Помощь
PlayStation VR Teardown
Редактирование шага 22 —
Тип шага:
Перетащите чтобы изменить порядок
The PlayStation VR Repairability Score: 8 out of 10 (10 is best):
Thoughtfully constructed and fairly straightforward to disassemble.
Many pieces, such as the cushions and light shield, snap in place with no fussy fasteners or adhesive.
Standard JIS J0 screws are used throughout. You can take it apart with a single driver that's likely already in your electronics toolkit (Phillips drivers work for JIS in a pinch).
Adhesive is mild, used sparingly, and mostly easy to remove. However, the lenses are firmly glued in place.
Complicated piece of hardware with a lot of extra trim pieces that would be difficult to reassemble without guides.
Ваш вклад лицензируется под свободной лицензией Creative Commons .
