Unibody Laptop Dual Drive
  • Unibody Laptop Dual Drive
  • Unibody Laptop Dual Drive / New / Part Only
  • Unibody Laptop Dual Drive / New / Upgrade Bundle
$24.99
$24.99
Мы отправим сообщение, когда товар будет в наличии.
Спецификации
Описание
Описание
Increase the storage space in your laptop by replacing the optical drive with a second SATA hard drive or SSD.
Part Assembly Includes
  • SATA Optical Bay SATA Hard Drive Enclosure - not for ATA drives or hard drives thicker than 9.5 mm
Заметка
This enclosure does not include a hard drive or SSD.
Disclaimer
This enclosure is not compatible with MacBook Pro Retina models. These models were not originally equipped with an optical drive.
Install Video
Совместимость
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.53 GHz (Mid 2010)
2.66 GHz (Early 2009)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
MacBook Unibody Model A1278
2 GHz
2.4 GHz
MacBook Unibody Model A1342
2.26 GHz
2.4 GHz
Показать еще 12 устройств
Истории ремонта
Моя проблема
I had an SSD I was using as an external via USB adapter. I knew I was not maximizing the speed of the drive. I also had a 2011 MacBook Pro that could barely handle simple processes. I used the iFixit kit to install the SSD on the laptop and reinstalled the operating system onto that harddrive. Now t . . .
Моя проблема
I use a MacBook Pro mid-2009 as a second machine. The CD drive failed long ago, so I decided to use the slot for a second drive.
Моё решение
The repair isn't terribly tricky, but it can be time consuming. The mounting screws need to be inserted into tight spaces.
Мой совет
(1) If you are careful, there is no need to unplug . . .
Моя проблема
Wanted a way to boot into a Windows drive without having to lug around an external drive and without sacrificing space on the main drive.
Моё решение
The repair went well. After doing the teardown a few times, it becomes fairly familiar.
Мой совет
This model of dual drive wasn't advertised to work with the 2GHz Early 2009 . . .
Моя проблема
Wanted more storage and a faster drive
Моё решение
The installation was easy-breezy. The directions in the tutorial made everything very straightforward.
Мой совет
Don't order the parts only dual hard drive kit if you're planning to format your new drive ahead of time or you want to use your old drive as an external at som . . .
Моя проблема
I wanted to upgrade my inspiron laptop to run faster. I purchased the dual hard drive bay to replace in order to replace the OS main drive with a solid state drive. I intended to move the original drive to the optical drive's location. I also purchased a larger stick of memory
Моё решение
It went very well. I pe . . .
Моя проблема
Was entertaining the idea of taking out the disc drive. Tried it out the other day and it was not reading DVDs. So I went ahead and swapped it out for a 500gb ssd as my
Back up bringing me to a total of 980gb of solid state on my laptop.
Моё решение
Fairly simple. Would recommend doing it with plenty of space. A . . .
Моя проблема
Nothing needing repairing, I wanted to remove the optical drive and replace it with a second hard disk drive so I would have extra storage and seemless backup capabilities.
Моё решение
No issues, very fast and easy.
Мой совет
No, not really. The easy step by step guide made everything clear and concise.
Моя проблема
I want more storage in my Mac. So i decided to swap the optical drive with SSD.
Моё решение
The entire process is a really exhausting for the first timers. Certain things like unplugging wires should be done very much care. Ifixit explained it all in detail. There are many small parts that probably can chip awa . . .
Моя проблема
Wanted more partitions for more operating systems
Моё решение
The repair went really well
Мой совет
You cannot use dual SSD drives in the 2011 MacBook pro. There is too much interference and the drive will not work correctly. You have to use a normal hard drive. The fault is Apple's.
Моя проблема
I upgraded my Mac HDD to an SSD but was missing the storage capacity I wanted.
Моё решение
Simple! Easy to do while tired and with some rum in the tank. Pull out the screws, rip out the CD and plonk in the HDD Mount. Definitely not rocket surgery.
Мой совет
I would have preferred if the HDD was accessible from the top; th . . .
Показать еще
