iPhone 7 Rear Case Replacement
Выберете то, что вам нужно
  1. iPhone 7 Rear Case Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 7 Rear Case Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Rear Case Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Rear Case Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 7 Rear Case Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Rear Case Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Rear Case Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  4. iPhone 7 Rear Case Replacement: шаг 4, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 4, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  5. iPhone 7 Rear Case Replacement: шаг 5, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  6. iPhone 7 Rear Case Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  7. iPhone 7 Rear Case Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Rear Case Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  8. iPhone 7 Rear Case Replacement: шаг 8, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 8, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  9. iPhone 7 Rear Case Replacement: шаг 9, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 9, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Спросите у FixBot
  10. iPhone 7 Rear Case Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Спросите у FixBot
  11. iPhone 7 Rear Case Replacement: шаг 11, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 11, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  12. iPhone 7 Rear Case Replacement: шаг 12, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  13. iPhone 7 Rear Case Replacement: шаг 13, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 13, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  14. iPhone 7 Rear Case Replacement: шаг 14, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  15. iPhone 7 Rear Case Replacement: шаг 15, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 15, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  16. iPhone 7 Rear Case Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    Tri-point Y000 Screwdriver
    $5.99
    Спросите у FixBot
  17. iPhone 7 Rear Case Replacement: шаг 17, изображение 1 из 1
    • Remove the lower connector bracket.
    Спросите у FixBot
  18. iPhone 7 Rear Case Replacement: шаг 18, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 18, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Спросите у FixBot
  19. iPhone 7 Rear Case Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Rear Case Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Rear Case Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Спросите у FixBot
  20. iPhone 7 Rear Case Replacement: шаг 20, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 20, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 20, изображение 3 из 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
    Спросите у FixBot
  21. iPhone 7 Rear Case Replacement: шаг 21, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Спросите у FixBot
  22. iPhone 7 Rear Case Replacement: шаг 22, изображение 1 из 1
    Спросите у FixBot
  23. iPhone 7 Rear Case Replacement, Barometric Vent: шаг 23, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
    Спросите у FixBot
  24. iPhone 7 Rear Case Replacement: шаг 24, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 24, изображение 2 из 2
    • Remove the vent.
    Спросите у FixBot
  25. iPhone 7 Rear Case Replacement, Taptic Engine: шаг 25, изображение 1 из 2 iPhone 7 Rear Case Replacement, Taptic Engine: шаг 25, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
    Спросите у FixBot
  26. iPhone 7 Rear Case Replacement: шаг 26, изображение 1 из 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
    Спросите у FixBot
  27. iPhone 7 Rear Case Replacement: шаг 27, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 27, изображение 2 из 2
    • Remove the Taptic Engine.
    Спросите у FixBot
  28. iPhone 7 Rear Case Replacement, Speaker Assembly: шаг 28, изображение 1 из 1
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
    Спросите у FixBot
  29. iPhone 7 Rear Case Replacement: шаг 29, изображение 1 из 1
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
    Спросите у FixBot
  30. iPhone 7 Rear Case Replacement: шаг 30, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 30, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 30, изображение 3 из 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    Спросите у FixBot
  31. iPhone 7 Rear Case Replacement: шаг 31, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 31, изображение 2 из 2
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
    Спросите у FixBot
  32. iPhone 7 Rear Case Replacement: шаг 32, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 32, изображение 2 из 2
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
    Спросите у FixBot
  33. iPhone 7 Rear Case Replacement: шаг 33, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 33, изображение 2 из 2
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
    Спросите у FixBot
  34. iPhone 7 Rear Case Replacement: шаг 34, изображение 1 из 1
    • Remove the speaker.
    Спросите у FixBot
  35. iPhone 7 Rear Case Replacement, SIM Card: шаг 35, изображение 1 из 3 iPhone 7 Rear Case Replacement, SIM Card: шаг 35, изображение 2 из 3 iPhone 7 Rear Case Replacement, SIM Card: шаг 35, изображение 3 из 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Спросите у FixBot
  36. iPhone 7 Rear Case Replacement, Logic Board Connectors: шаг 36, изображение 1 из 2 iPhone 7 Rear Case Replacement, Logic Board Connectors: шаг 36, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
    Спросите у FixBot
  37. iPhone 7 Rear Case Replacement: шаг 37, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 37, изображение 2 из 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
    Спросите у FixBot
  38. iPhone 7 Rear Case Replacement: шаг 38, изображение 1 из 1
    • Remove the bracket.
