iPhone 13 Pro Lidar Sensor Replacement
Выберете то, что вам нужно
  1. iPhone 13 Pro Lidar Sensor Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Pro Lidar Sensor Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Ответить
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Ответить
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Ответить
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Ответить
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Ответить
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Ответить
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Ответить
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Ответить
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Ответить
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Ответить
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Ответить
  3. iPhone 13 Pro Lidar Sensor Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Pro Lidar Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 13 Pro Lidar Sensor Replacement: шаг 5, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement: шаг 5, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Pro Lidar Sensor Replacement: шаг 6, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement: шаг 6, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement: шаг 6, изображение 3 из 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  7. iPhone 13 Pro Lidar Sensor Replacement, Heat the bottom edge: шаг 7, изображение 1 из 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Pro Lidar Sensor Replacement, Insert an opening pick: шаг 8, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Insert an opening pick: шаг 8, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Insert an opening pick: шаг 8, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    By far the hardest part. It really does take a lot of heat and force to get it lifted enough to insert the pick.
    Tarrot The Human - Ответить
  9. iPhone 13 Pro Lidar Sensor Replacement, Heat the right edge: шаг 9, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Heat the right edge: шаг 9, изображение 2 из 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 13 Pro Lidar Sensor Replacement, Separate the right adhesive: шаг 10, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Separate the right adhesive: шаг 10, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Separate the right adhesive: шаг 10, изображение 3 из 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 13 Pro Lidar Sensor Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 13 Pro Lidar Sensor Replacement, Separate the top adhesive: шаг 12, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Separate the top adhesive: шаг 12, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Separate the top adhesive: шаг 12, изображение 3 из 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 13 Pro Lidar Sensor Replacement, Heat the left edge: шаг 13, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Heat the left edge: шаг 13, изображение 2 из 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    Make sure you read steps 14 and 15 before using the opening pick. I tried inserting a pick from top to bottom, and cracked it. You must insert two, one from the top and one from the bottom, as per step 15.
    Daniel Carley - Ответить
  14. iPhone 13 Pro Lidar Sensor Replacement, Screen information: шаг 14, изображение 1 из 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 13 Pro Lidar Sensor Replacement, Separate the left adhesive: шаг 15, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Separate the left adhesive: шаг 15, изображение 2 из 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 13 Pro Lidar Sensor Replacement, Open the iPhone: шаг 16, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Open the iPhone: шаг 16, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Open the iPhone: шаг 16, изображение 3 из 3
    • Remove your suction handle from the screen.
    • Rotate your iPhone so the right edge faces you.
    • Open your iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 13 Pro Lidar Sensor Replacement, Remove the battery connector cover: шаг 17, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the three 1.3 mm screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 13 Pro Lidar Sensor Replacement: шаг 18, изображение 1 из 1
    • Remove the battery connector cover.
  19. iPhone 13 Pro Lidar Sensor Replacement, Disconnect the battery: шаг 19, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Disconnect the battery: шаг 19, изображение 2 из 2
    • Use the pointed end a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 13 Pro Lidar Sensor Replacement, Disconnect the display cable: шаг 20, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Disconnect the display cable: шаг 20, изображение 2 из 2
    • Use the pointed end of a spudger or a clean fingernail to pry the display connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 13 Pro Lidar Sensor Replacement, Unscrew the front sensor connector cover: шаг 21, изображение 1 из 1
    • Use a Y000 screwdriver to remove two 1.1 mm screws from the front sensor connector cover.
    • Use a Phillips screwdriver to remove the remaining two screws from the cover:
    • One 1.5 mm screw
    • One 1.8 mm screw
  22. iPhone 13 Pro Lidar Sensor Replacement: шаг 22, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement: шаг 22, изображение 2 из 2
    • Remove the front sensor connector cover.
  23. iPhone 13 Pro Lidar Sensor Replacement: шаг 23, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement: шаг 23, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the front sensor assembly cable connector.
