Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Помощь
iPad Wi-Fi Teardown
Редактирование шага 28 —
Тип шага:
Перетащите чтобы изменить порядок
The display seems to be glued around its perimeter but can still be removed from the plastic framework.
The display assembly weighs in at:
193g for the front glass
The glass seems quite thick (~1.18 mm), which is not a huge surprise considering the size of the iPad. Compare that to about 1.02 mm for the iPhone.
The iPad would require thicker glass due to the increased "lever arm" caused by pressing down at the center of the screen. This is analogous to the difficulty of bending a one inch section of a ruler compared to bending the entire twelve inch ruler.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
