger or a fingernail to pry up and disconnect the flex cable for the Lightning connector assembly.
    Спросите у FixBot
  32. iPhone 11 Logic Board Replacement, Remove three Phillips screws: шаг 32, изображение 1 из 3 iPhone 11 Logic Board Replacement, Remove three Phillips screws: шаг 32, изображение 2 из 3 iPhone 11 Logic Board Replacement, Remove three Phillips screws: шаг 32, изображение 3 из 3
    • Remove the three Phillips screws surrounding the SIM card reader:
    • One 1.5 mm screw
    • One 1.9 mm screw
    • One 1.6 mm screw securing a grounding bracket
    • Removing the grounding bracket secured by the final screw.
    Спросите у FixBot
  33. iPhone 11 Logic Board Replacement, Remove the standoff screw: шаг 33, изображение 1 из 2 iPhone 11 Logic Board Replacement, Remove the standoff screw: шаг 33, изображение 2 из 2
    • Use a standoff driver to remove the 3.1 mm screw securing the SIM card reader connector bracket.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage nearby components.
    Спросите у FixBot
  34. iPhone 11 Logic Board Replacement, Remove the SIM reader's connector bracket: шаг 34, изображение 1 из 2 iPhone 11 Logic Board Replacement, Remove the SIM reader's connector bracket: шаг 34, изображение 2 из 2
    • Remove the SIM reader's connector bracket.
    Спросите у FixBot
  35. iPhone 11 Logic Board Replacement, Disconnect the SIM card reader: шаг 35, изображение 1 из 2 iPhone 11 Logic Board Replacement, Disconnect the SIM card reader: шаг 35, изображение 2 из 2
    • While gently lifting the Lightning connector flex cable out of the way, use the point of a spudger to pry up and disconnect the SIM card reader flex cable.
    Спросите у FixBot
  36. iPhone 11 Logic Board Replacement, Push the SIM eject plunger aside: шаг 36, изображение 1 из 2 iPhone 11 Logic Board Replacement, Push the SIM eject plunger aside: шаг 36, изображение 2 из 2
    • Use the point of a spudger to push the SIM eject plunger out towards the edge of the phone.
    Спросите у FixBot
  37. iPhone 11 Logic Board Replacement, Remove the SIM reader: шаг 37, изображение 1 из 3 iPhone 11 Logic Board Replacement, Remove the SIM reader: шаг 37, изображение 2 из 3 iPhone 11 Logic Board Replacement, Remove the SIM reader: шаг 37, изображение 3 из 3
    • Lift the SIM card reader and slide it toward the outside edge of the iPhone.
    • Remove the SIM card reader.
    Спросите у FixBot
  38. iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: шаг 38, изображение 1 из 3 iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: шаг 38, изображение 2 из 3 iPhone 11 Logic Board Replacement, Disconnect the front camera assembly: шаг 38, изображение 3 из 3
    • Use a spudger or fingernail to disconnect the two front camera cable connectors by prying them from straight up from their sockets.
    Спросите у FixBot
  39. iPhone 11 Logic Board Replacement, Remove the front camera array: шаг 39, изображение 1 из 1
    • The front camera array houses the FaceID sensor, which is paired to the motherboard. If you use the front camera array that does not belong to its respective board, FaceID will not function. Make sure your logic board comes with its original front camera array if you want to retain FaceID functionality.
    • Remove the front camera assembly.
    Спросите у FixBot
  40. iPhone 11 Logic Board Replacement, Remove the standoff screws: шаг 40, изображение 1 из 1
    • Remove the two 3.2 mm standoff screws.
    Спросите у FixBot
  41. iPhone 11 Logic Board Replacement: шаг 41, изображение 1 из 2 iPhone 11 Logic Board Replacement: шаг 41, изображение 2 из 2
    • Remove the upper cable bracket.
    Спросите у FixBot
  42. iPhone 11 Logic Board Replacement, Disconnect upper cables: шаг 42, изображение 1 из 3 iPhone 11 Logic Board Replacement, Disconnect upper cables: шаг 42, изображение 2 из 3 iPhone 11 Logic Board Replacement, Disconnect upper cables: шаг 42, изображение 3 из 3
    • Use a spudger to disconnect the cable connectors for the volume, power, and silent switch.
    Спросите у FixBot
  43. iPhone 11 Logic Board Replacement, Disconnect the charging connectors: шаг 43, изображение 1 из 3 iPhone 11 Logic Board Replacement, Disconnect the charging connectors: шаг 43, изображение 2 из 3 iPhone 11 Logic Board Replacement, Disconnect the charging connectors: шаг 43, изображение 3 из 3
    • Use a spudger to disconnect the cable connectors for the lighting port and wireless charging coil.
    Спросите у FixBot
  44. iPhone 11 Logic Board Replacement: шаг 44, изображение 1 из 1
    • Carefully remove the logic board from the phone chassis.
    • Be careful not to snag the logic board on any cables.
    Спросите у FixBot
Заключение
55 человек успешно провели ремонт по этому руководству.
Arty
Участник с: 10/27/19
33 475 Репутация
Автор 110 руководств
20 Комментарии к руководству
Nice beakdown! Might also use post-processing on stopping point above video view over main pcb to highlight screw location with color coding
26nn - Ответить Поделиться
Thanks for the recommendation, I’ll take this into account in the following videos.
Arty - Ответить Поделиться
where can I buy a logic board for an Iphone 11
Cassie Srubar - Ответить Поделиться
Try AliExpress or eBay
Lawson Glomski - Ответить Поделиться
Top, explications claires. Merci pour votre vidéo.
Manar Maiti - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 37
За последние 7 дней: 281
За последние 30 дней: 1,401
За всё время: 94,093
