iPhone 7 Power and Volume Control Cable Replacement
Выберете то, что вам нужно
  1. iPhone 7 Power and Volume Control Cable Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 7 Power and Volume Control Cable Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 7 Power and Volume Control Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  4. iPhone 7 Power and Volume Control Cable Replacement: шаг 4, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 4, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  5. iPhone 7 Power and Volume Control Cable Replacement: шаг 5, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  6. iPhone 7 Power and Volume Control Cable Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  7. iPhone 7 Power and Volume Control Cable Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  8. iPhone 7 Power and Volume Control Cable Replacement: шаг 8, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 8, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  9. iPhone 7 Power and Volume Control Cable Replacement: шаг 9, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 9, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Спросите у FixBot
  10. iPhone 7 Power and Volume Control Cable Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  11. iPhone 7 Power and Volume Control Cable Replacement: шаг 11, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 11, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  12. iPhone 7 Power and Volume Control Cable Replacement: шаг 12, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  13. iPhone 7 Power and Volume Control Cable Replacement: шаг 13, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 13, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  14. iPhone 7 Power and Volume Control Cable Replacement: шаг 14, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  15. iPhone 7 Power and Volume Control Cable Replacement: шаг 15, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 15, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  16. iPhone 7 Power and Volume Control Cable Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
    Спросите у FixBot
  17. iPhone 7 Power and Volume Control Cable Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
    Спросите у FixBot
  18. iPhone 7 Power and Volume Control Cable Replacement: шаг 18, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 18, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Спросите у FixBot
  19. iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Спросите у FixBot
  20. iPhone 7 Power and Volume Control Cable Replacement: шаг 20, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 20, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Спросите у FixBot
  21. iPhone 7 Power and Volume Control Cable Replacement: шаг 21, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Спросите у FixBot
  22. iPhone 7 Power and Volume Control Cable Replacement: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 7 Power and Volume Control Cable Replacement, SIM Card: шаг 23, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement, SIM Card: шаг 23, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement, SIM Card: шаг 23, изображение 3 из 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Спросите у FixBot
  24. iPhone 7 Power and Volume Control Cable Replacement, Logic Board Connectors: шаг 24, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement, Logic Board Connectors: шаг 24, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    Спросите у FixBot
  25. iPhone 7 Power and Volume Control Cable Replacement: шаг 25, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 25, изображение 2 из 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    Спросите у FixBot
  26. iPhone 7 Power and Volume Control Cable Replacement: шаг 26, изображение 1 из 1
    • Remove the bracket.
    Спросите у FixBot
  27. iPhone 7 Power and Volume Control Cable Replacement: шаг 27, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 27, изображение 2 из 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    Спросите у FixBot
  28. iPhone 7 Power and Volume Control Cable Replacement: шаг 28, изображение 1 из 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    Спросите у FixBot
  29. iPhone 7 Power and Volume Control Cable Replacement: шаг 29, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 29, изображение 2 из 2
    • Remove the upper cable bracket.
    Спросите у FixBot
  30. iPhone 7 Power and Volume Control Cable Replacement: шаг 30, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 30, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
    Спросите у FixBot
  31. iPhone 7 Power and Volume Control Cable Replacement: шаг 31, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 31, изображение 2 из 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    Спросите у FixBot
  32. iPhone 7 Power and Volume Control Cable Replacement: шаг 32, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 32, изображение 2 из 2
    • Remove the top left antenna.
    Спросите у FixBot
  33. iPhone 7 Power and Volume Control Cable Replacement: шаг 33, изображение 1 из 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    Спросите у FixBot
  34. iPhone 7 Power and Volume Control Cable Replacement: шаг 34, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 34, изображение 2 из 2
    Спросите у FixBot
  35. iPhone 7 Power and Volume Control Cable Replacement: шаг 35, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Спросите у FixBot
  36. iPhone 7 Power and Volume Control Cable Replacement: шаг 36, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 36, изображение 2 из 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    Спросите у FixBot
  37. iPhone 7 Power and Volume Control Cable Replacement, Logic Board: шаг 37, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement, Logic Board: шаг 37, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement, Logic Board: шаг 37, изображение 3 из 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Спросите у FixBot
  38. iPhone 7 Power and Volume Control Cable Replacement: шаг 38, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 38, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 38, изображение 3 из 3
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
    Спросите у FixBot
  39. iPhone 7 Power and Volume Control Cable Replacement: шаг 39, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 39, изображение 2 из 2
    • Use the point of a spudger to disconnect the lower cable connector.
    Спросите у FixBot
  40. iPhone 7 Power and Volume Control Cable Replacement: шаг 40, изображение 1 из 1
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using a standoff driver.
    Спросите у FixBot
  41. iPhone 7 Power and Volume Control Cable Replacement: шаг 41, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 41, изображение 2 из 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    Спросите у FixBot
  42. iPhone 7 Power and Volume Control Cable Replacement: шаг 42, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 42, изображение 2 из 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    Спросите у FixBot
  43. iPhone 7 Power and Volume Control Cable Replacement: шаг 43, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 43, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 43, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Спросите у FixBot
  44. iPhone 7 Power and Volume Control Cable Replacement, Barometric Vent: шаг 44, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    Спросите у FixBot
  45. iPhone 7 Power and Volume Control Cable Replacement: шаг 45, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 45, изображение 2 из 2
    • Remove the vent.
