iPhone 15 Pro Battery Replacement
Выберете то, что вам нужно
  1. iPhone 15 Pro Battery Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Prepare your iPhone for disassembly: шаг 1, изображение 2 из 2
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
  2. iPhone 15 Pro Battery Replacement, Tape over any cracks: шаг 2, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Tape over any cracks: шаг 2, изображение 2 из 2
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Battery Replacement, Mark your opening picks: шаг 3, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Mark your opening picks: шаг 3, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Mark your opening picks: шаг 3, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Pro Battery Replacement, Remove the pentalobe screws: шаг 4, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Remove the pentalobe screws: шаг 4, изображение 2 из 2
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Battery Replacement, Heat the bottom edge: шаг 5, изображение 1 из 1
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Battery Replacement, Insert an opening pick: шаг 6, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Insert an opening pick: шаг 6, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Insert an opening pick: шаг 6, изображение 3 из 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Battery Replacement, Screen information: шаг 7, изображение 1 из 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: шаг 8, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: шаг 8, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Separate the bottom edge adhesive: шаг 8, изображение 3 из 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Battery Replacement, Heat the right edge: шаг 9, изображение 1 из 1
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Battery Replacement, Position the opening pick: шаг 10, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Position the opening pick: шаг 10, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Position the opening pick: шаг 10, изображение 3 из 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Battery Replacement, Release the right clip: шаг 11, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Release the right clip: шаг 11, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Release the right clip: шаг 11, изображение 3 из 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: шаг 12, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: шаг 12, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Separate the right edge adhesive: шаг 12, изображение 3 из 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Battery Replacement, Heat the top edge: шаг 13, изображение 1 из 1
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: шаг 14, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: шаг 14, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Separate the top edge adhesive: шаг 14, изображение 3 из 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Battery Replacement, Heat the left edge: шаг 15, изображение 1 из 1
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: шаг 16, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: шаг 16, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Separate the left edge adhesive: шаг 16, изображение 3 из 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Battery Replacement, Prop up the screen: шаг 17, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Prop up the screen: шаг 17, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Prop up the screen: шаг 17, изображение 3 из 3
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
  18. iPhone 15 Pro Battery Replacement, Unfasten the logic board cover: шаг 18, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Unfasten the logic board cover: шаг 18, изображение 2 из 2
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  19. iPhone 15 Pro Battery Replacement, Remove the logic board cover: шаг 19, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Remove the logic board cover: шаг 19, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Remove the logic board cover: шаг 19, изображение 3 из 3
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
  20. iPhone 15 Pro Battery Replacement, Disconnect the battery: шаг 20, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Disconnect the battery: шаг 20, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Disconnect the battery: шаг 20, изображение 3 из 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Pro Battery Replacement, Disconnect the screen: шаг 21, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Disconnect the screen: шаг 21, изображение 2 из 2
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
  22. iPhone 15 Pro Battery Replacement, Disconnect the ambient light sensor: шаг 22, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Disconnect the ambient light sensor: шаг 22, изображение 2 из 2
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
  23. iPhone 15 Pro Battery Replacement, Remove the screen: шаг 23, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Remove the screen: шаг 23, изображение 2 из 2
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  24. iPhone 15 Pro Battery Replacement, Unfasten the loudspeaker: шаг 24, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Unfasten the loudspeaker: шаг 24, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the loudspeaker:
    • One 2.7 mm‑long screw
    • Three 2 mm‑long screws
  25. iPhone 15 Pro Battery Replacement, Remove the loudspeaker: шаг 25, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Remove the loudspeaker: шаг 25, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Remove the loudspeaker: шаг 25, изображение 3 из 3
    • A plastic buffer is adhered to the top edges of the loudspeaker and Taptic Engine.
    • Lift the bottom edge of the loudspeaker until you can grab it with your fingers.
    • Peel the loudspeaker from the plastic buffer on its top edge and remove it.
  26. iPhone 15 Pro Battery Replacement, Disconnect the Taptic Engine: шаг 26, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Disconnect the Taptic Engine: шаг 26, изображение 2 из 2
    • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
  27. iPhone 15 Pro Battery Replacement, Unfasten the Taptic Engine: шаг 27, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Unfasten the Taptic Engine: шаг 27, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the two 2 mm‑long screws securing the Taptic Engine.
