iPhone 14 Battery Replacement
Выберете то, что вам нужно
  1. iPhone 14 Battery Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 14 Battery Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 14 Battery Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 14 Battery Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 14 Battery Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 14 Battery Replacement, Tape over any cracks: шаг 3, изображение 1 из 2 iPhone 14 Battery Replacement, Tape over any cracks: шаг 3, изображение 2 из 2
    • If your iPhone has a cracked rear glass, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
    • If all else fails, you can superglue the suction cup to the rear glass.
    Спросите у FixBot
  4. iPhone 14 Battery Replacement, Heat the bottom edge: шаг 4, изображение 1 из 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
    • Never leave your heat gun in one spot for an extended period of time.
    Спросите у FixBot
  5. iPhone 14 Battery Replacement, Insert an opening pick: шаг 5, изображение 1 из 3 iPhone 14 Battery Replacement, Insert an opening pick: шаг 5, изображение 2 из 3 iPhone 14 Battery Replacement, Insert an opening pick: шаг 5, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
    Спросите у FixBot
  6. iPhone 14 Battery Replacement, Heat the left edge: шаг 6, изображение 1 из 1
    • Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
    Спросите у FixBot
  7. iPhone 14 Battery Replacement, Slice the left edge adhesive: шаг 7, изображение 1 из 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: шаг 7, изображение 2 из 3 iPhone 14 Battery Replacement, Slice the left edge adhesive: шаг 7, изображение 3 из 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    Спросите у FixBot
  8. iPhone 14 Battery Replacement, Rear glass information: шаг 8, изображение 1 из 1
    • There's a delicate cable along the right edge, next to the volume up button. Don't insert your pick here, as you may damage the cable.
    Спросите у FixBot
  9. iPhone 14 Battery Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
    Спросите у FixBot
  10. iPhone 14 Battery Replacement, Slice the right edge adhesive: шаг 10, изображение 1 из 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: шаг 10, изображение 2 из 3 iPhone 14 Battery Replacement, Slice the right edge adhesive: шаг 10, изображение 3 из 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the charging coil cable.
    Спросите у FixBot
  11. iPhone 14 Battery Replacement, Heat the top edge: шаг 11, изображение 1 из 1
    • Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
    Спросите у FixBot
  12. iPhone 14 Battery Replacement, Slice the top edge adhesive: шаг 12, изображение 1 из 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: шаг 12, изображение 2 из 3 iPhone 14 Battery Replacement, Slice the top edge adhesive: шаг 12, изображение 3 из 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
    Спросите у FixBot
  13. iPhone 14 Battery Replacement: шаг 13, изображение 1 из 3 iPhone 14 Battery Replacement: шаг 13, изображение 2 из 3 iPhone 14 Battery Replacement: шаг 13, изображение 3 из 3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm, as you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
    Спросите у FixBot
  14. iPhone 14 Battery Replacement, Open the iPhone: шаг 14, изображение 1 из 3 iPhone 14 Battery Replacement, Open the iPhone: шаг 14, изображение 2 из 3 iPhone 14 Battery Replacement, Open the iPhone: шаг 14, изображение 3 из 3
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
    Спросите у FixBot
  15. iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: шаг 15, изображение 1 из 2 iPhone 14 Battery Replacement, Unfasten the battery connector cover screws: шаг 15, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Спросите у FixBot
  16. iPhone 14 Battery Replacement, Remove the battery connector cover: шаг 16, изображение 1 из 3 iPhone 14 Battery Replacement, Remove the battery connector cover: шаг 16, изображение 2 из 3 iPhone 14 Battery Replacement, Remove the battery connector cover: шаг 16, изображение 3 из 3
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
    Спросите у FixBot
  17. iPhone 14 Battery Replacement, Disconnect the battery: шаг 17, изображение 1 из 2 iPhone 14 Battery Replacement, Disconnect the battery: шаг 17, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Спросите у FixBot
  18. iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: шаг 18, изображение 1 из 2 iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: шаг 18, изображение 2 из 2
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
    Спросите у FixBot
  19. iPhone 14 Battery Replacement, Remove the charging coil connector bracket: шаг 19, изображение 1 из 2 iPhone 14 Battery Replacement, Remove the charging coil connector bracket: шаг 19, изображение 2 из 2
    • Use a pair of tweezers to remove the charging coil connector cover.