  24. iPhone 13 Pro Lidar Sensor Replacement: шаг 24, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement: шаг 24, изображение 2 из 2
  25. iPhone 13 Pro Lidar Sensor Replacement, Unscrew the camera cover: шаг 25, изображение 1 из 1
    • Use a Y000 driver to remove the four screws securing the rear-facing camera sensor cover:
    • Three 1.4 mm screws
    • One 1.3 mm screw
    • Use a Phillips screwdriver to remove one 1.6 mm screw.
  26. iPhone 13 Pro Lidar Sensor Replacement, Remove the camera cover: шаг 26, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Remove the camera cover: шаг 26, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Remove the camera cover: шаг 26, изображение 3 из 3
    • Lift the camera cover from the edge closest to the logic board, and remove it.
  27. iPhone 13 Pro Lidar Sensor Replacement, Reassembly tip: шаг 27, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Reassembly tip: шаг 27, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Reassembly tip: шаг 27, изображение 3 из 3
    • When reinstalling the camera module cover, ensure the lip along the right edge slides underneath the phone's chassis.
  28. iPhone 13 Pro Lidar Sensor Replacement, Disconnect the camera assembly: шаг 28, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Disconnect the camera assembly: шаг 28, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Disconnect the camera assembly: шаг 28, изображение 3 из 3
    • Pry up with the pointed end of a spudger to disconnect the two camera cables from the logic board.
  29. iPhone 13 Pro Lidar Sensor Replacement, Remove the rear-facing cameras: шаг 29, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Remove the rear-facing cameras: шаг 29, изображение 2 из 2
    • Use the tip of a spudger to lift the camera assembly out of the iPhone.
  30. iPhone 13 Pro Lidar Sensor Replacement: шаг 30, изображение 1 из 1
    • Remove the rear-facing cameras.
    There's a piece of glue that sticks the cable (the grey, metal looking piece on the top right shown in the picture) to the back of the LIDAR sensor. A bit of slicing may be required.
    aquila_zyy - Ответить
  31. iPhone 13 Pro Lidar Sensor Replacement, Reassembly tips: шаг 31, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Reassembly tips: шаг 31, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Reassembly tips: шаг 31, изображение 3 из 3
    • During reassembly, you'll need to insert the two camera assembly cables into the gap between the upper battery wall and lower camera wall.
  32. iPhone 13 Pro Lidar Sensor Replacement, Remove the lidar cover: шаг 32, изображение 1 из 1
    • Use a Y000 screwdriver to remove the three screws from the lidar cover:
    • Two 1.4 mm screws
    • One 1.3 mm screw
  33. iPhone 13 Pro Lidar Sensor Replacement: шаг 33, изображение 1 из 1
    • Remove the lidar cover.
  34. iPhone 13 Pro Lidar Sensor Replacement, Disconnect the lidar cable: шаг 34, изображение 1 из 2 iPhone 13 Pro Lidar Sensor Replacement, Disconnect the lidar cable: шаг 34, изображение 2 из 2
    • Use the pointed tip of a spudger to disconnect the lidar cable from the logic board.
  35. iPhone 13 Pro Lidar Sensor Replacement, Remove the lidar sensor: шаг 35, изображение 1 из 3 iPhone 13 Pro Lidar Sensor Replacement, Remove the lidar sensor: шаг 35, изображение 2 из 3 iPhone 13 Pro Lidar Sensor Replacement, Remove the lidar sensor: шаг 35, изображение 3 из 3
    • Use the pointed tip of a spudger to lift the lidar sensor up out from the chassis and remove it.
    I’ve a question. Isn’t the different serial a problem? Will it work if I replace the LiDAR sensor of my iPhone 13 Pro?
    Piereligio Di Sante - Ответить
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Pro Answers community for help.
9 человек успешно провели ремонт по этому руководству.
Sam Omiotek
Участник с: 02/25/19
84 611 Репутация
Автор 290 руководств
Один комментарий
It's good to note the LiDAR Scanner is tied to the motherboard and there seems to be no way to pair a new one, so if you replace it, it won't work
Nar001 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 14
За последние 7 дней: 95
За последние 30 дней: 434
За всё время: 13,668