    Спросите у FixBot
  39. iPhone 7 Rear Case Replacement: шаг 39, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 39, изображение 2 из 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    Спросите у FixBot
  40. iPhone 7 Rear Case Replacement: шаг 40, изображение 1 из 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    Спросите у FixBot
  41. iPhone 7 Rear Case Replacement: шаг 41, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 41, изображение 2 из 2
    • Remove the upper cable bracket.
    Спросите у FixBot
  42. iPhone 7 Rear Case Replacement: шаг 42, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 42, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
    Спросите у FixBot
  43. iPhone 7 Rear Case Replacement: шаг 43, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 43, изображение 2 из 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    Спросите у FixBot
  44. iPhone 7 Rear Case Replacement: шаг 44, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 44, изображение 2 из 2
    • Remove the top left antenna.
    Спросите у FixBot
  45. iPhone 7 Rear Case Replacement: шаг 45, изображение 1 из 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
    Спросите у FixBot
  46. iPhone 7 Rear Case Replacement: шаг 46, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 46, изображение 2 из 2
    Спросите у FixBot
  47. iPhone 7 Rear Case Replacement: шаг 47, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Спросите у FixBot
  48. iPhone 7 Rear Case Replacement: шаг 48, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 48, изображение 2 из 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
    Спросите у FixBot
  49. iPhone 7 Rear Case Replacement, Lightning Connector Assembly: шаг 49, изображение 1 из 2 iPhone 7 Rear Case Replacement, Lightning Connector Assembly: шаг 49, изображение 2 из 2
    • Use the point of a spudger to disconnect the lower cable connector.
    Спросите у FixBot
  50. iPhone 7 Rear Case Replacement: шаг 50, изображение 1 из 1
    $5.49
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    Спросите у FixBot
  51. iPhone 7 Rear Case Replacement: шаг 51, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 51, изображение 2 из 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    Спросите у FixBot
  52. iPhone 7 Rear Case Replacement: шаг 52, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 52, изображение 2 из 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    Спросите у FixBot
  53. iPhone 7 Rear Case Replacement: шаг 53, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 53, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 53, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
    Спросите у FixBot
  54. iPhone 7 Rear Case Replacement: шаг 54, изображение 1 из 1
    • Remove the 2.9 mm Phillips screw from the lightning connector.
    Спросите у FixBot
  55. iPhone 7 Rear Case Replacement: шаг 55, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 55, изображение 2 из 2
    • Remove the spring contact from the lightning connector.
    Спросите у FixBot
  56. iPhone 7 Rear Case Replacement: шаг 56, изображение 1 из 1
    • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
    Спросите у FixBot
  57. iPhone 7 Rear Case Replacement: шаг 57, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 57, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 57, изображение 3 из 3
    • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
    Спросите у FixBot
  58. iPhone 7 Rear Case Replacement: шаг 58, изображение 1 из 1
    • Remove the two 1.3 mm Phillips screws from the rear case.
    Спросите у FixBot
  59. iPhone 7 Rear Case Replacement: шаг 59, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 59, изображение 2 из 2
    • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
    Спросите у FixBot
  60. iPhone 7 Rear Case Replacement: шаг 60, изображение 1 из 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
    • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
    • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
    Спросите у FixBot
  61. iPhone 7 Rear Case Replacement: шаг 61, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 61, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 61, изображение 3 из 3
    • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
    Спросите у FixBot
  62. iPhone 7 Rear Case Replacement: шаг 62, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 62, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 62, изображение 3 из 3
    • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
    Спросите у FixBot
  63. iPhone 7 Rear Case Replacement: шаг 63, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 63, изображение 2 из 2
    • Continue to slide the pick underneath the lightning connecter assembly.
    • Stop sliding the pick once it passes the battery.
    Спросите у FixBot
  64. iPhone 7 Rear Case Replacement: шаг 64, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 64, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 64, изображение 3 из 3
    • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
    • Stop sliding the pick when it reaches the lightning connector.
    Спросите у FixBot
  65. iPhone 7 Rear Case Replacement: шаг 65, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 65, изображение 2 из 2
    • Gently pull the lightning connector out of its hole on the rear case.