  28. iPhone 15 Pro Battery Replacement, Remove the Taptic Engine: шаг 28, изображение 1 из 1
    • Remove the Taptic Engine.
  29. iPhone 15 Pro Battery Replacement, Adhesive information: шаг 29, изображение 1 из 1
    • Three sections of stretch release adhesive secure the battery to the frame—two along the bottom and one on top.
    • Each strip has a black pull tab at its end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab out from underneath the battery.
    • The strips loosen when stretched, but might break off before you can fully remove them, especially the top edge strip. If any break, don't worry! Keep reading for an alternate way to remove the battery.
  30. iPhone 15 Pro Battery Replacement, Separate the pull tabs: шаг 30, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Separate the pull tabs: шаг 30, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Separate the pull tabs: шаг 30, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Don't puncture or dent the battery with your tool, as it can leak dangerous chemicals or catch fire if damaged.
    • Use the tip of an opening pick to gently unstick an edge of an adhesive pull tab from the edge of the battery.
    • Use blunt nose tweezers to grip the edge of the pull tab and pull it completely off the edge of the battery.
    • Repeat for the other two pull tabs.
  31. iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: шаг 31, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: шаг 31, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Remove the stretch release adhesive: шаг 31, изображение 3 из 3
    • Pull one of the pull tabs out from under the battery until you can grip it with your fingers or wrap it around your tool.
    • Hold the phone steady using the edges of the frame—don't press down on the battery.
    • Pull the strip slowly, evenly, and at a low angle without dragging on other components.
    • Continue pulling, re-gripping or wrapping it around your tool as you go, until the strip fully releases from under the battery.
    • If the strip breaks off, try to retrieve it. If you can't grip it from under the battery, move on to the next step.
    • Repeat this step for the other two strips.
  32. iPhone 15 Pro Battery Replacement, Alternate method to remove the battery: шаг 32, изображение 1 из 2 iPhone 15 Pro Battery Replacement, Alternate method to remove the battery: шаг 32, изображение 2 из 2
    • If you removed all three stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next two steps to separate the adhesive with isopropyl alcohol and a plastic card.
    • If the top strip remains, prop up the top edge of the phone.
    • If either of the bottom strips remain, prop up the left edge of the phone (the side with the volume buttons).
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the elevated edge of the battery.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
  33. iPhone 15 Pro Battery Replacement, Pry up the battery: шаг 33, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Pry up the battery: шаг 33, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Pry up the battery: шаг 33, изображение 3 из 3
    Plastic Cards
    $2.99
    • Don't bend or crease your battery. If the adhesive feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Insert the short edge of a plastic card between the bottom edge of the battery and the frame.
    • Be careful not to scrape the frame underneath the battery—the wireless charging coil is exposed near the center.
    • Gently pry up the battery until the adhesive fully separates.
    • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
  34. iPhone 15 Pro Battery Replacement, Remove the battery: шаг 34, изображение 1 из 3 iPhone 15 Pro Battery Replacement, Remove the battery: шаг 34, изображение 2 из 3 iPhone 15 Pro Battery Replacement, Remove the battery: шаг 34, изображение 3 из 3
    Stretch Release Battery Adhesive
    $3.99
    • Remove the battery.
    • To install a new battery:
    • Clean your frame with isopropyl alcohol and a lint-free or microfiber cloth.
    • Before applying adhesive, temporarily reconnect your new battery and place it in its recess to check if it fits and that the cable reaches the socket on the logic board. Disconnect the battery before continuing.
    • Check out this guide to apply new stretch release adhesive strips to your battery, if it doesn't already come with adhesive installed.
    • If you don't have stretch release adhesive, use thin, double-sided tape to secure it.
Заключение
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
17 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
158 120 Репутация
Автор 1 043 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 886 руководств
3 Комментарии к руководству
Exelente tutorial , gracias
Miguel Rincon - Ответить
the hardest part of this repair was definitely removing the old glue, it made me lose my mind, the rest was easy
Carlo Bückert - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 256
За последние 7 дней: 2,016
За последние 30 дней: 7,595
За всё время: 87,333