    Спросите у FixBot
  46. iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable Battery: шаг 46, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable Battery: шаг 46, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    Спросите у FixBot
  47. iPhone 7 Power and Volume Control Cable Replacement: шаг 47, изображение 1 из 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    Спросите у FixBot
  48. iPhone 7 Power and Volume Control Cable Replacement: шаг 48, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 48, изображение 2 из 2
    • Remove the Taptic Engine.
    Спросите у FixBot
  49. iPhone 7 Power and Volume Control Cable Replacement: шаг 49, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 49, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 49, изображение 3 из 3
    Спросите у FixBot
  50. iPhone 7 Power and Volume Control Cable Replacement: шаг 50, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 50, изображение 2 из 2
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
    Спросите у FixBot
  51. iPhone 7 Power and Volume Control Cable Replacement: шаг 51, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 51, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 51, изображение 3 из 3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    Спросите у FixBot
  52. iPhone 7 Power and Volume Control Cable Replacement: шаг 52, изображение 1 из 1
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
    Спросите у FixBot
  53. iPhone 7 Power and Volume Control Cable Replacement: шаг 53, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 53, изображение 2 из 2
    Plastic Cards
    $2.99
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
    • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
    Спросите у FixBot
  54. iPhone 7 Power and Volume Control Cable Replacement: шаг 54, изображение 1 из 1
    • Remove the battery.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    Спросите у FixBot
  55. iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable: шаг 55, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement, Power and Volume Control Cable: шаг 55, изображение 2 из 2
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
    Спросите у FixBot
  56. iPhone 7 Power and Volume Control Cable Replacement: шаг 56, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 56, изображение 2 из 2
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
    Спросите у FixBot
  57. iPhone 7 Power and Volume Control Cable Replacement: шаг 57, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 57, изображение 2 из 2
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
    Спросите у FixBot
  58. iPhone 7 Power and Volume Control Cable Replacement: шаг 58, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 58, изображение 2 из 2
    • Use a pair of tweezers to remove the rear-facing camera.
    Спросите у FixBot
  59. iPhone 7 Power and Volume Control Cable Replacement: шаг 59, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 59, изображение 2 из 2
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
    Спросите у FixBot
  60. iPhone 7 Power and Volume Control Cable Replacement: шаг 60, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 60, изображение 2 из 2
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
    Спросите у FixBot
  61. iPhone 7 Power and Volume Control Cable Replacement: шаг 61, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 61, изображение 2 из 2
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
    Спросите у FixBot
  62. iPhone 7 Power and Volume Control Cable Replacement: шаг 62, изображение 1 из 1
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
    • Standoff screws are best removed using an [связанный продукт отсутствует или отключен: IF145-343] and driver handle.
    Спросите у FixBot
  63. iPhone 7 Power and Volume Control Cable Replacement: шаг 63, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 63, изображение 2 из 2
    • Remove the flash bracket.
    Спросите у FixBot
  64. iPhone 7 Power and Volume Control Cable Replacement: шаг 64, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 64, изображение 2 из 2
    • Use the point of a spudger to gently unseat the flash module.
    Спросите у FixBot
  65. iPhone 7 Power and Volume Control Cable Replacement: шаг 65, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 65, изображение 2 из 2
    Halberd Spudger
    $2.99
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
    Спросите у FixBot
  66. iPhone 7 Power and Volume Control Cable Replacement: шаг 66, изображение 1 из 2 iPhone 7 Power and Volume Control Cable Replacement: шаг 66, изображение 2 из 2
    • Gently fold the power button module from the edge of the rear case.
    Спросите у FixBot
  67. iPhone 7 Power and Volume Control Cable Replacement: шаг 67, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 67, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 67, изображение 3 из 3
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
    Спросите у FixBot
  68. iPhone 7 Power and Volume Control Cable Replacement: шаг 68, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 68, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 68, изображение 3 из 3
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
    Спросите у FixBot
  69. iPhone 7 Power and Volume Control Cable Replacement: шаг 69, изображение 1 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 69, изображение 2 из 3 iPhone 7 Power and Volume Control Cable Replacement: шаг 69, изображение 3 из 3
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
    Спросите у FixBot
  70. iPhone 7 Power and Volume Control Cable Replacement: шаг 70, изображение 1 из 1
    • Remove the power and volume control cable.
    Спросите у FixBot
Заключение
36 человек успешно провели ремонт по этому руководству.
Scott Havard
Участник с: 06/27/16
51 299 Репутация
Автор 31 руководств
8 Комментарии к руководству
Hello,
how can I disassemble and assemble the mute button from the flex cable. because most spare part cables are without mute button…
thanks
Martin - Ответить Поделиться
the mute button can slide out. there is space on the side that is not marked red. it looks like three clips hold it in but simply grab hold of the button nob thing with tweezers and slide or wedge it out from underneath that bar that goes around the side with the red line and then once it’s out you can slip that button into the new flex
reymito sanchez - Ответить Поделиться
Well theres 2 hours of my life I’m not getting back, worked a treat though…
Trig0r - Ответить Поделиться
hahaha aqint that the truth LOL
Sethi Jr - Ответить Поделиться
After reinstalling the volume and power buttons and brackets & clips, my power button won’t turn phone off/on; my volume control seems possessed and does what it wants, lol. Help!
Martha Brewer - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 26
За последние 30 дней: 188
За всё время: 49,234