    Спросите у FixBot
  66. iPhone 7 Rear Case Replacement: шаг 66, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 66, изображение 2 из 2
    • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
    • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
    Спросите у FixBot
  67. iPhone 7 Rear Case Replacement: шаг 67, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 67, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 67, изображение 3 из 3
    • Remove the lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
    Спросите у FixBot
  68. iPhone 7 Rear Case Replacement: шаг 68, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 68, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 68, изображение 3 из 3
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
    Спросите у FixBot
  69. iPhone 7 Rear Case Replacement, Rear Case Battery: шаг 69, изображение 1 из 2 iPhone 7 Rear Case Replacement, Rear Case Battery: шаг 69, изображение 2 из 2
    • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
    Спросите у FixBot
  70. iPhone 7 Rear Case Replacement: шаг 70, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 70, изображение 2 из 2
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
    Спросите у FixBot
  71. iPhone 7 Rear Case Replacement: шаг 71, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 71, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 71, изображение 3 из 3
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    Спросите у FixBot
  72. iPhone 7 Rear Case Replacement: шаг 72, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 72, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 72, изображение 3 из 3
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
    Спросите у FixBot
  73. iPhone 7 Rear Case Replacement: шаг 73, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 73, изображение 2 из 2
    Plastic Cards
    $2.99
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
    • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
    Спросите у FixBot
  74. iPhone 7 Rear Case Replacement: шаг 74, изображение 1 из 1
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    Спросите у FixBot
  75. iPhone 7 Rear Case Replacement, Power and Volume Control Cable: шаг 75, изображение 1 из 2 iPhone 7 Rear Case Replacement, Power and Volume Control Cable: шаг 75, изображение 2 из 2
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
    Спросите у FixBot
  76. iPhone 7 Rear Case Replacement: шаг 76, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 76, изображение 2 из 2
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
    Спросите у FixBot
  77. iPhone 7 Rear Case Replacement: шаг 77, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 77, изображение 2 из 2
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
    Спросите у FixBot
  78. iPhone 7 Rear Case Replacement: шаг 78, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 78, изображение 2 из 2
    • Use a pair of tweezers to remove the rear-facing camera.
    Спросите у FixBot
  79. iPhone 7 Rear Case Replacement: шаг 79, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 79, изображение 2 из 2
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
    Спросите у FixBot
  80. iPhone 7 Rear Case Replacement: шаг 80, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 80, изображение 2 из 2
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
    Спросите у FixBot
  81. iPhone 7 Rear Case Replacement: шаг 81, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 81, изображение 2 из 2
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
    Спросите у FixBot
  82. iPhone 7 Rear Case Replacement: шаг 82, изображение 1 из 1
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
    • Standoff screws are best removed using an [связанный продукт отсутствует или отключен: IF145-343] and driver handle.
    Спросите у FixBot
  83. iPhone 7 Rear Case Replacement: шаг 83, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 83, изображение 2 из 2
    • Remove the flash bracket.
    Спросите у FixBot
  84. iPhone 7 Rear Case Replacement: шаг 84, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 84, изображение 2 из 2
    • Use the point of a spudger to gently unseat the flash module.
    Спросите у FixBot
  85. iPhone 7 Rear Case Replacement: шаг 85, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 85, изображение 2 из 2
    Halberd Spudger
    $2.99
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
    Спросите у FixBot
  86. iPhone 7 Rear Case Replacement: шаг 86, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 86, изображение 2 из 2
    • Gently fold the power button module from the edge of the rear case.
    Спросите у FixBot
  87. iPhone 7 Rear Case Replacement: шаг 87, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 87, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 87, изображение 3 из 3
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
    Спросите у FixBot
  88. iPhone 7 Rear Case Replacement: шаг 88, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 88, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 88, изображение 3 из 3
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
    Спросите у FixBot
  89. iPhone 7 Rear Case Replacement: шаг 89, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 89, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 89, изображение 3 из 3
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
    Спросите у FixBot
  90. iPhone 7 Rear Case Replacement: шаг 90, изображение 1 из 1
    • Remove the power and volume control cable.
    Спросите у FixBot
  91. iPhone 7 Rear Case Replacement, Power Button: шаг 91, изображение 1 из 2 iPhone 7 Rear Case Replacement, Power Button: шаг 91, изображение 2 из 2
    • Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
    Спросите у FixBot
  92. iPhone 7 Rear Case Replacement: шаг 92, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 92, изображение 2 из 2
    • Remove the clip from the rear case.