    Спросите у FixBot
  20. iPhone 14 Battery Replacement, Disconnect the charging coil: шаг 20, изображение 1 из 2 iPhone 14 Battery Replacement, Disconnect the charging coil: шаг 20, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
    Спросите у FixBot
  21. iPhone 14 Battery Replacement, Remove the rear glass assembly: шаг 21, изображение 1 из 2 iPhone 14 Battery Replacement, Remove the rear glass assembly: шаг 21, изображение 2 из 2
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
    Спросите у FixBot
  22. iPhone 14 Battery Replacement, Locate the adhesive pull-tabs: шаг 22, изображение 1 из 1
    • Two stretch adhesive strips secure the battery to the case. They're both accessed from the top edge of the battery.
    • Each adhesive strip has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
    Спросите у FixBot
  23. iPhone 14 Battery Replacement, Remove the stretch-release adhesive: шаг 23, изображение 1 из 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: шаг 23, изображение 2 из 3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: шаг 23, изображение 3 из 3
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Use a pair of blunt-nosed tweezers to peel up the two battery adhesive pull-tabs along the top edge of the battery.
    Спросите у FixBot
  24. iPhone 14 Battery Replacement: шаг 24, изображение 1 из 3 iPhone 14 Battery Replacement: шаг 24, изображение 2 из 3 iPhone 14 Battery Replacement: шаг 24, изображение 3 из 3
    • Grab the first pull-tab with your fingers or wrap it around a spudger and slowly pull it away from the battery, toward the top of the iPhone.
    • Pull out hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery but hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strip, and then proceed as instructed below.
    Спросите у FixBot
  25. iPhone 14 Battery Replacement: шаг 25, изображение 1 из 3 iPhone 14 Battery Replacement: шаг 25, изображение 2 из 3 iPhone 14 Battery Replacement: шаг 25, изображение 3 из 3
    • Grab the second pull-tab with your fingers or the center of a spudger and pull it away from the battery, toward the top of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
    Спросите у FixBot
  26. iPhone 14 Battery Replacement, How to remove a stuck battery: шаг 26, изображение 1 из 3 iPhone 14 Battery Replacement, How to remove a stuck battery: шаг 26, изображение 2 из 3 iPhone 14 Battery Replacement, How to remove a stuck battery: шаг 26, изображение 3 из 3
    • If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    Спросите у FixBot
  27. iPhone 14 Battery Replacement, Remove the battery: шаг 27, изображение 1 из 2 iPhone 14 Battery Replacement, Remove the battery: шаг 27, изображение 2 из 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
    Спросите у FixBot
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
60 человек успешно провели ремонт по этому руководству.
Tobias Isakeit
Участник с: 03/31/14
134 195 Репутация
Автор 189 руководств
13 Комментарии к руководству
Salut.
Je veux savoir plus de cette formation dépannage.
cfas fix - Ответить Поделиться
this is iPhone 14, title error, not iPhone 14 Pro
Wells Zhang - Ответить Поделиться
I think this guide is wrong -- my iPhone 14 has a metal plate inside, covering the battery. The iPhone 14 screen replacement guide appears to be correct, though.
Olivia Farmen - Ответить Поделиться
U must go to trainning first
bakri hamid - Ответить Поделиться
U must going to technical training first
Статистика просмотров:
За последние 24 часов: 423
За последние 7 дней: 2,891
За последние 30 дней: 12,271
За всё время: 242,224