    Спросите у FixBot
  93. iPhone 7 Rear Case Replacement: шаг 93, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 93, изображение 2 из 2
    • Push the lower end of the power button bracket up off of peg securing it.
    Спросите у FixBot
  94. iPhone 7 Rear Case Replacement: шаг 94, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 94, изображение 2 из 2
    • Pull the bracket from the rear case.
    Спросите у FixBot
  95. iPhone 7 Rear Case Replacement: шаг 95, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 95, изображение 2 из 2
    • Use the pointed end of a spudger to push the power button cover out of the rear case.
    • Remove the power button cover.
    Спросите у FixBot
  96. iPhone 7 Rear Case Replacement, Volume Buttons: шаг 96, изображение 1 из 2 iPhone 7 Rear Case Replacement, Volume Buttons: шаг 96, изображение 2 из 2
    • Pull the volume button clip towards the bottom of the phone to free it from the bracket.
    Спросите у FixBot
  97. iPhone 7 Rear Case Replacement: шаг 97, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 97, изображение 2 из 2
    • Pull the clip towards the top of the phone to remove it.
    Спросите у FixBot
  98. iPhone 7 Rear Case Replacement: шаг 98, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 98, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 98, изображение 3 из 3
    Спросите у FixBot
  99. iPhone 7 Rear Case Replacement: шаг 99, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 99, изображение 2 из 2
    • Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
    • Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
    • Rotate the spudger to pop the bracket off of the peg on the volume button.
    Спросите у FixBot
  100. iPhone 7 Rear Case Replacement: шаг 100, изображение 1 из 2 iPhone 7 Rear Case Replacement: шаг 100, изображение 2 из 2
    Спросите у FixBot
  101. iPhone 7 Rear Case Replacement: шаг 101, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 101, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 101, изображение 3 из 3
    • Repeat the procedure to remove the second volume button bracket.
    Спросите у FixBot
  102. iPhone 7 Rear Case Replacement: шаг 102, изображение 1 из 3 iPhone 7 Rear Case Replacement: шаг 102, изображение 2 из 3 iPhone 7 Rear Case Replacement: шаг 102, изображение 3 из 3
    • Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
    • Remove the volume button covers.
    Спросите у FixBot
  103. iPhone 7 Rear Case Replacement, Rear Case: шаг 103, изображение 1 из 3 iPhone 7 Rear Case Replacement, Rear Case: шаг 103, изображение 2 из 3 iPhone 7 Rear Case Replacement, Rear Case: шаг 103, изображение 3 из 3
    • Use the point of a spudger to push the left rubber speaker vent out of the rear case.
    Спросите у FixBot
  104. iPhone 7 Rear Case Replacement: шаг 104, изображение 1 из 1
    • Remove the right rubber speaker vent from the rear case.
    Спросите у FixBot
  105. iPhone 7 Rear Case Replacement: шаг 105, изображение 1 из 1
    • Remove the 1.5 mm Phillips screw securing the grounding bracket.
    Спросите у FixBot
  106. iPhone 7 Rear Case Replacement: шаг 106, изображение 1 из 1
    • Remove the grounding bracket.
    Спросите у FixBot
  107. iPhone 7 Rear Case Replacement: шаг 107, изображение 1 из 1
    • Only the rear case remains.
    Спросите у FixBot
Заключение
73 человек успешно провели ремонт по этому руководству.
Scott Havard
Участник с: 06/27/16
51 299 Репутация
Автор 31 руководств
10 Комментарии к руководству
Great manual. I was successful in this repair but bought a rear case with small parts. Safes up a lot of work and time :)
Dreetn - Ответить Поделиться
Great Guide!
There are some components that may need to be transferred to your new case, which are not in this guide:
1 speaker screens
2 screen mounting catches
3 put the SIM card tray ejector pin back in BEFORE the logic board. I inserted it before mounting the logic board, otherwise the pin may fall out.
Mike - Ответить Поделиться
Hello everyone!
Has anyone had problems with reception, especially the 4G network, after replacing the body with a non-original one?
thank you and sorry for my terrible english!
Giovanni Fasoli - Ответить Поделиться
Merci tres bon tutoriel tout c’est bien passé
jean.dujardin - Ответить Поделиться
HIW much cost to changing it
ishfaqbhat11 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 32
За последние 30 дней: 180
За всё время: 177,950
